Previous in Forum: SIL FOS Silver Solder???   Next in Forum: Looking for Suppliers
15 comments
Auto Level Surface
09/24/2007 12:45 AM
Hello Everybody,
About one month ago I asked you guys for help on Topic "Vibration isolation system" using Pneumatics. After your suggestions I have narrowed the topic to Auto level Surface.
Basically I am trying to build a table which will have in fixed leg in the middle connected with the ball joint to the table top so it will have 2 degree of freedom. This table is 12" X 18" and it will have 2 degree of freedom. The others legs will be connected in a right angle of each other. These two legs will be controlled by stepper motor and they will try to keep the surface of the table balanced when the platform of the table will be tilted by +/- 5cm.
If you guys can give me any kind of sport it will be greatly appreciated. Thanks in advance.
Re: Auto Level Surface
09/24/2007 5:15 AM
Good luck, sounds quite a challenge, especially achieving a decent reaction time.
Using gravity (gimbals) has the advantage of simplicity but perhaps disadvantages of weight and space.
Wish I was here more often.
Safety - ESD - RF Manufacturing ESD Installer
09/24/2007 7:18 AM
You might try using some mercury switches mounted underneath the table to activate the levelers.
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
Good Answers: 143
09/24/2007 2:48 PM
Be aware that the motor mounts and linkages will determine whether you have 2 DOF or 3 DOF. You can check out links to Stewart platforms to see how this works.
You also may need to worry about stiffness.
Tom
Good Answers: 54
09/24/2007 8:57 PM
Hi Balraj,
Does your unit look something like this?
Oops, I put pneumatic cylinders instead of stepper motors but the principle's the same. I don't know the dynamics but I think this system is workable. The pivot's in the wrong place (it's supposed to be just underneath the center of the table) but I'm a little lazy to redraw it. You get the idea anyway, I hope.
09/24/2007 9:25 PM
I am sorry for not posting a picture
09/25/2007 1:07 AM
To have precise tilt angle measurement, you need a gyro positioner, transmitter.
The signal will be output through a Fuzzy logic controller to the Servo motor.
tijit
Deut 25:15,16 Honesty in dealings is to God's desires, and dishonesty is His detests.
Good Answers: 54
09/25/2007 1:32 AM
Okay, my idea wasn't quite accurate but similar, in a way.
I've reread your post. What were you asking about? You just asked for support without specifying what kind of support you needed.
Good Answers: 58
09/25/2007 4:54 AM
Barry Controls and others make pneumatic, self leveling, vibration isolation tables used primarily for isolation of optical systems. Design specifics depend on the amplitude and frequency you need to isolate to. Generally, they can isolate down to low numbers of hz and can provide output levels of a few mili Gs throughout the entire spectrum of noise inputs. The design you show will not isolate through the center leg, unless it also is a pneumatic cylinder or some type of compliant member.
Good Answers: 94
09/25/2007 5:29 AM
This is how naval radar arrays are mounted, the ones you see spinning around at the top of the superstructure. The antenna stay level whilst the ship pitches & yaws around in the ocean. The stabilised gimbal mounts use stepper motors & gyroscopic detectors to maintain stability.
09/25/2007 8:19 AM
Are you a yachtsman or similar? Is that the reason for building the table in the first place?
Good Answers: 18
09/25/2007 9:13 AM
You say "the platform of the table will be tilted by +/- 5 cm," but you don't say that the +/- 5 cm is measured at the edge, for example. In the 12" dimension, 5 cm translates to a larger angle than it does in the 18" dimension, if the 5 cm is measured at the edge. (By the way, thanks for mixing units of linear measure.)
It is possible to use two devices called a LOHET (Linear Hall Effect Transducer) to measure two dimensions of motion and directly control servo motors as a function of distance off-level. The output of the LOHET is a function of the strength of the magnetic field it is subjected to. A rigidly attached arm extending down from the bottom of the plate with two or four LOHETS or permanent magnets free to move between two or four permanent magnets or LOHETS rigidly attached to the bottom plate extending upwards will produce the position feedback necessary to control servo motors.
Of course, there are other ways to do the same thing.
09/25/2007 11:09 PM
Go to Newport.com. Look at "Smart Tables." They have exactly what you want.
-Robert Pettis
09/26/2007 12:17 AM
I allready checked that website long time ago, but that is vibration isolation. I am dealing with low frequency only between 1 to 5 hz. I will be using linear actuator and servo motor to keep it balanace. If you could help me finding linear actuator with servo motor for cheap plrice that would be good. Actuator should be able to lift 5Kg, it should have stroke of 12-14cm. I will be using Lab view to control it as well as memes INclinometer.
09/29/2007 10:42 PM
I'm curios why don't you use gyro stabilization ...im not being smart I'm really asking ...
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
10/12/2007 8:49 AM
X-Y Auto level platform:
As a sensor for your leveling mechanism you can use 2 gyroscopic artificial horizons, mounted perpendicular to each other. This will only be feasible if a very high degree of accuracy is needed. You can use two auto pilot general aviation type artificial horizons, they already have the outputs you need. you can get a good used one for $300.00 to $700.00.(calibrated)
A more rudimentary solution is to use capacitive level indicator. that is, 2 perpendicular horizontal levels such as construction level, with two conductive rings wrapped around each end of the liquid tubes at the level markers. Tilting of the level will vary the capacity between the links. You know what to do with this variation.
A third possible solution is to use Mercury switches, and so on.
Telling us what exactly you want to do with your table, might bring some more ideas? however, I hope this helps.
Wangito.
Never trade luck for skill.
Register to Reply 15 comments
Andy Germany (1); Balraj (2); Bill (1); jowens (1); Nigh (1); rpettis1 (1); tijit (1); TVP45 (1); Vulcan (2); wangito (1); welderman (1); wgh71 (1); Wrenched (1)
You might be interested in: Auto Dialers, Level Sensors, Liquid Level Switches
