Previous in Forum: Magnetic Driven Sealless Pumps   Next in Forum: Drying Mechanisms Help
22 comments
Drum Pumps
03/06/2019 2:00 AM
Can drum pumps be used to empty a tank with a considerably large CSA rather than a barrel?
Say, my customer has a highly viscous wax that is to be transferred from a tank to a container. Can I recommend a drum pump? Or is there any other suggestion?
The problem is that the liquid is highly flammable and motor driven pumps cannot be used.
He was asking for an air driven Screw pump initially.
Don't mind being called stupid if you can learn something out of it.
Re: Drum Pumps
03/06/2019 2:48 AM
That should work about as well as any.
The main issue will be how the viscous fluid tends to flow toward the pump suction. If a depression forms into a funnel of air toward the pump, then it will cavitate. But this could be a problem with any type of pump.
Re: Drum Pumps
03/07/2019 10:45 AM
A drum pump has a moving element check valve, it is a moving element that will likely move more slowly or get stuck in a highly viscous fluid. Other suggestions that include no moving elements (other than the pump element) in the fluid path are more likely to be reliable.
i don’t understand the prohibition on electric motor drives, explosion proof induction motors are a mature technology.
Re: Drum Pumps
03/06/2019 3:12 AM
A lot depends on the hazardous classification of the material.
There are pumps designed for hazardous locations,such as gasoline pumps,coal mines,etc. but they are very expensive.
A pneumatic PD pump could work also.
A peristaltic pump might also work.
The pneumatic screw pump sounds reasonable,and as previously stated,there are a lot of variables to consider:
How much flow is desired?
Can the vessel be pressurized?
Can the material be heated safely to reduce viscosity.
Here is a link to peristaltic pumps:
https://www.castlepumps.com/pump-type/peristaltic-pumps
Re: Drum Pumps
03/06/2019 4:05 AM
The latest suggestion that has been made by asking for a possible agitation or heating for the viscosity to be reduced. Then again, if it is a drum pump, it has to be used horizontal because of the orientation of the tank (don't know if it can be used like that).
Now we are planning by hose on either siides so that the pump can be kept farther
Good Answers: 58
Re: Drum Pumps
03/06/2019 3:58 AM
Don't want to be too pedantic, but I have found 413 definitions for the acronym CSA - please tell me what it means in this context.
Re: Drum Pumps
03/06/2019 4:18 AM
Cross-sectional area.
Good Answers: 58
Re: Drum Pumps
03/07/2019 12:09 AM
Re: Drum Pumps
03/06/2019 5:18 AM
<...highly flammable...> and <...viscous wax...> are not usually characteristics of the same fluid.
Viscosity is highly dependent on temperature.
Electric-motor-driven pumps are used routinely for pumping <..highly flammable...> substances: read this. Correct design, installation and maintenance of electrical equipment in potentially explosive atmospheres requires special training. If in doubt, consult a specialist Electrical Engineer.
If the <...customer...> is asking for <...an air driven Screw pump...> then fine, though a progressive cavity lobe pump, a peristaltic pump or a gear pump might also be used, subject to the <...highly flammable...viscous wax...> and the wetted materials of the pump being compatible.
If in doubt, consult a qualified Process Engineer.
Re: Drum Pumps
03/06/2019 7:43 AM
The actual fluid is hexane mixed with sludge and wax
Re: Drum Pumps
03/10/2019 2:10 PM
That doesn't change anything.
The things that will are flowrates, pressures and temperatures. It is still recommended to consult a Process Engineer, who will come up with an operable and safe scheme during process design, and a specialised Electrical Engineer, who will come up with a way of safely making the thing operate.
This isn't something that can be clattered together with a few welding rods and a file after consuming a can of beer or two. Nor is it something a bit of to-ing and fro-ing on an anonymous global internet Engineering blog-site can gather together either.
Good Answers: 18
Re: Drum Pumps
03/06/2019 5:34 AM
Can you give some idea of the sizes we are talking about?
Is the tank the size of a house and is the container the size of a mouse (sorry I couldn't resist it).
Does the wax flow?
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Re: Drum Pumps
03/06/2019 7:39 AM
14m dia x 18m high tank. The hexane mixed with waxy sludge to be pumped out in safe tanks or similar.
Good Answers: 18
Re: Drum Pumps
03/06/2019 9:49 AM
Hi Adil,
Wow! that's a big difference in size.
What time scale do you want to do this over, it looks like a big job.
Does the liquid flow?
If it does, is there an outlet on the tank you could use to adapt to a drum sized container you could fit a pneumatic drum pump to.
That said, it sounds like you will be transferring to dozens or hundreds of smaller containers, the pump output and logistics of handling the product, from the big tank, sounds like a significant concern.
Keep us informed of your thoughts and progress.
Best regards,
John
Good Answers: 58
Re: Drum Pumps
03/07/2019 12:32 AM
If the tank were full and you used the average drum pump and you ran the pump for 8 hours a day, you would empty it in around a month and a half and yes it may work, but you give no indication of the viscosity or what the "sludge" might be.
You give no indication of the flow that you want to achieve, but whatever it is I would strongly suggest that you should be looking at a progressive cavity pump (Mono is one of many brands) in order to pump hexane/wax/sludge.
Electric motor drives are perfectly acceptable for use in hazardous areas, they are used all the time. You would need to consult an expert, but probably class1 division2 motor would be acceptable.
Re: Drum Pumps
03/15/2019 3:51 AM
At what rate?
To what change in elevation?
These are the sorts of questions that need to be addressed.
<unsubscribes>
Re: Drum Pumps
03/06/2019 1:18 PM
Is this an imaginary tank, or does it already exist?
If imaginary, consult a qualified process engineer as PWSlack suggested. Electric pumps can be used in a correct design.
If it really exists, how is the fluid transfer accomplished now?
Can your customer provide the forum with more detail?
I'm guessing that this plea for help is related to your first post,
You should seek guidance from a known qualified professional, not an anonymous forum who has very little knowledge of this operation.
Hire a consultant!
Re: Drum Pumps
03/06/2019 11:13 PM
As someone pointed out liberally applied heat works wonders for pumping viscous liquids -- I have worked on processes where we pumped a mixture of lead, zinc, silver , and gold and it tended to become very viscous when it cooled down.....as in we had big natural gas burners all along the pipelines and if the heat went out or the pump stopped it was not a bit fun...
But your mixture is not as much fun, if you heat it very much, or maybe at all the pentane, which sounds like it might be there for a solvent, will boil off then you will be in worse shape, not to mention the flammable vapors.
I would think about an air driven, (if it wants to be portable) or electrically driven , explosion proof, double diaphragm pump with a 2 to 4 inch suction.
They self prime, so cavitation does not matter, and they can be made of high temp and non sparking materials, I have used them to pump thickener concentrate which was 80 or 90% solids density and for pumping water out of holes doing pipeline repairs.
Hope this might help.
Expat007
Re: Drum Pumps
03/07/2019 3:36 AM
Thanks for the reply,
I work in a company that sells pump and I was given the responsibility exclusively for plastic mag drive and Drum Pumps recently, hence the posts.
The customer here is a chemical cleaning/maintenance company and the said tank isn't something what they have done before. I was checking if this application suits my pumps and was up for suggestions. I wanted knowledgeable third person opinions before I suggest something. Of course, once I pass on, it will be carried out by professionals.
Re: Drum Pumps
03/07/2019 5:16 AM
Given your apparent total lack of knowledge of pumps and processes, I'm surprised that you were given this assignment.
Good luck.
<unsubscribe>
Re: Drum Pumps
03/15/2019 3:50 AM
<...plastic...> [which one(s)?] and <...hexane...> is of more relevance than the drive of the pump.
Consult a qualified Process Engineer before proceeding.
<unsubscribes>
Re: Drum Pumps
03/07/2019 11:44 AM
I would recommend a pneumatic grease pump. It will move viscous material and will avoid air locking in use.
https://www.mscdirect.com/product/details/04616330
Good Answers: 58
Re: Drum Pumps
03/11/2019 3:00 AM
A grease pump would take an awfully long time to empty a tank that size and they are not that fond of sludge.
Register to Reply 22 comments
Adil Iqbal (4); Epat07 (1); HiTekRedNek (1); jesw55 (2); Jpfalt (1); lyn (2); PWSlack (4); rwilliams (1); The Prof (4); Tornado (2)
