Previous in Forum: CCFL Inverters   Next in Forum: Adhesive for Bonding Styrofoam Sheets
59 comments
Engineering Fields - Manufacturing Engineering - New Member United States - US - Statue of Liberty - New Member
Turning Clocks Forward and Back
10/31/2007 12:02 PM
i can never remember this. can anyone give me some ideas?
Vote your hope not your fear.
User-tagged by 1 user
Re: turning are clocks forward or back?
10/31/2007 12:05 PM
Spring forwards.
Fall backwards. ['Fall' is an Americal word for 'Autumn'].
10/31/2007 1:51 PM
that is good . i think i can remember that, thanks
10/31/2007 6:51 PM
Fall back.
10/31/2007 10:00 PM
thanks
10/31/2007 12:27 PM
depends whether yo want to be 2 hours longer in bed or two hours late for something!
I just remember it by the fact that we move the clocks so as to make the problem WORSE!!! (In the evenings).
Wish I was here more often.
11/01/2007 12:11 PM
Thanks for the tip. Nice cherry by the way!
Good Answers: 918
10/31/2007 1:06 PM
Those in the northern hemisphere will turn their clocks back (fall back).
Those in the southern hemisphere will turn their clocks forward (spring forward).
10/31/2007 9:57 PM
so i could not go wrong? Nan
Good Answers: 918
11/01/2007 6:56 AM
Shhhhhhh! :)
11/03/2007 3:20 PM
"Those in the northern hemisphere will turn their clocks back (fall back).
Those in the southern hemisphere will turn their clocks forward (spring forward)."
Where ever they are:
will turn their clocks back (fall back)& forward (spring forward).
Northerns or Southerns all have their OWN Spring & Fall.
Don't bring them in your "hemisphere", let them stay @ their OWN.
See also:
http://cr4.globalspec.com/thread/11849/Daylight-savings-time
What the people say about "Daylight-savings-time" the related discussion.
11/04/2007 10:11 AM
Yes Haajee. Thank you for referring to my previous thread.
No one ever answered that question. Originally I asked, "Can't we just split the difference and cut this crap out?"
I guess not.
cr3
Good Answers: 123
11/05/2007 10:25 AM
If I understand you correctly, you are saying that clocks run counterclockwise south of the equator.
Bob
11/05/2007 10:39 AM
"If I understand you correctly, you are saying that clocks run counterclockwise south of the equator."
Everything south of the equator is upside down and backwards!
11/05/2007 2:18 PM
No Sir!
What I mean is that in the South SEASONs ARE OPPOSITE IN YEAR to those in NORTH.
Their X-Mas is in Hottest [like our June]
When here is Spring it is Fall in South & viceVersa
When here we are advancing our clocks they are reversing their clocks
11/07/2007 10:32 AM
No. That's the Coriolis Effect.
11/05/2007 11:46 AM
Except in Arizona.
Re: Turning Clocks Forward and Back
10/31/2007 3:51 PM
Just turn your clock OFF and forgetaboutit
11/01/2007 12:48 AM
don't i wish!
10/31/2007 11:53 PM
tubenut "i can never remember this. can anyone give me some ideas?"
Spring Forward, Fall Back!
Simple solutions for simple problems! SS
11/01/2007 12:13 PM
sorry i don't get the connection, but thanks anyway.
11/01/2007 3:59 AM
............time machine!!...
Good Answers: 12
11/01/2007 6:23 AM
I have this grandfather clock which must never be turned back, only forward. So I have to turn the hands forward 23 hours to fall back, stopping every 15 minutes (not literally) to let the chimes adjust. So it's not always a trivial matter which way a clock should be turned, don't you see!
Good Answers: 15
11/01/2007 7:04 AM
Or you could just stop it for 23 hours.
scotchdrnkr
11/01/2007 5:04 PM
25?, or 1?
11/01/2007 10:52 PM
Another good point.
The dial can spring forward an hour fairly conveniently. Count the 4 pauses needed to do so, multiply that by the 11 pauses needed to spring the dial 11 hours forward so the time falls 1 hour backward....check another clock to see how long it takes....you get the idea!
CowAnon
11/01/2007 8:07 AM
"I have this grandfather clock which must never be turned back, only forward. So I have to turn the hands forward 23 hours to fall back, stopping every 15 minutes (not literally) to let the chimes adjust."
Just like the one I have. No problem in the spring to advance the time one hour manually.
"So it's not always a trivial matter which way a clock should be turned, don't you see!
In the fall it is simply a matter of stopping the clock for an hour. If you forget and don't start it right on time, adjust it forward to the correct time!
Simple solution for a simple problem.
Never forget that the official time change is to be done at 02:00 hours!
11/01/2007 11:01 PM
That's probably the key...but it takes some advance planning for falling back.
Sometime near fall back time, just let the clock run down. Wait until the fall back time and the clock dial coincide. Crank up the weights. Give the pendulum a boost. Back on schedule.
But oh,....there's the 'hunter's moon' dial to think about, too. Hmm?
CowAnon
11/01/2007 8:17 AM
Why don't you stop the Grandfather clock by holding the pendulum for a few seconds and re-start it 25 hours afterwords so you will have gone back 1 hour. This would be much easier than turning the clock hour by hour
Popular Science - Weaponology - Cardio-7
11/01/2007 8:28 AM
Am I missing something? Is the grandfather's clock digital? Why 23 or 24 hours? The clock likely has a 12-hour dial face.
Good Answers: 12
11/01/2007 2:20 PM
Please see reply further down the thread.
Good Answers: 123
11/01/2007 9:45 AM
Hey, try this. Write the numbers 1-12 on sticky tape. Put the 12 over the 11. Put the 11 over the 10. Put the 10.... You get the idea? to make your eyes more familiar with the new locations just tilt the clock 30* clockwise. What was so friggen hard about that.
Bob
11/01/2007 12:01 PM
thanks Bob, i 'll get my translator right on it!
11/01/2007 12:06 PM
If it were me i would not look at it for six months.
Good Answers: 123
11/01/2007 12:44 PM
Perhaps it would just be easier to purchase another matching clock and set that one for the modified time schedule. Back to back on a lazy Susan. It could work.
Bob
11/01/2007 1:51 PM
I was thinking along the same lines, thanks. Going on job sites with a portable Fence notcher that has a computer chip embedded. I think it would be a bad idea.
Good Answers: 12
11/01/2007 2:37 PM
Excellent point, Cardio07, Guess I got carried away. (And, you've already cut "12 hours" off my next clock resetting)
To everyone, thanks for the "timely" tips. My clock has crank-up weights--one each for clock movement, 1/4-1/2-hour strike, and any of the three selectable chime tunes. So I'm not sure about stalling the weights--I would guess this is the way those clocks with a stop feature work. Another way might be to stop the pendulum--maybe remove the weights from their cables as well. I wonder...?
11/01/2007 7:57 PM
cheers!
Popular Science - Weaponology - Scapolie, new member.
11/01/2007 8:14 AM
Hi tubenut, Turning the clocks back in the autumn (fall USA) originated during the Last war (WWII). This was to give the farmers in the northern hemisphere more daylight in the mornings. Spencer.
11/01/2007 8:40 AM
Actually, I think the idea was first put forth by Ben Franklin way back when - and if I remember, it was to provide more daylight at the END of the day for agricultural purposes. It is an odd thing, now it's voiced as an energy saving process somehow, and adhesion to it is somewhat slipshod in parts of America..
"For a successful technology, reality must take precedence over public relations, for Nature can not be fooled." - Richard Feynman
11/01/2007 8:52 AM
The extra hour of daylight could burn the crops. I know there is one less hour in the morning, but everyone knows the afternoon sun is hotter
Good Answers: 123
11/01/2007 9:36 AM
What crops do you know of that do not observe daylight saving time? In Florida there are severe penalties for any plants that fail to comply.
Bob
11/05/2007 11:51 AM
Lettuce in Yuma. Of course, to grow in Yuma, lettuce has to be a bit different anyways.
Good Answers: 123
11/05/2007 12:51 PM
Ahh yes. Now I remember. "Lettuce" said guest crisply.
Bob
11/01/2007 10:43 AM
Turning the clocks forward or back DOES NOT CHANGE THE NUMBER OF HOURS THE SUN SHINES ON THE CROPS.
The whole idea is to regulate hours of daylight for those who follow the clock.
It is akin to the indian who cut one foot off his blanket and sewed it on the other end, to make the blanket longer.
11/01/2007 11:10 AM
I thought he was an American, someone by the name of GW, that's what I heard, I mean it was Secondhand news
11/01/2007 12:52 PM
Yes. After reading the Wiki entry it makes a lot more sense (well, as much as DST does anyway..) - Not sure where I got the idea that Franklin came up with it, probably some schoolbook story from my dim past.
11/01/2007 2:03 PM
I just wanted to chime in here on the Wiki website. it is a good ,very good, resource center.
11/01/2007 12:09 PM
Thanks for the history Lesson ,Spencer.
11/01/2007 9:27 AM
It's just a jump to the left, and then a step to the right
put your hands on your hips, and pull your knees in tight...
oh wait, thats how to warp
I'm not a real engineer, I just play one on TV
Good Answers: 123
11/01/2007 9:39 AM
Thanks, I needed that.
Bob
11/01/2007 10:27 AM
Please see...here
11/03/2007 11:56 AM
Don't forget. This only happens once a year!
TONIGHT'S THE NIGHT!
11/03/2007 5:51 PM
tomorrow morning is!
11/03/2007 6:11 PM
tubenut:
You can get up and reset yours at 2:00 AM if you want to.
AFAIAC TONIGHT'S THE NIGHT!
SS
11/03/2007 6:30 PM
Stirling Stan: I guess were both correct.
Stan I like the way you put a user name up there. I am going to incorporate this also!
It is also easier to track.
11/04/2007 12:43 AM
Hi there,
The easiest way to remember is you "spring forward" and "fall back". I hope this helps.
Jenn
11/04/2007 1:20 AM
Thanks Jenn . hope you stick around Jenn this is an interesting site. I just join a few days ago. i am already addicted.
11/04/2007 5:12 AM
Dig it! There's AA; and there's CR4:
For compulsive, compulsive, compulsive, constantly
11/07/2007 10:35 AM
It does rather depend on how close to the speed of light the clock is travelling!
Register to Reply 59 comments
Anonymous Hero (2); Anonymous Poster (8); Bob B. (1); bob c (6); Cardio07 (1); CowAnon (3); Haajee (2); Hellcat (1); Jim at GodwinPumps (2); Labyguy (1); M Chasin (1); PWSlack (2); Scapolie (1); scotchdrnkr (1); Stirling Stan (5); TexasCharley (3); tubenut (15); vikas (1); vishmayor (2); Wrenched (1)
You might be interested in: IC Clocks, Turning Tools, Lathes and Turning Centers
