Previous in Forum: Building the Pyramids   Next in Forum: Environmental & Ecology Section
25 comments
The Weight of Heavy Water?
11/15/2007 1:15 PM
water; if fresh water wieghs 10 lbs. and salt 7.5 lbs. What does heavy water wiegh?
Re: water
11/15/2007 1:45 PM
do not know if this is what you are asking for, it also tells you about semi heavy water
http://en.wikipedia.org/wiki/Heavy_water
Re: water
11/16/2007 10:39 AM
sorry i may have mis worded my question,but i am sorry. i believe no question is a stupid question. especially at my age. sorry you feel the way you do. sad for you
Re: water
11/16/2007 10:52 AM
Guest,
I think you mistook the poster's quote as being directed to you. I can't speak for the poster, but I would be willing to bet it wasn't directed at you. We all have a quote that we like that is attached to our posts and we don't usually change it when we answer a particular thread. Don't take it personally.
Jim
"That's just my opinion, I could be completely wrong."--Dennis Miller
Re: water
11/16/2007 4:42 PM
no problem thank-you for straighting me out. Take-Care Barry
Good Answers: 18
Re: water
11/16/2007 5:44 PM
For the record, the poster's signature quote was made by Abraham Lincoln.
Re: water
11/19/2007 9:03 PM
no, my quote was'nt directed to you, its something that I try to follow. My dad told this to me when I was a teenager, I thought it was his, only to find out it has quite a few authors, including the bible.
I try to follow it, but not all the time , as you can see it is wise advise.
Good Answers: 918
Re: The Weight of Heavy Water?
11/15/2007 3:37 PM
Is this a Gico insurance question?
Then, the answer is Spring.
Look up the molecular weight of hydrogen and oxygen and do the math for each for a given volume. Basic chemistry.
Good Answers: 32
11/16/2007 8:57 AM
Sorry, you can't calculate the density of a liquid by the molecular weight, so it's a bit more than basic chemistry.
However, I have no idea what he is asking.
Tad
Good Answers: 97
11/15/2007 5:03 PM
Are you asking about the weight after dissolving the salt in the water?
11/15/2007 6:33 PM
Are you talking NaCl in H2O, or D2O or what?
11/15/2007 7:16 PM
"water; if fresh water wieghs 10 lbs. and salt 7.5 lbs. What does heavy water wiegh?"
1- lb. + 7.5- lb. = 17.5- lb. Most any fool knows that!
If this information is critical to your job, you should have already looked it up in Wikipedia.
OTOH if it is just out of idle curiosity, again you should have already looked it up in Wikipedia.
Look up the information for a requestor and he will ask you to do it again. Teach him to look it up for himself and you have added a new 'skill' to his capabilities.
11/15/2007 9:27 PM
Deuterium oxide a.k.a. heavy water density is 1.10469 g/cm3 at 0 °C, 1.10445 at 25 °C, and 1.06346 at 100 °C.
11/15/2007 10:00 PM
" if fresh water wieghs 10 lbs. and salt 7.5 lbs. What does heavy water wiegh?"
How do you get from the above to your answer below? Doogle doesn't recognise the above data?
"Deuterium oxide a.k.a. heavy water density is 1.10469 g/cm3 at 0 °C, 1.10445 at 25 °C, and 1.06346 at 100 °C."
11/15/2007 10:43 PM
I should´ve quoted the source, sorry. Handbook of Chemistry and Physics, 56th ed.
11/23/2007 10:18 AM
thats what i'm talking about. thank-you for your answer and patience Barry
11/16/2007 3:49 AM
Re : 'Heavy Water', Water is at its highest level of density at 4 degress C. It would therefore mean that whether it is in its purest state or contains salts or impurities, it would still have its highest level of density at 4 degress C., meaning that is when it is heaviest.
11/16/2007 4:01 AM
Let's not get confused between weight and density.
The weight of a given quantity will remain the same, ie, matter can be neither created or destroyed.
It is the density which changes with temperature.
I have learnt something new, that heavy water is denser than water, well, I guess it would be, wouldn't it.
But how 'heavy' is light brown and light beer? Reminds me of the apprentice sent to the stores for some elbow grease and a long weight.
gem
11/16/2007 5:04 AM
... and a new bubble for the spirit level .
BTW in Scotland, a pint of ordinary beer is called 'heavy' (as distinct from 'special', 'export' etc.).
11/19/2007 9:06 PM
in wisconsin lite beer is called unleaded,
United Kingdom - Member - Member
11/16/2007 7:42 AM
Long stand, bucket of blue steam, bucket of melted ice, sky hook, striped/tartan paint, left handed screwdriver, glass hammer, square bubble for the spirit level.
Pulled them all off with apprentices
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Good Answers: 12
11/16/2007 6:16 PM
Lets not forget the metric Crescent wrench (adjustable spanner).
I am wondering where the salt (mentioned by the originator of this thread) enters into thiings. Salt doesn't have a thing to do with heavy water.
Bill
11/16/2007 8:30 AM
You wrote that "the weight of a given quantity will remain the same"
This is not the case, the weight will change dependent upon the effects of gravity on the object being measured...the mass will remain constant (unless it is travelling very very fast and is being affected by relativity). Weight is the measure of gravity's effect on mass, mass is a measurement of the amount of matter.
I'm not sure if the original poster wants to know what the molecular mass of heavy water is or if they are looking for a more complicated answer, but my simple answer would be to take the molecular weight and add the mass of two neutrons. It's been a while since I've even though about heavy water, but I know that to some degree it does exist naturally (since isotopes of hydrogen exist naturally in relatively small amounts).
Good Answers: 247
11/16/2007 12:44 PM
10 lbs of heavy water will weigh precisly 10 lbs.
11/16/2007 12:57 PM
"10 lbs of heavy water will weigh precisly 10 lbs."
And 7.5 pounds of salt will weigh precisely 7.5 lbs. Eureka!
11/22/2007 8:57 PM
Interesting question, I recently had a discussion about water and Ice, and the fact that water is most dense at 4 deg C, that's why Ice floats, and in your drink the coldest liquid remains at the top of the glass. We discussed the possibility of weighted ice to make the temperature of a drink uniform.
Will Deuterium oxide ice cubes sink in water?
Perhaps that is the solution to warm drinks???
Regards CEKM
Register to Reply 25 comments
agua_doc (1); Anonymous Hero (1); Anonymous Poster (3); Blink (1); Bolton_Alan (1); coffeebean (2); Georgee (1); Hendrik (1); JimR79 (2); John Duncan (1); JohnDG (2); phoenix911 (3); Sciesis2 (1); Stirling Stan (3); Tad (1)
