I'm not sure how many of you are musicians, so i'll preface my post with a bit of background.
There are a number of products on the market for the electric guitar
which produce artificial feedback. They basically consist of a pickup,
gain stage and magnetic driver. The idea is the device will sustain a
string indefinately when activated. They usually come with a harmonic
mode switch to sustain the string in a number of different harmonic
modes above the fundamental.
The most popular sustainer product (the "ebow") is a small handheld
unit which sits over a single string. It is only designed to sustain a
single string at a given time.
There are a number of competing products which consist of a pickup that
transduces the signal from all of the strings simultaneously and drives
all of the strings simultaenously (through a single gain stage).
A similar variant is a device called the "sustainiac" which uses the
guitar's output signal to drive a neodymium exciter which is literally
clamped to the body of the guitar, causing the strings to resonate by
vibrating the body of the guitar.
Most of these devices claim to offer "polyphonic sustain", that is they
will allow any number of strings to be sustained simultaneously.
In my experience, however, this doesn't seem to be the case. The same
is true for natural feedback that one would obtain from an amplifier
turned up very loudly (with loads of preamp gain). If you release the
strings, one string will always end up being dominant and will
preferentially sustain over the others.
I've found that these sustainer products are capable of sustaining
multiple strings simultaneously when they're intimately harmonically
related, (for example a string and its higher octave counterpart).
I have been trying to find some insight into why this occurs using
control theory, but I haven't had much success. My theory is that if
the sustainer product featured six independent transducers (one for
each string, commonly referred to as a hexaphonic pickup), six
independent gain stages, and six independent drivers, then surely it
would be able to sustain six strings simultaneously?
Why is it that a single transducer, single gain stage and single exciter is only capable of resonating at the one frequency.
What's the critical limiting component here?
