Previous in Forum: Feel the Music: Questions About Feedback Mechanisms   Next in Forum: What is Leakage Flux?
19 comments
Motor Windings: Aluminum vs. Copper Wire
12/04/2007 11:02 PM
Hellow,
Can you give a information or difference between motor winding by aluminium wire and 100% copper wire.
Now I am facing a lot of problems about this.
How can I justify or cheek that type of motor winding.
Good Answers: 143
Re: Motor Windings: Aluminum vs. Copper Wire
12/05/2007 9:27 AM
Aluminum costs a little over $1 USD per pound and copper a little over $3 USD per pound for the metal.
Aluminum has a significantly higher resitivity, requiring a larger coil.
Aluminum expands a lot more when hot.
Aluminum tends to form a very non-conductive oxide layer at any connection point.
12/06/2007 1:22 AM
Thanks for reply.
But let me know can I justify or cheek the motor when I buy.
I want to cheek that without motor connection. Because when I buy it, they are not agree to connect electric connection and load.
Kindly give reply.
01/26/2023 10:10 AM
Undefined: <...they...>.
12/05/2007 5:15 PM
I admit I am ignorant of a motor wired with aluminum. I have never seen one.
James
" adapt, improvise, overcome "
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
12/06/2007 8:36 AM
I have never seen a motor wired with aluminum.
Are you talking about Die cast Rotor Bars?
You can get those in Al or Cu
“There's a sucker born every minute, and I happen to be one of them”
12/06/2007 11:50 AM
I do believe that most car starter motors have been made with aluminium windings for many years, repairing is consequently very difficult, which is what the makers want!!!
To put a proper brass cable shoe onto an aluminium wire, it used to be pushed together and the cable shoe spun till it got hot and then suddenly stopped, that would join the two. How they do it today I haven't a clue!! probably Laser or something....
12/06/2007 2:49 AM
An aluminum wound motor will function the same as a copper wound motor. Applying the nameplate voltage should make it run without excessive noise or heat, but tie it down first.
Clintb3252
12/06/2007 4:32 AM
The aluminium motor will probably be a bit lighter in spite of thicker wiring.
The biggest problem I see is when the need to repair comes along, aluminium needs special connectors and equipment whereas copper can be soldered....
But in all other aspects, surely the differences will not be noticeable?
Perhaps you could detail your worries better?
12/06/2007 6:21 AM
You should be able to look in one of the ends. Aluminium will be silver/yellow depending on the varnish and copper more of a red color. If not, look where the hook up wires are connected.
12/13/2007 2:11 PM
hello
it is depending on core. if the core slot have more space then you insret the SWG no. like if there is 20 then you insert 19. and give good varnish like razan chemical. conform that the wire is not lose in slot. the melting temperature of aluminum is low then copper on this reason when the aluminum reach at melting temperatuer the good varnish save enamel from damage.
Good Answers: 109
12/13/2007 5:58 PM
Hi,
there was a series of aircraft motors and transformers with aluminum wires (50years ago),does anybody know more about it?
Nowadays there are the coils of harddisc memories sometimes wound from aluminum wire, this is giving faster acceleration despite bigger size (if resistance is the same as with copper winidings).
Not only connecting aluminum wire is difficult (except compression welding with or without ultrasonics - widely used in semiconductors and thick film power electronics and except laser welding) but more difficult is to get samples of the wire to test concepts.
I once asked for a 0.3mm diameter and the suppliers wanted me to buy minimum 100kg up to 1000kg - and tjis wire comes without any insulation!
So this is not ready to use.
But there is one major pro that should be considered: anodising is giving very good electrical insulation combined with pretty good thermal conductivity.
So if the polymer is restricted for gluing the coil to a rigid coil the thermal resistance from inside the coil to the mounting structure will be much lower, allowing more heat conduchted to the base structure. This may well counterbalance the higher resuistance!
RHABE
12/14/2007 8:03 AM
You wrote:-
I have not a clue what you are talking about!! please stop taking the tablets asap
Reply Off Topic (Score 6)
Good Answers: 109
12/14/2007 12:04 PM
Hi Andy,
take a screwdriver and open your old harddisc.
You will see the motor with the plates, the arm with its moving coil and stationary magnet system and ballbearing unit, preamplifyer and some wiring.
Only in older ones (pre 1995) you will detect the read-write head on the end of the airbearings that ride above the surface of the discs.
The moving coil - fixed to the arm - is made from copper wire for most harddisc drives but sometimes from aluminum wire.
Have a nice Christmas.
RHABE
12/14/2007 12:39 PM
Look what you wrote:- "Hard disk memories", that is what caused the problem.
A hard disk is not a memory my friend.....its a data storage device.
Memory loses its knowledge when power is switched off.....hard disks should not (sometimes they do if you switch off too quickly or have a virus!!)
Now we have that cleared up in a professional manner at last!! Its a concept problem I think....but we must be as accurate as possible as many others read this.....
Good Answers: 109
12/14/2007 6:56 PM
Memory or data storage does not matter, I don't care if there is a difference or not.
Your brain and some computers have permanent and volatile memories.
RHABE
12/14/2007 7:29 PM
I guess that you have no wish to learn something correctly for once.
Well you will see that several people have marked you as "Off topic" on this answer, can you work out why?
Good Answers: 109
12/15/2007 3:21 AM
100% correctness is near to fundamentalism.
RHABE
12/15/2007 3:15 PM
And what does this "off topic" remark have to do with this blog????
Good Answers: 109
12/15/2007 3:45 PM
Nothing as you know.
Only referring your previous comment.
RHABE
Reply to Forum Thread 19 comments
Andy Germany (6); Anonymous Poster (2); Clintb32 (1); DGCYS (1); hastingselectric (1); PWSlack (1); RHABE (5); T Man (1); TVP45 (1)
