Previous in Forum: Why are Radians Dimensionless?   Next in Forum: Cubicle Accessories?
18 comments
Nomenclature - Lamp vs. Bulb
12/05/2007 1:55 PM
As a young lad growing up, whenever the discussion of light-producing devices came up at the dinner table my dear old momma always cautioned me to say "lamp" when referring to fluorescent devices and "bulb" for incandescent ones.
Now, momma was a fine woman with a pure soul but it was a fact that only those perople who were basically done with living life would ever dare question her about how she arrived at a given opinion on such matters.
But now that I'm old and wise, I've been allowing myself to dwell on what if anything makes the difference? I always sort of felt that it had something to do with the pressure contained inside the envelope -- bulbs < atmospheric and lamps > atmospheric. Or at minimum the shape (bulbs being...er...bulbous).
However, you tend to see bulb and lamp used interchangeably and with reckless abandon where fluorescents are concerned. And since the actual fixture into which either is installed is also sometimes called "a lamp" then where does this leave us?
Anyone care to opine on the correct terminology?
Re: Nomenclature - Lamp vs. Bulb
12/05/2007 2:08 PM
Bulb - the thing that the light comes from.
Lamp - the thing that holds the thing that the light comes from.
Good Answers: 66
12/05/2007 2:52 PM
Growing up around industrial electricians I can tell you that all light emitting elements were referred to as "lamps". Bulb was strictly a layman's term. The thing that holds the lamp? "Lighting fixture." Installing lamps was always "lamping the fixtures". Replacing elements was "re-lamping".
Aequam memento rebus in arduis servare mentem.
04/02/2010 1:02 AM
Correct, having worked in the industry in the past, my boss always told me that a lighting device made of glass was a Lamp . . . a bulb is something you plant in the ground in the springtime.
Hobbies - HAM Radio - New Member Fans of Old Computers - Apple II - New Member Canada - Member - 'ssauga eh?
12/05/2007 3:48 PM
Good answer since all the solid state light emitting devices I have used have been referred to as lamps or emitters specifically.
But where did the laymans term originate?
My speculation is the early hand blown glass incandescent lamps were similarly shaped to the standard flower bulb.
Now why electronic valves were referred to as tubes I can't hazard a guess.
there are 10 types of people on this earth. Those who understand Binary and those who do not.
12/05/2007 4:03 PM
bulb
1568, "an onion," from M.Fr. bulbe, from L. bulbus "bulb, onion," from Gk. bolbos "plant with round swelling on underground stem." Expanded by 1800 to "swelling in a glass tube" (thermometer bulb, light bulb, etc.).
Online Etymology Dictionary, © 2001 Douglas Harper
Canada - Member - New Member
Good Answers: 11
12/06/2007 12:30 AM
Great, with onions, you get biodegradable, green bulbs!
12/06/2007 6:28 PM
I concur here: "Bulb" = rounded enlargement (think pneumatic "thingie" on end of sphygmomanometer)
"Lamp" = thing that gives light or heat (i.e. whale-oil, or kerosene[parafin] lamps)
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 266
12/05/2007 3:58 PM
I always thought the lamp was the fixture. As a lamp can produce light with out a bulb. The electric light bulb is just part of the lamp just as the wick in an oil lamp is.
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
12/06/2007 3:00 AM
I would have gone with the explanations above until I emigrated to Oz. Especially as I live under down under, they have a different nomenclature here.
Bulbs and lamps = GLOBE
Tubes = Fleuro's
I think people will come up with different terminology from around the world. When in Rome............!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Good Answers: 54
12/06/2007 5:27 AM
I always thought that all electric lights are "lamps", including the incandescent bulb. The reason why they call it a bulb was because of its shape.
Ergo, a bulb is a type of lamp.
12/06/2007 8:41 AM
I've been brought up to think of 'bulbs' as the light emitting part of an assembled 'lamp'...
As in bulb = wick and lantern = lamp or torch
And a fluorescent 'bulb' in called a tube, due to its shape...
An electonic 'tube' is called a valve etc...
Confused? I blerdy am
John.
12/06/2007 8:44 AM
Oh I forgot and also a torch = flashlamp!!
a flaming torch is called a match / flame / candle / fire etc...
A lantern is a ..... errrmmm stumped there!!
John.
12/10/2007 9:08 AM
<A lantern is a ..... errrmmm stumped there!!>
How about 'a housing, usually decorative, that partly or totally surrounds a light emitter'?
12/10/2007 1:00 PM
I would concur with that description.
But thinking about it if the lamp is the complete lighting fixture then why is a lamp-shade called that? As its only part of the lighting fixture that covers the bulb... It should be called a bulb- shade!!?
Brain is addled.... John.
12/10/2007 1:17 PM
and...
"Buildings should only be called that when they are being constructed. Afterwards they should be called 'Builts' or 'Crumblings'. " Gallagher
12/06/2007 9:41 AM
Definitions from the IESNA handbook (Illuminating Engineers of North America)
Bulb See Lamp
Lamp a generic term for a source created to produce optical radiation. By extension, the term is also used to denote sources that radiate in regions of the spectrum adjacent to the visible.
Note Through popular usage, a portable luminaire consisting of a lamp with shade, reflector, enclosing globe, housing, or other accessories is also sometimes called a lamp. In such cases, in order to distinguish between the assembled unit and the light source within it, the latter is often called a bulb or tube, if it is electrically powered.
12/06/2007 11:16 AM
L.E.D. = Light Emitting Diode
an emitter lol
12/06/2007 1:50 PM
Just semantics so far as I know. My Papa always called the FIXTURE a lamp, the glass-enclosed filament a bulb, and if fluorescent, a tube. Why it would matter to anyone more than that is, however, quite beyond my ken.
Reply to Forum Thread 18 comments
Anonymous Poster (2); Beej50 (1); bhankiii (2); CSM Engineer (1); Electroman (3); EnviroMan (1); gigaconcept.com (1); Howetwo (2); ozzb (1); PWSlack (1); sidevalveguru (1); thrudd (1); Vulcan (1)
You might be interested in: Lighting Fixtures, Ballasts, Spectral Lamps
