Previous in Forum: MBR(Membrane Bio Reactor)   Next in Forum: Shower tile
13 comments
Windows 2000 Pro
12/26/2007 9:49 AM
I bought a used computer that has windows 200 pro installed on it when I got it home it has a password on it and it looks like it was set up to be part of a business network.
Does anyone out there know of a way to crack the password or get around it?
I do have a 200 pro install disk but it will not boot from the CD is there a way to force the system to boot from the CD instead of the floppy drive? Help!! Thanks.
Good Answers: 97
Re: Windows 2000 Pro
12/26/2007 10:20 AM
Press delete when the system is switched on. This will activate the setup menu where you can set and activate the CD as the first boot drive.
12/26/2007 9:29 PM
I've had great success re-writing the hive with this utility cd:
http://ebcd.pcministry.com/
Good luck
12/27/2007 5:18 AM
If the PC is so old that you cannot alter the BIOS setup (you did not mention as to whether you could access the BIOS or not) to allow booting from CD, then you need a boot floppy from say Win98SE, with a CD driver that will allow any CD to run.....
If the BIOS has a password that you do not know, just remove the battery link or the battery on the main board for an hour or two, then the setup password will be gone....on some boards you need to place the link in another position for it to lose the settings....
Format the disk and then install Win2000.
You will need to identify the main board on the internet and download the drivers....from another computer, not this one......never ever go on the internet without having full anti-virus and a working firewall.....especially not if you mean to use Win2K again!!!! Win2K is not to be recommended for going online anymore......
WinXP Pro is the ONLY OS that is worth having from B.G. .....
Good Answers: 15
12/27/2007 6:44 AM
[quote=andy]WinXP Pro is the ONLY OS that is worth having from B.G. .....[/quote]
only if you are a fan of MS.....
MANY linux distros can and do run circles around all MS products.
If th programs you are planning to run are ported to linux/unix, you would be $$ ahead to look into this!!
If you don't have time to do it right the first time, when are you going to have time to do it over?
12/27/2007 10:40 AM
You may have read it wrong, what I was saying is that every other OS from MS is rubbish, either too old or too new.....
I would like to use Linux or similar, but the softwares that I use are rarely available for such operating systems or exceedingly expensive. It would cost me maybe $15,000 in software costs alone today to change......I do not even think about it.
I have used Macs professionally and I can only say that I was completely unimpressed by the Mac OS.....and the lack of cheap good software (in some specific areas) for either Macs or Linux........a modern Mac machine with both OSs might be an alternative....
I do not like the marketing techniques of MS (or Intel or Sony for that matter!) at all and I usually buy my operating system when it is 3 years old or so and well tested by the customers......my last company did basically the same.....
Bill gates will not get me to change when he would like, never has and never will.....I may stay with XP till I am in my dotage or under the turf!!! 2015 is the EARLIEST date that I will change planned for the moment! Like it or lump it Mr B.G........!
I only have an Intel Laptop(last year AMD was a little too far behind in performance in Laptops!), all my other PCs (3) are all AMD based, a company that puts its money where its mouth is and supports its customers through thick and thin.....I have never had an AMD PC go down, but I get often PCs from friends (all intel) to repair from time to time, but never an AMD!! (Recommended by me to other friends for a long problem free life!!)...
I am biased!!! But not racist......
Good Answers: 15
12/28/2007 7:36 AM
Ok, I agree, now that I understand what you were saying. Sorry for the misinterpretation.
I too am stuck with having to use B.G.'s products for quite a few apps. Seems like Autodesk refuses to even consider porting their products to Linux, along with multiple other big name software producers.
The dual boot routine gets a workout on my box! (now if I could figure out how to run autocad et al under XP in Wine..........
APIX Pilot Plant Design Project - Member - New Member
12/28/2007 9:23 AM
There are several big name Engineering applications, Autodesk being the biggest, that are refusing to go Linux (Unix - or whatever nix). They are also very greedy as well. Take the case of autodesk and you will see their software has been used to make some major animated movies. Autocad is, by (so) far, the top of the line for engineering graphics and project management, but their are facing increasing competition from the open source community. Just as Linux is rapidly gaining on Microsoft, open source is rapidly gaining of all of the overpriced proprietary software. The $15,000 price tag for Andy Germany's software is far beyond reason but is required in today's Engineering climate. Most all engineering specs require the .dwg/.dwx format and some ever require the .doc format, forcing us to go Microsoft. This is very much in violation of the spirit of the court settlement against Microsoft and is the real reason Microsoft and Bill Gate became the most wealthy. However, I do believe Microsoft shot themselves in the foot with Vista.
chtank
12/28/2007 11:39 AM
I take great offense at the statement you made which was:-
The truth is really much worse - they shot themselves in BOTH feet, shortly after they had fitted both of them, at the same time, in their Corporate Mouth !!!!
These statements would not have been so true if they had not done such a good job with WinXP.......then we might have been more happy with Vista.....!! Have a great day in spite of me!!
12/27/2007 10:19 AM
So you bought an old computer? So what, I have an old Dell Dimension XPS D33 that at one time I ran WIn95, then upgraded to WIn98se, than upgraded to Win2000pro. Today, it runs Ubuntu 5.04, a Linux operating system. But before I installed Ubuntu, I ran several Linux LiveCD distributions on it. One thing that running, or installing, Linux does in dual boot with Windows is that it allows you to go to "My Computer" and look at all the files on both the Linux and the Windows operating systems. Thus, you can see what is on the hard drive even if you cannot use it. Any company that sells or throws out its old computers are downright stupid if they allow a computer with a client's personal information still on it, they should remove any such hard drive with that information and destroy it.
Also, you do not say what processor, ram, hard drive, etc, this machine has on it. It may be too old to be of much value or it may be one that was upgraded to have a fast processor of 2.8 Ghz, 500 meg or more of ram, and many gig of storage. This does make a difference in what operating systems you can use effectively. In any case, I would not try to break the passwords and would find the appropriate Linux desktop operating system and do a complete install. Forget trying to use any of the existing software, it is all proprietary and will require you to license it. Linux open source software is readily available and is rapidly being upgraded to beyond the quality of any Microsoft operating systems or applications. To find the software LIveCD's you may want to try, go to ON-DISK. There, you will find all the LIveCD's available, including open source, Windows and Mac.
As low a cost as computer parts are today, I do not understand why one would buy an old machine rather then building their own. It is easy and you know what you are getting. BTW, if you recall, I said I have upgraded an old Dell 486 machine with Ubuntu, guess what, it is the very machine I am using to type this reply to you. You see, my motherboard to my primary machine went bad and I am replacing it with a new 64 bit X2 Dual Core with 2 gig DDR2 ram. All for less than $300. This old Dell will then "test" Tiny and/or SAM Linux and continue to serve as my second backup Linux machine. I will never again use Windows. Linux is simply that much better and the applications are as good as, if not better than, anything Microsoft has to offer and is continually being upgraded, all free of cost through open source.
chtank
Good Answers: 117
12/27/2007 10:49 AM
I didn't know that you could even obtain a dual core motherboard to replace the one in the computer. Thats good to know....so I could just get my local computer repair shop to yank out the old 486 and stick in a new motherboard. Who knew!
As far as the OS debates are concerned, they all sound too much like "Ford is better than Dodge...No! Japanese cars at the only reliable cars". It has been my experience that MS windows on this old IBM motherboard has been pretty much bulletproof. (It was years before I got the "blue screen of death", for instance, and I didn't know what the fuss was all about! Still don't! Everything seems to run on it just fine.)
I was only this month thinking about upgrading because my old Win98 is no longer being supported...understandable I guess, neither is my 98 Ford van!...and am fascinated by the idea that I could pick up an old junker of a computer and soup it up to run with the best!
Thanks for the tip.
Bill
12/27/2007 11:07 AM
I would say that its still better to buy a new (or build one from parts) computer, otherwise you may have problems due to the power supply, especially if you upgrade the Motherboard.....even with a new motor, an old car is still an old car......
I build my own always from selected parts, it is not the cheapest way, but the results are worth looking at.....I then let them run for about 3 years. The last time, I kept the box as it is 90Cm high and has room for 6 hard drives in easily removable units, good cooling etc.. But I changed everything else including the PS which is now 550 watts and has temperature controlled fan cooling......
AMDs have better temperature tolerances and shut themselves down if something breaks.....with help from the main board of course......
I like MSI main boards as their support center is in Frankfurt and they have actually invited me to visit once when I had an install problem with their board and an AMD X2 64 bit CPU, they fixed the problem immediately and no charge!!! I had made the problem......Nice people at MSI Germany!!!
12/27/2007 11:43 AM
Yusef1, you are in Canada, so you should have no problems with obtaining USA computer stuff. I did my shopping homework at Microcenter in Houston, Texas. I have lost faith in Fry's Outpost. You can search online for all your computer stuff, including bargains for new and refurbished computers with Mac, Windows, or Linux (freeBSD) installed. I like Microcenter because I can put my hands on it.
As for rebuilding old computers, one has to know the case, too. If it is older than a ATX case, forget it, they are too old and beyond salvaging. For my primary machine, I have selected a Asus M2N-E nForce 570 Ultra AM2 ATX Motherboard 2 $125, AMD Boxed Athlon 64 X2 Dual Core Processor 4000+ Socket AM2 @ $62, Processor Cooling fan @ $10 with $2 rebate, and 2 gig DDR2 Ram @ $62. The total for these parts is $259. Then I have as an option a 19" wide screen LED monitor @ $160, taking the total to $419. As for the rest of the parts, I have all that I need plus the DVD rom and Floppy drives already in the box. I have not found any ready made computers of this type anywhere for anywhere near this price. we actually do not know enough about this Win2000pro machine to know what options are available.
chtank
Good Answers: 140
12/27/2007 10:59 AM
If you do not want to go to the bother of re-installing the OS, there are many good password utilities available for download for a fair sum on the Internet that will allow you to change the startup and the administrator password. Go to Google and search on "Password Changer".
If its not the OS user password and the BIOS one instead, power the box down, open it up and remove the CMOS battery, let it sit for an hour then put the battery back in. You will have to reset the CMOS settings, but as the motherboard should come back up in its default settings mode it should work fine.
Andy Germany (4); bonsaicult (1); charlie_r (2); chtank (3); Hendrik (1); North of 60 (1); Yusef1 (1)
You might be interested in: Waveguide Pressure Windows, Windows, Infrared Windows
