Previous in Forum: Engineer   Next in Forum: Shear Stress Measurement for Bolt
simple
02/05/2008 6:34 AM
in how many ways ellispe can br drawn
Re: simple
02/05/2008 6:59 AM
Two - CW and CCW.
Can you please explain more about what you want to know? Are you talking about drawing with paper & pencil? Easiest way (and the only way I know, apart from plotting the co-ordinates from the equation & playing join-the-dots) is 2 drawing pins (thumbtacks) and a loop of string.
Good Answers: 97
Re: simple
02/05/2008 7:11 AM
Horizontal and vertical and anything in between.
A CNC machine and a plotter can do a nice one.
Long ago they used mechanical integrators.
I am not sure but I think a "trammels" can be used as well.
http://www.sciencemuseum.org.uk/images/I032/10302774.aspx
Re: simple
02/05/2008 9:33 AM
Say it were a stone bridge arch, for example. The tutorial, pencil-and-paper, method of doing it is as follows:
  • draw a horizontal construction-line between the upper faces of the two springer stones.
  • Mark the centre-point of this horizontal line.
  • draw a semicircle in construction-line, touching the two springers of the arch and perpendicular to the upper faces.
  • draw another, smaller, semicircle in construction line that just touches the underside of the keystone.
  • Draw radii from the centre every 10deg or so in construction-line so that they intersect the two semicircles.
  • Where each radius intersects the inner semicircle draw a horizontal construction-line contained within the space between the two semicircles.
  • Where each radius intersects the outer circle, draw a vertical construction-line contained within the space between the two semicircles.
  • Where the verticals and horizontals intersect is a point on the semi-ellipse. Mark the point in bold-line, and join the dots with either French Curves or Flexi-curves.
  • Rub-out the construction-lines.
Job done.
Eat yer heart out, AutoCad!
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: simple
02/05/2008 9:58 AM
Hammer in two nails a desk. Not completely.
Get a thread which length is longer than distance between nails (nails represent your ellipse poles).
Tie both ends of thread to nails.
Stretch a thread by means of pencil.
Having thread constantly tight draw an ellipse with care.
Yes, you can do it both ways CW and CCW.
Re: simple
02/14/2008 12:34 AM
I learnt this 65 years back.
When/who discovered this?
Re: simple
02/16/2008 7:33 AM
I was taught and even demonstrated this method by my math Prof 25 years ago. And he didn't pretend that he was inventor of this.
Register to Reply 6 comments
Anonymous Poster (1); caramba (2); Hendrik (1); JohnDG (1); PWSlack (1)
