Previous in Forum: Which Is Better ... Radiometry Integrating Sphere or Radiometry Detector Head   Next in Forum: Biosafety Level-3 facility- Prefab Vs Conventional Construction
44 comments
Fuel Saver (diesel only)
02/19/2008 10:58 PM
My company has perfected a diesel fuel saver that can help saves upto 50% we have tested the product (we named it Nh2 Fuel converter), at this point in time 2 units are being operated in the Philppines' small power utility group premises (SPUG-NPC) on a 700KVA diesel fuelled power generators running at 300KW load, as per record (to date) fuel consumption is reduced to 42%. However I am finding difficulties to find a fuel change over soleniod valve that will automatically bypass the fuel to normal flow if ever my machine fails. Another thing is that I am in need of a very accurate flow measuring device to measure up the forward flow and the return flow of diesel fuel to and from the generator.
Can any one help?
Carbon Technology
Pathfinder Tags: fuel saver
Good Answers: 230
Re: Fuel Saver (diesel only)
02/19/2008 11:21 PM
Hello Andynh2
Send me one of those "up to 50% diesel fuel savers".
I shall install it into my 1986 Toyota LandCruiser non-turbo 3.4 litre engine as made by Hino truck Co for Toyota, and run the unit on-road and off-road for 50,000 miles, over various terrain, various altitudes, various climatic conditions, then issue a comprehensive report on the unit.
The report will be sent to you, along with a copy placed here on CR4 Forum, for all to enjoy.
If your unit is truly excellent, I look forward to the comprehensive testing.
Kind Regards....
02/20/2008 3:30 AM
Friend,
I am so sorry to tell you it won't fit your car the dimension is 110cm X 90 cm X125 cm. running at 240VAC
it is the comercial model, the smallest I can go.
It is designed to cater small power plant it is a stationary machine,
Sorry friend,
Car or mobile model I still can figure it out. I can send you pictures if you give your e-mail
Andy
Carbon Technology
02/20/2008 1:25 AM
Sound like an additive such as H20, as experimented with on gas turbines? and may require the engine rev's to be kept up? that I think would rule out the Ute? If the system needs purging then maybe twin injectors may be the way to go? I wish you well and good luck in your endeavours. I think there is a induction coil that can be placed around a fuel line to read flow, I saw it a long time ago cant remember the details.
Regards JD.
02/20/2008 3:42 AM
Dear Sir,
Thank you for your comments. perhaps you can help find a supplier of a shut-off valve that works automatically, either dc volt operated or ac volt. motorized or solenoid, 3/4" port or 1" port size.
Thank you again
Andy
Carbon Technology
02/20/2008 11:00 PM
Researching and testing a fuel saver device is much more complex than finding or searching for a shut-off valve.
Canada - Member - New Member
Good Answers: 11
02/21/2008 9:11 AM
A good shut-off valve can make you save 100% fuel!!!
02/21/2008 5:11 PM
Try the ASCO solenoid company.They make many types of electric solenoid valves.What you need is a 3 port, normally open to one port, normally closed to the other, with one port common.You can configure the ports for your needs.Energized is normal, deenergized is backup, or just the opposite.
As far as flow measurement, a turbine meter with external inductive pickup will work.As the turbine blades rotate, they alter the magnetic field of the pickup unit, creating pulses. Signal amplification and scaling can be done with your computer.Many compnies make this type of flowmeter.
I would be interested in seeing a drawing of how your system works, if it will not compromise any proprietary information.You can send it to my email address, or here.
Good Answers: 97
02/20/2008 5:23 AM
Hi Andy
We are sort of allergic to impossible claims of fuel saving. A claim of 58% saving is bound to raise a question.
Your saving seems to limit the fuel supply to the load. Running a 700KVA at 300KVA should result in at least 42.8 % energy use.
Your real question - The supply of fuel change over solenoid valve got lost in claim.
02/20/2008 8:52 AM
Sir,
I haven't reach the 58% level yet, only 42%.
you are absolutely right. however we have the recorded data, sent to us by our field engineers.
Actually the fuel saving is not done by simply restricting entry of the fuel to the host engine, there is a technology behind it.
The name of the machine dictates that the fuel is converter to a new form of fuel, thus giving the primary fuel a new characteristics making it efficient.
At the moment our website is underconstruction, I will post it as soon as it is ready for viewing. www.nh2nichevision.com, mean while can you help me find a supplier of a 2 way shut-off valve electrically operated either by solenoid or actuator 1/2" or 3/4" port.
Thank you
Andy
Carbon Technology
02/20/2008 1:24 PM
Oy ve. When this gets finalized, I'm sure with a little engineering and tweaking, this should be able to save an additional 10 to 20 %.
02/20/2008 1:54 PM
I have not been able to find any information on what your generator is actually adding or doing to the diesel. The only reference I can find is regarding adding urine to the diesel (that doesn't sound right at all thou ).
There are plenty of companies that can supply electrically-operated solenoid valves that should do the trick, and they should also do changeover valves but you will need two of them to isolate your generator (I think based on what you have indicated). If you could give us an idea on the diesel pressure and chemical makeup of the modified diesel coming out of the generator that will help in specifying the right kind of valve with the correctly rated seals and o-rings.
A little more information would help. Does your generator not have a straight-thru labyrinth fuel flow arrangement? What's the additive?
Why do you need to do this? Can't you just monitor the output pressure of the Diesel going to the load (generator in this case) and adjust a valve to keep it constant?
As I said before, more information is required as we see quite a few of these sort of devices come thru, and they are generally free-energy scam or hopeless backyard inventor devices that don't work (so you can imagine why some people are posting sceptical comments ). At the very least keep me informed as your device interests me (part of my job is in power transmission and distribution R&D afterall), so much in fact that I am going to ask again, could you please provide more information and perhaps a bit of history on the development and operation of this new device (pictures and diagrams perhaps).
Thanks.
Good Answers: 183
02/20/2008 4:45 PM
1- The valve you try to get. The dimensions are quite important. If the pressure or/and the pressure drops are important you will be obliged to use a 2 stage valve. Basically you can use a cartridge which is common in high flow hydraulics. I think that usual seals will be ok if not (temperature too high) you can go to Viton or even more exotic materials. Look at Bosch Rexroth Vickers which are the most important manufacturers and available almost all over the world.
2- For the flow measuring the problem is the flow magnitude. With available systems (Kracht and others) it is possible to obtain VERY high accuracies. For example it is possible dynamically to determine the leak during the travel of a piston.
Such devices are in fact gear motors with an electrical pick up for every tooth passing by the sensor. Their very low own friction makes internal leaks almost nil.
Let me know if you need more support but if you need more data are to be supplied as flows and pressures. It would also be good to know how small should be the reaction time of the valves.
02/25/2008 7:26 PM
Thank you for your help
Andy
Carbon Technology
02/20/2008 10:59 PM
www.floscan.com for the fuel flow metering
Good Answers: 247
02/21/2008 1:24 AM
If we assume a power factor of 1 for a second to get a feel for what sort of fuel use reduction you are achieving, we'd expect that in going from 700KVA to 300KW, the fuel consumption would drop (by 57%) to 43% of that at 700KVA. Is that what you are saying?
I'd suggest Global Spec for the fuel valves and flowmeters.
02/21/2008 3:01 AM
Hi Andy,
Please tell us the power in KW generated per litre of Diesel before and after the installation of your Nh2 converter. This will help us know exactly the magnitude of your claim and clear our doubts. Thanks.
02/25/2008 7:25 PM
Thank you for comments,
based on the recent field report that I have just received Our machine can raise the kw/liter of the 700KVA generator running at 300kw load by third fraction and even more the normal output which is 6.3kw/liter from 3.4kw/liter.
As per claim by the user their normal fuel consumption is 120-150 per hour based on their sounding, with Nh2 running to assist the generator on fuel delivery consumption drops to 76 liters/hour based on flowmeter.
This power generators are quite old, (Dale Perkins)
If you would be kind enough to send me your e-mail I will send you copy of the report.
Andy
Carbon Technology
03/26/2008 2:15 AM
Andy
Hi Andynh2,
Can you kindly send me also a copy of this report and picture of the Nh2 unit? Email it to: mikatnam@yahoo.com. How long is this being tested in the Philppines' small power utility group premises (SPUG-NPC)? Does this SPUG-NPC already purchased your unit?
Hoping for your reply.
Thanks,
Mike G.
02/21/2008 3:25 AM
Dear friend hello I am Mr. A.C.Zervos Greek nationality
My email is zervostassos@hotmail.com
I have as well been experimenting lot on fuel efficiency systems and as well in alternative fuels and efficient power generation
I have aircraft engineering as background studies and I have involved in plastic packaging production and other industrial lines and utilities
Coming to you enquiry for assistant I thing from what you mention there is a solution using special nozzles coming from Germany for diesel engines that are for converting diesel to natural gas without the use of spark plug
These nozzles are using the current system of diesel from 10% to 100%
1) Opening gate valve to the input of the natural gas (is where you can have your fuel input instead of natural gas)
2)10% to 100% diesel is adjusted automatically and mechanical from the nozzle system depending on the capacity of the fuel in the second point (natural gas)
The only thing you are replacing in the diesel engines is the nozzles and is necessary to supply the inputs in the nozzles with the secondary fuel (natural gas or your fuel) with pressure sustained as common rail fuel systems
A.C.ZERVOS
Good Answers: 54
02/21/2008 7:23 PM
Do you have an Australian cousin called AC Servo? ffeJ
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
02/21/2008 4:35 AM
Dear Andynh2 ,
We congratulate you for your invention of Diesel saver . Can you give us the details so that we can use it in our gen set of 1250 KVA rating .This is definitely going to help us .
aks
02/21/2008 7:32 AM
I want one for my 06 Harley, electra glide classic, to test also.
02/21/2008 8:20 AM
You have a diesel Harley?!? This I've gotta see! What's your location?
02/21/2008 8:26 AM
Dear Sir,
I have already passed your quest to a group of engineers who most certainly will give you a solution to your issue in dealing with Diesel flow mweasurements.
We are also interested in knowing your product Nh2 fuel converter as we may want to find applications in USA and Latin America.
Look forward to hearing from you soon,
Antonio Noriega
VP Marketing & Sales
02/21/2008 8:38 AM
Please forgive me if I'm mistaken. A company that has developed this global changing device can't select a solenoid valve and flow measurement equipment? Even if "your company" is not able to do it surely your "field engineers" could! If I'm wrong please press on to fuel savings!
Everything I know about opera I learned from Bugs Bunny
Good Answers: 54
02/21/2008 7:20 PM
Spot on, but at least they're not asking for investors. ffeJ
02/21/2008 10:30 AM
Hauck mfg out of lebanon,PA has some of the best fuel conctrols Ive see ,and can handle extremes ,temp, viberation, dirt ect.I know from my own exp. on a twenty million btu burner. Good luck ,JMK W Fgo nd
Good Answers: 230
02/21/2008 3:53 PM
Hello jamesmkieffer
Just helpful advice to you.
I would cut down on the texting.
It has affected your spelling and punctuation.
Kind Regards....
02/21/2008 11:44 AM
If there is an engine driven, or electrically driven, supply/lift pump on your engine (which in my experience there almost always is) I would tap the pressure between this pump and the primary/engine mounted fuel filter. Direct this working pressure to a normally closed hydraulic type selector valve. In the event of failure to your "machine" supply interruption would cause a pressure loss, thereby allowing the spring pressure to open the valve to the alternate fuel source (assuming that the supply at this point in your system is of negative pressure). If the alternate source is pressurized then the engine "tap" would be utilized as a pilot pressure to control your valve.In my experience the quantity of fuel contained in the filter or filters is sufficient to maintain operation of the engine until the alternate source is established. You may find that you will need to increase the primary filter size to insure that you do not experience fuel starvation.
As for flow measurement, I would seriously consider using a Floscan diesel flow meter. I have installed many of these and found them to be highly accurate and reliable. http://www.floscan.com/html/blue/generators.php?gclid=CPi18IDS1ZECFRkGagodMniaZw.
This set up should not be very difficult to accomplish.
Good Luck,
Dragonfly
P.S. I saw a post some time ago that lined out the method for inserting graphics, but I did not save it and now can not remember the procedure. I have a very simple schematic of how I would do this that was quickly accomplished using AutoCAD. If my idea is unclear contact me and I will forward the drawing to you.
Location: Somewhere in the hills of Pennsylvania, I think.
02/21/2008 12:05 PM
This is an excellent idea, that is, to use the fuel as the hydraulic medium to operate a valve upon pressure failure in the primary fuel system.
Also a good idea to use floscan instrumentation instead of trying to "re-invent the wheel". These boys have been doing fuel flow for quite a while and are the de-facto standard in the marine diesel fuel flow instrumentation arena.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Good Answers: 114
02/22/2008 4:02 AM
02/21/2008 11:46 AM
Dear Andy,
We are also working on improving the efficiency of big diesel generator sets but not by modifying the fuel system. We work in the 1-5 MW range for distributed power generation. Please send me some more information about test results, principle of operation, cost. If this works I'd be happy to use it and distribute it in europe.
Best regards,
Randolph Toom
Kind Regards, Randolph Toom - www.heat2power.net
02/25/2008 7:41 PM
Dear Randolf,
I would like to made clear that we do not modify the engine, or the fuel system, our machine has nothing to do with the genset engine other than delivering the fuel,
However much of the modification thing are being done to use other type of fuel to a diesel engine are not succesful because there is no real substitute to fossil fuel at this time,
Hydrogen is not a combustion fuel as I understood it, for fuel cell yes it is fuel, but for other apllication I would say it is a energy carrier. it is in this simple principle our technology gave birth to Nh2 fuel converter.
If you will be kind enough to send me your e-mail, I will send you copy of the field report.
Thank for your conment
Andy
Carbon Technology
Good Answers: 114
02/25/2008 8:38 PM
Please tell us more. We're all interested in real solutions that increase efficency.
02/21/2008 3:30 PM
HMMM... Very interesting. Are you sure about these 50%?
Anyhow, what you need is easy to obtain, If I were you I would use aircraft type fuel flow indicator PLUS fuel pressure indicator, and have them connected to a data logger. The more sophisticated ones have this option already installed, and the simpler ones will need to modified, a piece of cake for someone who knows what he is doing in electronics. I would use a vain type flow meter as they all are generator type and will be easy to modify them to be connected to a data logger.
Now as to auto shutdown: you need to use a fuel change over mechanism that will be actuated in case one of several predetermined thresholds is reached. these could be the fuel flow and pressure, current consumption under a certain load, voltage regulation excitation voltage etc. and of course the regular auto shutdown in case of low oil pressure or excessive oil temp. etc. not a big problem. Again look at aircraft emergency or fuel management solenoid fuel valves. This can be easily be obtained by using two (2) one-way solenoid valves one is normally open, connected to the Nh2 the other is a normally closed connected as by-pass directly to the fuel pump. this is cheap compare to a change over valve.
Once you finished, I want to be your exclusive world distributor....Well, maybe not worldwide South America alone will make me a millioner, and that's good enough.
www.shadin.com and than click on "Digiflow". Hope it helps.
Wangito.
Never trade luck for skill.
02/25/2008 7:47 PM
Dear wangito,
Thank you for the suggestion on the auto shut off valve , it works, Please send me your e-mail so that I could send you the picture of the piece of work I have done base on your suggestion.
Andy
Andy
Carbon Technology
02/25/2008 8:44 PM
Hello Andy,
Glad to be of help.
You can E-mail me at wangito@gmail.com
Cheers, Wangito.
03/06/2008 10:04 AM
Andy,
Am still waiting for your pic's.......would love to see them
Wangito.
wangito@gmail.com
02/22/2008 3:42 AM
It sounds great. Please keep me informed of developments.
Mostafa El Shamy
mokash@tedata.net.eg
02/26/2008 12:18 AM
I would like to use for our diesel genertaors sets. Any contact is appreciated.
Shivaram
Cadbury Bangalore
+91-9845756340
email- shivaram.prasad@ap.csplc.com
Best Regards, Shivaram
02/26/2008 12:34 AM
Also please inform KWH/Liter before and after. If makes sense we can use it across.Your immediate reply is highly appreciated
Shivaram
+91-9845756340
02/26/2008 8:30 AM
Look into Tokyo Keiso Flow meters, (malema in the US). They offer a full range of flow meters including ultrasonic meters for difficult liquids.
03/06/2008 7:04 AM
It is very encouraging to know this type of product. Can you mail address of company who is supplying this product.
parveen
parveenksoni2yahoo.co.in
03/23/2008 10:15 AM
Dear Friend,
The company is Niche Vision SDN BHD Malaysia, #16 Jalan IND PBP3 Taman Industri, Pusat Bandar Puchong, Selangor, 47100 Malasia. Tel No. (603)5891 0366; 2092 2836, Fax No. (603) 5891 0367, Contact person Dato" K.K. Sharma, CEO
Thank you for your interest.
Andy
Carbon Technology
Register to Reply 44 comments
aks (1); Andynh2 (8); Anonymous Poster (6); Antonio Noriega (1); Blink (1); catman (1); DaveB (1); Dragonfly (1); EnviroMan (1); ffej (2); FKIA (1); Garthh (2); gigaconcept.com (1); Graebeard (1); Hendrik (1); jack of all trades (1); jamesmkieffer (1); jdretired (1); k.v.gopalakrishnan (1); melshamy (1); Mike G. (1); nick name (1); Randolph Toom (1); shivaganti (2); Sparkstation (2); wangito (3)
You might be interested in: Fuel Testers, Fuel Cells, Fuel Additives
