Previous in Forum: Bailey Bridge   Next in Forum: Audit of (Engineering Designs Consulting)
Expansion joint
03/24/2008 9:53 AM
Hi,
What is the difference between: elastometric expansion joint, strip seal expansion joint and filler joint?
Thx
When you want to do something good, do it, don't hesitate maybe it's your last time to do some thing!
Re: Expansion joint
03/24/2008 5:21 PM
If you had not stated you were an artist, I would have guessed it from the weird question.
These three things are not even related according my swift google search so how did you want to compare them?
http://www.johnsonpackings.com/expjoints/elastexj.htm
http://www.techstar-inc.com/pub/Strip_Seals.shtml
http://www.british-gypsum.bpb.co.uk/products/plasterboard___accessories/gyproc_accessories/gyproc_joint_filler.aspx
One is for pumps and valves, one is for bridges and the other one is a diy product for plaster boarding.
Unless google is wrong on all three accounts
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
Re: Expansion joint
03/25/2008 5:26 AM
Hi, artist!
Welcome to CR4. Dr. Marshall McLuhan used to say that the artist who portrays his/her times portrays reality in history, and in the sense of observer and portrayer has value as the only true historian. He allowed for those artists who had an axe to grind in one sense or another; but he was speaking of simple pastoral themes.
It's a pleasure and an honour, whether or not you are an artist, to have you aboard. Stick around, have fun, and shine light in here where you are able.
Re your question. You noticed that Case491 rapidly was able to give you information and references after having used Google to find them.
I have recommended search engines such as Google to inquiries in here so often that they should be paying me a salary by now. The point is, it's simple to use search engines and you could have undertaken that simple exercise on your own, using CR4 to fill in the gaps for yourself.
I agree, however, that using a search engine is not as much fun as waiting to see what kind of response you'll get..especially if it's slanted differently from the one you found for yourself.
All the best,
Mark
Re: Expansion joint
03/25/2008 8:25 AM
First of all they are much different material. The standard filler specified by most civil engineers is one that is used by the highway departments. it is the cheapest thing they could come up with and is made of a woody fiber soaked with a bitumunous tar. It will mostly rot away and serve no purpose in about 5 years in any climate not in a desert. There are several other types of expansion joints. Most of them use a "backer rod" or "backer material" made of foam. This is simply something to stuff into the hole. They are then filled with different types of elastic materials. Some of there fillers are made of silicone. These are the ones that weather black and ussually that is not really noticed. The silicone is mostly used because it lasts longer. There are many other types of fillers. For a lasting residential expansion joint often I will use redwood for the forms. It lasts a long time and it weathers to gray that matches plain concrete.
Good Answers: 12
Re: Expansion joint
03/25/2008 6:12 PM
Lets not forget Wikipedia too. I have followed links provided by other CR4ers and learned some fascinating stuff. That place could be more addictive than CR4.
I also say welcome to CR4, but beware... we occasionally get a wee bit silly, and some times down right hilarious. But it all in good fun.
Sincerely
Bill
Re: Expansion joint
03/26/2008 12:51 AM
MISTER Guru!!
Re: Expansion joint
03/25/2008 8:40 AM
They are all to be used for different uses. One is for one use, the other for another use, and the last for a different use....
Register to Reply 6 comments
Anonymous Poster (1); case491 (1); jrpeck (1); MarkTheHandyman (2); Sciesis2 (1)
