Previous in Forum: Suitability of Two Power Supply   Next in Forum: GIL Vs GIB
36 comments
Wind Force Replacement in Wind Mills
04/22/2008 1:21 AM
Its interesting to know anyone is seriously considering high priority to incorporate an alternative force substitute to replace WIND as the primary soruce in el.generation by WIND MILLS!
Good Answers: 97
Re: wind force replacement in wind mills
04/22/2008 4:31 AM
I was considering water but found out that it could not be called a wind mill any more.
There are strong and persistent ocean currents all over the globe. Turbines could be placed there and a lot of electricity can be generated.
One (exaggerated) concern is that with enough turbines the water temperature will drop slightly which may affect the driving force of the current and create different flow patterns. As seen with El Nino (which seem to influence the weather in Africa) the effect can be devastating over large areas.
Good Answers: 243
Re: Wind Force Replacement in Wind Mills
04/22/2008 10:45 PM
We could make big honkin jars to drop over them... and then paint one side of the blades black... and then let them run on sunlight...
in the day time any way.
milo
04/23/2008 6:58 AM
Perhaps the thread starter is suggesting that windmills (with their more blades and slower speeds have more torque) could be coupled with gear reducers (hooked in reverse to actually be a gear increaser) to provide the force. Since there are more 10 mph winds than 25 mph ones, what do you think? Of course this scenario will have to overcome more frictional losses. Don
Western North Carolina...Veni, Vidi, Velcro...(I came, I saw, I stuck around)
Good Answers: 204
04/22/2008 11:03 PM
your post is not clear what you are trying to say. please clarify.
04/22/2008 11:50 PM
"Its interesting to know anyone..."
Who is this 'anyone?'
BTW the post falls under the classification of BS when posted by anonymous Guest.
WAG -- Did you mean flatulence to substitute for wind.
04/22/2008 11:55 PM
it won't be called Wind Mill anymore then.
B +ve
04/23/2008 12:42 AM
I can show you how to turn the shaft by gravity, but then you would have to call it a gravity mill
04/23/2008 1:02 AM
"I can show you how to turn the shaft by gravity, but then you would have to call it a gravity mill"
So.
Show me.
If you can.
04/23/2008 2:07 AM
Well, how about this one?
http://www.seageneration.co.uk/
"It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong." - Richard Phillips Feynman.
04/23/2008 3:13 AM
Why not stay with the wind idea, but plant lots of large trees nearby. Now thats really green power.
As we all know, when the trees are still, there is no wind, but as soon as they start to flap their branches and leaves, the wind appears...so there. Free.
More trees = more wind.
Oh stop it!! Now you're being silly
When exercising, remember that walking on a treadmill gets you nowhere, but using a trampoline has it's ups and downs
Good Answers: 243
04/23/2008 9:38 AM
Not so silly.
When there is no wind, we could have an arsonist ignite the trees, causing local convection currents to turn the "windmills" (Actually windmills convert wind energy into mechanical energy directly; wind Generators turn wind energy into electricity).
At any rate, just like the lake behind the damn is a reservoir of reserved kinetic energy, so too can your brilliant plant trees idea be seen as a reservoir of stored convection currrents.
Brilliant!
milo
04/23/2008 3:49 AM
How about water?
Hobbies - CNC - New Member
04/23/2008 4:57 AM
I am considering using a combination of sun energy (heat) and wind.
This would eliminate wind quiet periods.
Johan van Niekerk
Good Answers: 11
04/23/2008 7:04 AM
If you filled the wind mills with pepper, no passing Italian waiter could resist giving such a huge peppermill a really good grind.
I am leaving this as on topic as the question is demonstrably off, so therefore this by definition is on..................I'm going to lie down quietly.
Simon
horsepower measures work, ponypower measures pleasure!
04/23/2008 5:26 PM
A peppermill that big is gonna generate a heckuva lot of sneezes, which while still air, is not technically speaking, wind, hence - the advent of the SNEEZEMILL! (achoo!)
Good Answers: 11
04/23/2008 6:11 PM
I'm slipping badly, I missed that one, but since this is clearly an organic thread, I must point out that my suggestion was based on grinding green peppercorns.
Simon
04/23/2008 8:29 AM
How about a giant wheel that you could put squirrels, or hamsters into...
Good Answers: 204
04/23/2008 9:08 AM
my running wheel story.
Many years ago, when I was getting a new puppy, and I lived in an apartment, I decided I would build him a running wheel. It was 4 feet in diameter, made from a sheet of plywood, had 3 spokes.. and I put 1/4" galvanized mesh as the running surface.
For reasons known only to God, the puppy (purebred samoyed) insisted on pooping on the 1/4" mesh, every time he was put in... and then of course ,to run like the devil, which had the effect of dicing the poop through the mesh, and flinging it in a wonderful demonstration of centrfugal force.
another failed invention. ha ha.
Good Answers: 243
04/23/2008 9:33 AM
Love it!
milo
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
04/23/2008 9:07 AM
sorry, but I have to ask..... HUH???
-why bother doing it wrong when it will be anyway.......
04/23/2008 9:48 AM
Here, here. I didn't understand the question no matter how many times I read it.
Good Answers: 243
04/23/2008 9:54 AM
Than go up to vote on post number 3 and vote it good answer, the original poster declared it off topic, apparently not enjoying the keen critical insight of a horribly worded question.
I did.
milo
Good Answers: 12
04/23/2008 10:02 AM
True. Even though I enjoy the interesting quips, the question can not be answered. So the proper thing to state is that more information is required. Or, perhapse, the person could re-word the inquiry.
Guy
Good Answers: 243
04/23/2008 10:07 AM
YEP!
milo
04/23/2008 5:30 PM
No worries, B Sir R, you're apparently in rather large company here...
04/23/2008 10:07 AM
If you are not concerned with a rapid acting "law of diminishing returns", then when the wind quits, you can have the generator supply power to an electric fan blowing on the wind mill thus using the wind mill to supply its own wind!
The "law of diminishing returns" will be very rapid.
Good Answers: 243
04/23/2008 10:13 AM
Actually I think that you'd need to have a battery or capacitor in that system somewhere...
too phunny.
milo
04/23/2008 11:30 AM
Replace the wind with camels or moose on an all bean diet. Place control booth up wind.
Everything I know about opera I learned from Bugs Bunny
04/24/2008 9:12 AM
Dave,
You bring up a very good point. There are those who say that the methane gas produced by cattle is a large component of the greenhouse gases causing our collective temps to rise. Perhaps we should be designing systems to harvest cow flatulence, bottle it and use it to heat our homes, and power our cars. In that way we can reduce the CH4 in our atmosphere.
04/24/2008 11:20 AM
I can see the headlines now:
CR4 Reduces CH4, Saves Earth!
05/05/2008 9:55 PM
I currently work in a beef processing plant, and that is how we power our boilers. The plant finally applied for the carbon credits for the whole deal.
Home is where the heart is!
Good Answers: 12
04/23/2008 11:49 AM
I think I have a real answer for this.
A wind mill can be used to pump water into a tower resevoir. The water flowing down from the tower can drive a turbine to create the electrical power. During windy periods excess water is collected in the resevoir for less windy periods.
Here the source of generation is hydroelectric. Thus the substitute for wind in a windmill system.
Now the question to answer: "Is anyone doing this now?"
Guy
Good Answers: 243
04/23/2008 12:32 PM
Nice job carnac!
You must have disturbed the force to get that out of the original post.
Tip of the hat to you for that. Nice job of getting to the implied.
milo
Good Answers: 12
04/23/2008 12:50 PM
LOL.... years of designing for people who really didn't know what they wanted I guess.
Guy
04/24/2008 11:22 AM
You earned this, I'm told!
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
04/29/2008 5:34 PM
Yes it is.
Surplus power is used to pump water up to hydroelectric dam headponds from below the dam.
Slightly different scale, but same idea.
You can have it good, fast or cheap. Pick two.
Reply to Forum Thread 36 comments
Anonymous Poster (2); bbei (1); Brave Sir Robin (2); capri (1); chrisg288 (2); DaveB (1); davids (1); dkmiller68 (1); EnviroMan (4); gdevine (4); Hendrik (1); jmart23 (1); Johan van Niekerk (1); Jsquared (1); Milo (7); Munky (1); saddlechariot (2); skippy (1); Stirling Stan (2)
You might be interested in: Wind Turbines, Rolling Mills
