The fan on my home AC system is behaving oddly (1/4 hp, 60 Hz). As it runs along it slows down. I can hear the pitch change as it slows, and the air flow goes to nothing. If I turn it off for 10 minutes or so and start it back up, it comes to normal speed, but then over the next 30 minutes or so it slows down again. I can feel the outboard bearing and it is hot, but not too hot to touch so if it is a bearing problem it must be the fan end bearing. Is there anything electrical that could cause this? I will replace the motor and that should fix it, but I am a bit curious as to why it is doing this. Any ideas would be appreciated. Thanks!
