Previous in Forum: 2.4 MHz Antennas   Next in Forum: Coal: Heavy Metal Analysis
Engineering Fields - Mechanical Engineering - I am here to help!!
What is Gravity?
05/08/2008 4:02 AM
Hi,
Last day I was having discussion with my friend about gravity. He asked me a very general question. What is gravity? Where does that pulling force come from? What is it's purpose? Actually why it pulls & not repells? It attracts everything, whether the matter is magnetic or non-magnetic.
I don't know all those basics, so I thought I would consult you.
Thanks in advance.
#82
In reply to #81
Find in discussion
Re: What is Gravity?
05/13/2008 2:12 AM
Surprising! You do not understand the lighter meaning of his post?
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
#87
In reply to #82
05/13/2008 11:39 PM
Surprising! You do not understand the lighter meaning of my post?
I wonder..... Would Schrödinger's cat play with a ball of string theory?
In reply to #87
05/13/2008 11:59 PM
Why are you guys lightening up? This is a heavy discussion.
Good Answers: 40
#85
05/13/2008 3:11 PM
E= MC2
Anything at the speed of light is pure energy
Anything below the speed of light is Mass
Space is full of energy , seen as background radiation, etc.
The higher the speed of an object, the more total energy.
Anywhere there is mass, is basically a "low energy" location.
As space expands, The total energy is spread out, the average energy level at any one point will decrease, keeping the total energy the same.
Entropy dictates that all things will gradually lose energy. It is passed to other objects through collisions etc. All things will move towards the lowest energy state.
Think of a high energy particle flying through space, It hits a mass of objects, most of its energy is passed to the quantum mass. The quantum mass total energy will go up only minutely, but the high energy particle has lost enough energy that it cannot continue on, and becomes part of the quantum mass. The additional energy in the quantum mass could raise a few particles energy so as to change state, yet rarely will it give it enough energy to escape the mass of atoms, particles etc.
A good example is light radiation from the sun. How many particle collisions has happened before it comes to a complete stop when it hits the earth.
It follows all the laws of physics. The lowest energy areas are solids, higher energy are liquids, higher yet are gasses, and after that we have radiation.
Around the planet all the objects, gasses, radiation etc, through multiple continuous collisions are losing energy and being bounced towards lower energy object (earth), until there is not enough energy to bounce off an object. All these particles are pressing down towards the lower energy mass.
Thus, all the air,, light, radiation is pressing down towards the large mass. The larger the mass, the more objects are attracted to it. It takes more energy to get farther from the mass. Above the earth, the gas particles press down from about 150 miles, after that there is only radiation. The density will decrease the farther you go. The density of all the objects increases the closer you get to the mass.
The reason no-one can define gravity, is because few people can understand the quantity of atomic collisions going on in the smallest object, further more something the size or a planet.
But we can measure the result! Uncountable collisions, by uncountable objects, all generally moving towards a lower average energy state.
The force of this movement is called gravity, sometimes it is seen in the form as;
  • a weather system,
  • turbulence,
  • erosion,
  • aging,
  • entropy
  • resistance
  • magnetism
  • etc
My definition of gravity is: The total force on an object resulting from quantum movement of all objects and energy towards a low energy state.
In reply to #85
05/13/2008 11:02 PM
I will call your explanation as "absolut gravity', but then what is the explanation for 'relative gravity' i.e. if there is one big & one small mass on the earth, they both apply gravitational forces on each other.
Good Answers: 40
#102
In reply to #86
05/14/2008 12:04 PM
You seem to have answered your own question. The normal equations for gravity hold for any number of objects.
Good Answers: 50
#90
In reply to #85
05/13/2008 11:58 PM
Zzzzzzzzzzzzz... Blu... Ah? What was that?
In reply to #90
05/14/2008 12:04 AM
I was just going to ask you what you thought of the stuff in #85. Personally, I think he can stuff it.
Good Answers: 50
#94
In reply to #93
05/14/2008 1:20 AM
Thought for food?
In reply to #94
05/14/2008 4:01 AM
Great illustration!
Don't you think it is similar to surface tension phenomenon.
If you put an object weighing just enough for surafce tension of water to support, it will creat the same pull in water surface from around.
Also, does this mean that higher the mass greater the time inertia? Well, then time is faster on moon than earth. So, I'll get more aged on moon than on earth, as aging is related to time or is it not?
Good Answers: 50
#103
In reply to #96
05/14/2008 2:16 PM
It's actually the other way around.
Good Answers: 50
#107
In reply to #96
05/15/2008 1:08 AM
Yes, it does look something like surface-tension. It also looks like those demonstrations that put heavy objects on a large sheet of Spandex.
And, yes! Just like a bank vault door has more inertia than the front door of your house (assuming you don't live in a bank vault), kicking your front is a lot easier on the foot than kicking a bank vault!
Also, as you pointed out, the larger the mass, the more the inertia in time, and the slower you age! This is addressed in Einstein's General Theory of Relativity. Time moves slower in higher gravitational fields. This has already been proven.
#98
In reply to #94
05/14/2008 10:32 AM
Gravity is an amoeba?
Good Answers: 50
#109
In reply to #94
05/15/2008 3:45 AM
I'm really surprised that no one else has anything to say about my diagram! But that's physics for you!!!
#111
In reply to #109
05/15/2008 9:19 AM
It appears to say gravity might be a property (or anti-property?) of space not in the universe?
Good Answers: 40
#113
In reply to #109
05/15/2008 1:22 PM
Your diagram... What happens if two objects are on the same direct line from the center?
Good Answers: 50
#114
In reply to #113
05/15/2008 1:47 PM
They collide and squish each other!
Actually, the diagram is quite limited - I would have to make it 3-D to be truly representative of the Universe. Besides, I don't necessarily believe this is a true representation, it was just a passing thought.
In reply to #109
05/15/2008 11:47 PM
OK, it's a cosmic camshaft. You turn it, and the black hole goes flying away.
In reply to #94
05/15/2008 11:55 PM
Nice one Vermin
Good Answers: 50
#121
In reply to #119
05/16/2008 12:05 AM
Thank you! I give you one good vote for that!!!
Good Answers: 50
#92
In reply to #85
05/14/2008 12:01 AM
Oh, and so I guess that this means a black hole at the center of a galaxy, containing 10 million solar masses is a real low energy spot.
Good Answers: 40
#101
In reply to #92
05/14/2008 11:52 AM
Yes! The total energy per single unit of mass is low.
It is the huge amount of mass at that low potential that creates such strong gravitational force.
Remember, each particle that is added to the mass also adds its energy to total mass. At some point this total energy will reach a critical limit. At that point any energy added will result in an equal amount of energy ejected at the poles.
Good Answers: 50
#106
In reply to #101
05/15/2008 12:58 AM
Since mass and energy are essentially the same thing and are being converted back and forth on the grand cosmic scale, I think it's time for you to go back to the drawing board!
Yes, even the most energetic photons can give rise to mass given the appropriate conditions. Also, the jets of X-Rays that shoot out from black holes are high energy particles that are captured by the black hole's twisted magnetic fields. So they were in the correct place not to suffer the fate of being sucked in.
On top of all that, astronomers have observed stars in stable orbits going round the black hole in our own galaxy at about 2 to 3 percent the speed of light. Also, a new form of stellar creation was discovered, which is based on massive amounts of dust and gas being whipped into each other and rapidly forming stars in the region of the shock wave.
Seems like a very energetic place to me!
Good Answers: 40
#112
In reply to #106
05/15/2008 1:13 PM
I agree the total energy is high in a black hole, but only because the total mass and density is extreme. Gravity is directly proportional to mass.
When I say low energy, I reference it to pure energy - radiation, light, etc.
#95
In reply to #85
05/14/2008 3:07 AM
Yes- thank you for your explanation. Unfortunately, if true grvity would be increasing all the time- entropy certainly is-if grvty was increasing as energy slowed down to mass, the supposed expansion of th e pooliverse would be slowing- it ain't!. I guess you could say that as proportions involved are so massive, it will take billions of further years!.?. Is it the fact? that gravity on Earth is increasing that makes my physical movements weaker- or that my energy is declining thru entropy- or the amount of hb I have consumed, in a detrimental additive effect?. Or the fact that we know that 3 score & 10 years is the average lifespan!. Why don't you use your considerable intellect to answer if there is anything further life beyond this vale of tears!.
#99
In reply to #95
05/14/2008 10:42 AM
Gulp! What in the Hell was the topic? Any topic?
Good Answers: 40
#100
In reply to #95
05/14/2008 11:37 AM
The measured gravity and the mass of the earth is increasing all the time.
Entropy is not increasing, but the Total entropy is.
"supposed expansion of th e pooliverse would be slowing- it ain't!." Now how can make such a grandiose unsupported statement? getting emotional?
Your energy is declining due to easy chair-itis The HB is only adding to your veil of tears, Try Alexander Keiths or Guinness
The average lifespan went from about 900 years 6,000 years ago to about 26 years in the dark ages. It then gradually increased due to the advances in medicine over the last century. The average of 70+ years only applies to non-smokers!
Do you really want to know " if there is anything further life beyond this vale of tears!."? and if I told you would you believe me?
well.... here goes....the answer is...Yes!
Best be prepared!.Prepared=win, Not prepared =Lose.. On the unlikely and infestimally small chance I am wrong, nothing is lost, by being prepared, except your veil of tears.
Good Answers: 50
#108
In reply to #100
05/15/2008 1:13 AM
Bingo!!!
In reply to #85
05/15/2008 2:14 PM
Does it follow, then, that there is no dark mass, just energy?
Good Answers: 40
#131
In reply to #115
05/20/2008 9:43 AM
No,
Dark Matter is Matter that emits little or no detectable radiation. It could be simply a high gravitational mass close or equal to the mass of a black hole.
Good Answers: 50
#132
In reply to #131
05/21/2008 2:18 AM
Have you read today's article about they think they've discovered about half the dark matter? Using the Hubble Space telescope, they (the astrophysicists) say they've discovered webs of hydrogen, helium, and oxygen atoms extending out toward the farthest reaches of the visible Universe.
Still remains to be digested by other astro-phys... They also lost the giant void in the map of the Universe. They think it may have been nothing more than a statistical artifact.
In reply to #132
05/22/2008 10:16 PM
"They also lost the giant void in the map of the Universe. They think it may have been nothing more than a statistical artifact."
You mean a srew-up?
In reply to #132
05/22/2008 10:30 PM
If they know that the matter they discovered is half the total mass, then they know how much total it is. Means they have discovered complete matter.
The scientist also unnecessarily claim what is not really known!
Good Answers: 50
#137
In reply to #136
05/23/2008 12:04 AM
Pretty much, yeah.
In reply to #85
05/25/2008 8:01 PM
Techno,
That was bloody brilliant, sir!
Kudos,my friend, kudos.
Ari (orpheuse)
Orpheuse
#97
05/14/2008 7:08 AM
Gravity is to blame for people "falling" in love.
05/14/2008 8:30 PM
I think techno and I are on the same wavelength, but I'm not into string theory
United States - US - Statue of Liberty - Sworn to preserve and protect Engineering Fields - Nanoengineering - How tiny is it? APIX Pilot Plant Design Project - Member - Good idea. Engineering Fields - Engineering Physics - Engineering Fields - Energy Engineering - Energy in Transition
Good Answers: 15
#105
05/14/2008 9:12 PM
Your questions are not difficult to answer.
Gravity is the long-range attractive force that exists between all matter.
The attractive force called gravity is a characteristic of and derives from matter.
It is attractive, rather than repulsive, because that is the definition of the word. (If a similar but repulsive force were discovered it would be given its own word.)
As with all natural phenomena, gravity has no purpose, but rather it just is.
Magnetism is one aspect of electro-magnetism. Gravity is not related to it. Gravity is derived from all matter, both magnetic and non (see above.)
(This is the easy approach... I like it. I tried to find a picture of gravity, but it was too elusive.)
“Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities. Truth isn't.” – Samuel Clemens in Following the Equator, Pudd'nhead Wilson's New Calendar
#110
In reply to #105
05/15/2008 9:13 AM
In truth, "gravity" is defined only as pertaining to a sense of weightiness...as in heaviness, seriousness, finality, terminality, deadliness, ...gravitas. It's connection with attraction comes only as a result of physical law (Newton) meant to explain theoretically why objects "fall" (go downward in the Earth-bound sense), whether towards the ground on Earth or (as was Newton's insight) towards each other (as in orbiting bodies). While Newton and those who came after, having accepted the coined word, gravity, to describe (not a physical property but) an observed phenomenon, were able to establish laws by which to predict (to approximate very closely and very provably) the phenomenon (gravity), none yet have been able to explain (much less give evidence or proof of) the underlying cause (the physical property, if you will) of gravity....whether it is (or would be) a property of matter, of the intervening "space," or that it even exists!
So you see, ascribing a definition (a conventional word usage) is merely a man-made contrivance but does not, in the case of gravity, explain what it is...any more than the phenomenon of greenness can be explained by saying we define "green" to mean the color of anything that we observe to be green. To do so would constitute the logical fallacy commonly known as "begging the question."
Therefore, neither the validity of the original question ("What is gravity?"), nor that of the less outlandish suggestions, can be refuted or set aside by simply stating a word long agreed upon to describe a phenomenon (insofar as it can be described).
So, indeed, the question (itself) does remain difficult to answer...even difficult to understand.
In reply to #110
05/15/2008 11:51 PM
"none yet have been able to explain (much less give evidence or proof of) ... gravity.... or that it even exists!"
Oh then, if it doesn't exist, what keeps you from flying off the earth?
Good Answers: 50
#120
In reply to #118
05/16/2008 12:02 AM
Yeah!!! Let's go to my new thread and beat people up!!!
Good Answers: 12
#122
In reply to #118
05/16/2008 1:54 AM
I think you missed the point of the statement. It was a statement in principle; it wasn't about what keeps me from flying...
Good Answers: 50
#123
In reply to #122
05/16/2008 2:10 AM
Squish the bug!!! Squish the bug!!!
In reply to #122
05/16/2008 2:18 AM
So you were the GUEST of post 110! Cat (sorry not the Del the cat) is out of hat!
Good Answers: 50
#125
In reply to #124
05/17/2008 3:51 AM
It took me awhile to find it, but no. That's not me. I post only as myself, and have the bumps to prove it! Even if I'm being outragiously sarcastic, I never hide my identity!
Besides, you can't vote for yourself. Try it!
In reply to #125
05/18/2008 11:42 PM
Vermin, my friend, you misunderstood. See my post 124 again. It was in reply to post 122 of CowAnon, and not to post your post 123!
Good Answers: 50
#129
In reply to #128
05/19/2008 1:37 AM
Do'h!!! Sorry about that!
Good Answers: 93
#116
05/15/2008 6:30 PM
Gravity is glue.
Named as a clue.
Some places don't have it,
And some do.
You have to be there to see it or feel it,
You get weaker without it.
Stonger because you have to fight it.
The bigger you get, the more you have.
The place where it isn't,
Is a vacation from the world.
Big and small,
Gravity is glue held off by a comma.
You don't get wise because you got old, you get old because you were wise.
05/17/2008 10:03 AM
You guys are clueless.. not all of you, just the clueless ones.. about 90%
#127
In reply to #126
05/18/2008 11:34 PM
And probably you are glueless
In reply to #127
05/19/2008 7:02 PM
I have plenty of glue.
I just don't think you can conceptualize at the atomic level.
GUEST? come on..
3Doug (6); Anonymous Poster (18); bhankiii (1); bmorrow492 (4); bob c (1); bobguz (2); bubbapebi (1); Cardio07 (1); CowAnon (1); ddphillips (1); dkwarner (1); EnviroMan (4); freddie from design (1); G.K. (3); gsuhas (8); jdretired (1); JE in Chicago (6); johnfotl (8); Kilowatt0 (1); Mag (5); Milo (5); Neil Kwyrer (4); Orpheuse (9); pc (3); Pineapple (1); StandardsGuy (10); Stirling Stan (1); Techart (2); techno (7); Transcendian (1); v1sor (2); vermin (32)
