Previous in Forum: Windows Useless Address book WAB   Next in Forum: "Ohms Law" Application to Actual Economy...
29 comments
Good Answers: 94
What's Yours?
05/26/2008 6:00 PM
In these posts you sometimes get an idea of what the members are involved in every working day but there must be a lot of stories to tell. What's the biggest/smallest, fastest/slowest, lightest/heaviest piece of equipment that you have been involved in professionally?
Re: What's yours?
05/26/2008 6:14 PM
Now't very exciting...
Most prestigious thing would be testing the Secondary Radar Systems for Gatwick Stansted and a few other airports in UK many moons ago.
Most glamorous current product would be Urinal Dosing.
(... most fun hobby thing was my Chinese Repeating Crossbow)
Good Answers: 183
Re: What's yours?
05/26/2008 6:37 PM
Biggest: a computer controlled lifting-weighing equipment for off shore modules weight up to 4.000 To(metric). Weighing uncertainty 0.1% of weight.
Smallest: a pre-load sensor for M3 bolts
Fastest: a temperature sensor with a time constant of 0.3 ...0.6 ms
Among others.
Re: What's yours?
05/26/2008 7:41 PM
Most spectacular - control system for a waterjet cutter slicing 200 x 200mm chunks (samples) from the 150mm thick steel reactor vessel on a (decommissioned!) nuclear sub. Click of a mouse (MY mouse!), & it went through like a hot knife through butter.
Re: What's yours?
05/27/2008 2:46 AM
Did it play the James Bond theme? And did you have the white cat on yor lap? eh,eh... and the beautiful ladies?
Re: What's yours?
05/27/2008 3:25 AM
Sadly, don't think so, no and no, in that order. The inside of a sub ain't conducive to cats or beautiful ladies. May have been playing music, but couldn't hear through the ear defenders. If a tree falls in the forest ...
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: What's yours?
05/26/2008 9:21 PM
My biggest item was a drawing for an overhead crane system involving dozens of cranes on about a half dozen tracks. The biggest individual crane I remember was about 80 tons on another project.
My smallest item, and the most significant, is a casing I did for a product for the military. The project is classified, so I can't say more. Well, I could, as the joke goes, but then I'd have to kill you.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Re: What's yours?
05/26/2008 11:01 PM
Slowest and most current... Laser installation, waiting for building contractor to release the building.
Luckily, I'm doing it in a warm place, South East Asia. The food ain't bad either.
I'm not a real engineer, I just play one on TV
Re: What's yours?
05/27/2008 3:42 AM
Er, how does one weigh a sewage treatment works?
Re: What's yours?
05/27/2008 3:52 AM
...when it's empty!
Good Answers: 94
Re: What's yours?
05/27/2008 4:37 AM
You could just lift up one corner & weigh it, then extrapolate.
Re: What's Yours?
05/27/2008 10:20 AM
I suppose my fastest was working on the 'Milan' antitank missile firepost electronics.
Slowest is a project that is on-going and has taken 3 years so far for an Irish company, still waiting for their final specifications.... *z-z-z-z-z--zz*
Smallest would be measuring tiny gas jets and medical needle sets for the correct hole sizes approx. 0.1mm diameter.
Largest would be the design and manufacture of a medical instrument which is used worldwide in hospitals.
Most dramatic would be test firing a 'Milan' antitank missile and after 30 feet the fuse was armed then the wire broke and the missile went nuts as we all dived into a muddy trench!! Luckily the missile only hit an army generator costing about £10,000, made a right mess of it though!!
John.
Re: What's Yours?
05/27/2008 10:28 AM
Wish I'd seen that missile hit the generator.
Re: What's Yours?
05/27/2008 10:36 AM
As the missile was travelling at 400 feet per second and we were all up to our necks in a muddy trench we didn't see it either!!!
But boy! as the shaped charge warhead can penetrate several inches of armour plating - the generator didn't stand much of a chance
It melted a hole right through the engine block in the generator!
John
Re: What's Yours?
05/27/2008 10:48 AM
biggest - a 1,000,000 Watt AM transmitter - you could walk inside it (when it was turned off).
smallest - postage stamp sized phased radar transceiver
fastest - U2 spyplane, unless you count the Orion spacecraft
slowest - extremely low frequency (ELF) comm system for submarines ~ 55 Hz
lightest - current CEV docking system project - in the sense of weight being an important design requirement.
heaviest - I've design several "boat anchors" in my time.
Re: What's Yours?
05/27/2008 4:19 PM
Biggest, reactor vessel installation at a Nuclear power station. Amazingly large crane..
(Second biggest was doing an inspection on a slant axis hydroturbine. Stand on the blade looking for cavitation damage, imagine a ships propeller with an 100 foot diameter..)
Smallest, I am from Texas, we only do big....
Fastest, turbo expander on a air seperation plant at 40,000 rpm.
Slowest, output shaft speed on a gear extruder, at about 2 rpm.
Heaviest, probably the main turbine generator set on a 1000 MW nuclear plant. Or an off shore oil production platform, if you want to call that one piece of kit.
Lightest, I don't mess with light either..
Re: What's Yours?
05/28/2008 12:58 AM
Smallest: Hearing aid.
Most "glamourous": Automatic toilet/urinal flusher.
Most critical: Safety system response time measuring system for a nuclear power plant.
Most deadly: Process control for baking Gen 3 image tubes for night vision goggles (so people can kill people better in the dark, what else?).
Or perhaps it was the coil winder for TWT's in aircraft radar...
Greenest: Energy management systems for the hotel/motel industry.
Quietest: Audiometer for testing hearing.
Most precise: Machine control for cutting high security lock keys to +/- 0.0001" tolerance in a production environment.
Popular Science - Weaponology - Scapolie, new member.
Re: What's Yours?
05/28/2008 6:40 AM
I once steered a 260,000 ton oil tanker through the Persian Gulf, a 27,000 ton cargo ship through the Panama Canal, all this just to gain my steering certificate for the MN.
Spencer.
Good Answers: 38
Re: What's Yours?
05/28/2008 11:01 AM
Since we demolished our larger machine (.95 miles long ) I'd have to go with our recent overhaul for this little puppy only about 1500 feet long. This is the drive unit.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: What's Yours?
05/28/2008 2:04 PM
that's a big taffy puller.
Re: What's Yours?
05/28/2008 5:03 PM
"taffy puller" - language problem - please explain .
[Sorry - neglected to tick the "off topic" box (again). One of my few big CR4 gripes is "why can't I mark my own post OT after posting it?"]
Re: What's Yours?
05/28/2008 7:28 PM
I have a big wood chipper 110" disc 20 thousand pound flywheel total weight spinning 50,000 pounds will chip a 27" in logs surprisingly it spins at 350 rpm original hp 2000 electric ( converted to diesel ) we nicknamed it the collider a fun machine to watch atomize huge chunks of wood
Lighten up
Re: What's Yours?
05/28/2008 1:06 PM
Replacing the top of a cat cracker complete with cyclones. 2000 Tons.
Steam generator replacements. 200 tons to 400 tons.
Re: What's Yours?
05/28/2008 1:09 PM
cat cracker ... ? Ouch
Re: What's Yours?
05/28/2008 2:00 PM
A refinery makes gasoline with cat crackers Del, and without cat crackers we would be over run with cats, so we need to keep cracking them!
Good Answers: 94
Re: What's Yours?
05/29/2008 4:14 AM
It's not like a dog biscuit then???
Good Answers: 213
Re: What's Yours?
05/28/2008 10:18 PM
Smallest- fusion splicing polarization-maintaining optical fiber.
largest- Engine room, USS Ranger (Forestal Class Aircraft Carrier).
Fastest- Casini Prope
Slowest- My perpetual motion machine invention (mentioned in other posts, which most people mistake for a rock sitting on a park bench).
Most exciting- I haven't gotten there yet, but I'm working on it.
Re: What's Yours?
06/01/2008 8:33 PM
Hi,
The largest I worked on was a Skiaci? spot welder that was about 12 feet long, 6 feet high and 3 to 4 feet wide. It had 2 large mercury rectifier vacuum tubes, and a large thyratron tube, each with metal caps on top. It would throw sparks for at least 5 feet when welding. The slowest was a digital computer with a teletype to load the executive program with a paper tape. That took 35 minutes.
S
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
Re: What's Yours?
06/02/2008 5:14 AM
Smallest - high gain mic pre-amps
Largest - 50kA electro-plater supply, the cabling is a bit heavier than for mics!
Re: What's Yours?
06/04/2008 7:03 AM
Most memorable: Anaesthetist for open heart surgery. (125 separate operations, veterinary)
Somewhat Challenging: Hand operation of gravity mould. Mould was 17 pieces, total built size 1cm cube, single cavity.
Most challenging: Hand solering wires onto opposing faces of 0.5mm square piezoelectric wafers with no magnification and a "hobby" type soldering iron.
Largest challenge: 5,000 acrea "trial" planting of non-irrigated grain in Queensland desert zone. (Not on latin squares, but orthogonal array designed experiment.)
Smallest challenge: Design for 16 bit A/D 5 MHz chip. (In the early 1980's when computers were 8 bit and clocks speeds were slow by today's standards.)
Longest and most rewarding challenge: 25 years married.
Register to Reply 29 comments
3Doug (1); bhankiii (2); Chankley (1); charsley99 (1); cwarner7_11 (1); Electroman (2); Hellcat (1); jmart23 (1); JohnDG (3); Just an Engineer (1); nick name (1); Nigh (2); PWSlack (1); rcapper (1); Scapolie (1); StandardsGuy (1); Steve S. (2); traditional (1); user-deleted-1105 (5)
