Previous in Forum: Buoyancy on Precast Units   Next in Forum: Sinking Bridge
18 comments
DR Hopper
08/27/2008 3:57 PM
Hi
Ive recently moved to a road side property where a major trunk road runs literally 2 feet from the side of my house.
We have recently noticed considerable mould on the internal walls of the house and I have now measured the internal floor level against the road on the other side of the stone wall and to my horror find the road level to be approximately 30 inches above the internal floor level.
The property is over 200 years old and it looks like the road authorities over the years have gradually raised the road level and now Im suffering considerable damp ingress. There is obviously no dpc due to the age of the property so I expect a degree of natural cottage dampness. But having road side drainage seeping down the wall with 30 inches of road surfacing and sub base and soil piled up above the internal floor level is far from reasonable.
I approached the road authority and they suggets I should seek legal advice.
I have no money to front a legal arguement.
What can I do?
Thanks
David
Good Answers: 53
Re: DR Hopper
08/27/2008 7:39 PM
You may be able to dig a drainage trench between the house and the road that will divert the water to a lower area away from the house.
Good Answers: 230
Re: DR Hopper
08/27/2008 10:15 PM
Hello DR Hopper
You do not list your location or Country. (You may easily do that in your Profile, then it auto-updates for all your Topics and Posts).
There is a Common-Law provision in most Jurisdictions, known as: "Natural Ground Levels may not be disturbed to the detriment of others".
As this road-level raising has continued for some 200 years, the problem is not going to improve until you have approached the "Local Authority", the one responsible for raising the road level.
So (And I am assuming that you are in UK/Europe or US/Canada), go and see the Roading Engineer at the "Council" or "Roads Board", or the "Authority" responsible.
If you are in Eastern Europe, Asia, India, Russia or South America, you may have to "encourage' the person you see, with 'baksheesh' or similar.
What would be needed, is a trench dug to below your wall foundation level, concreted, and covered by hot-dipped heavy mesh grille, water to be taken away to a stormwater drain, either by natural flow or pumped if need be, all this at the expense of the "Roading Authority".
After that, your stone wall should slowly dry out, perhaps with assistance from an interior dehumidifier to speed the dry out of your stone wall.
Once the wall is fully dry, it would be prudent to cover the exterior surface to well above road level with a clear silicone weatherproofing liquid, = a water repellent, to reduce further water ingress. If you do thus, it's best to go up to right under the eaves, or rainwater may enter above the clear silicone, and find its way to the interior, causing mould once more.
Of course, if you are using any un-flued oil/gas/LPG heater, drying clothes with any 'un-vented to the outside' clothes drier, are not ventilating the interior air sufficiently, and/or insufficient DRY heating inside, you will get mould growth where condensation occurs: at the cold parts of the building = along the lower parts of the wall/s.
The interior mould (perhaps you are in the UK - spelling and the expression 'trunk road' shows that), may be removed by application of chlorine bleach or similar, remember to wear mask and gloves during use of bleach or mould killing chemicals.
Once again, this reply is of a general nature only, because you have not advised your Location/Country.
Reply here, with
Kind Regards....
Re: DR Hopper
08/28/2008 3:00 AM
There is a silicone product that gets added as a liquid by bottles placed in holes drilled in the wall that eventually permeates the wall and makes a permanent damp course.....do not ask me what its called. It takes a month or two to "seep" in.....I remember seeing the ads in the UK....
Good Answers: 230
Re: DR Hopper
08/28/2008 3:10 AM
Hello Andy Germany
Unsure whether this was what you meant: http://www.pureadhesion.co.uk/category/34/sealers?gclid=CJLSltr8r5UCFQ8QagodQincjw
It is important to use a product which repels water and water vapour, but allows the stone to breathe.
Kind Regards....
Re: DR Hopper
08/28/2008 3:40 AM
I think not, but it is a long time ago.
The method used was to drill a row of holes just above floor (road?) level. then a bottle of the special fluid is upended into each hole. The hole fills, and the liquid seeps into the wall. As the liquid is used, the bottle replaces the loss automatically as it is left sitting in the hole.....the fluid replaces water and repels further water. It forms a new damp course.
It takes a long time to seep in - months....
Re: DR Hopper
08/28/2008 12:26 AM
I agree with ace a valley is needed to drain away the water. If the road is really the close you could also dig some deep holes about 4 foot in diameter then fill them with rock. Cover the rock with some tar paper. Of you plan ahead call or find some roofer removing a flat roof and get a bunch of the old roofing they cut it out in 3 of 4 ft squares usually. Covering the rock filled holes with this will allow you to put dirt over the holes and keep a lot of dirt from filling in around the rock. But the holes will take in water during heavey rains and prevent the extra water from laying against your house.
Re: DR Hopper
08/28/2008 2:11 AM
You can also use some of the 4 ft dia plastic drain pipe as a liner for the holes.
Good Answers: 97
Re: DR Hopper
08/28/2008 2:07 AM
Hi Dr Hooper
Before you even tackle them legally you need to check some facts.
For example you may have to check the roof for leaks. In my area (masonry walls) a leak in the roof above the wall will soon have the wall damp enough for mould.
Legally I would start with your Title Deed, it may contain provisions enforcing duties on the authorities.
It is always handy to have copies of relevant law. Authorities can usually be persuaded to rectify problems without a legal battle when faced with facts.
You should also look for a hidden defect clause in your law. If the seller patched and painted the wall to disguise a mould problem and kept the information a secret you may have a claim on the seller.
Re: DR Hopper
08/28/2008 2:10 AM
He never said if he was renting or owned it.
Good Answers: 97
Re: DR Hopper
08/28/2008 5:44 AM
True but if he is renting the repair costs would be for the account of the owner and not his as suggested in the post.
Good Answers: 230
Re: DR Hopper
08/28/2008 7:16 AM
Hello Hendrik
from me
Good observation, keep up the good work.
Kind Regards....
Re: DR Hopper
08/28/2008 8:50 AM
I figured he owns it because who would put up with trucks driving right next to the house and moldy walls everyone eles would move.
Re: DR Hopper
08/28/2008 3:12 PM
Thanks Gents for your advice. My situation is in Scotland.
Im confident that the roof is not the source of the damp ingress. And yes I do own the property. Apart for the proximity to the road its a beautiful place to live.
I spoke to the engineer at the govenment office today and am pushing to have them excavate a trench along the wall. The engineer said they would possibly do this with a view to putting in a valley drain. I suggested that whilst they were excavating for this they dug further down to below the level of my internal floor so that a damproof membrain could be placed against the wall before back filling with, perhaps, course aggregate. This would reduce the interface of the miosture heavy soils and subbase penetrating directly into the wall.
He told me that he would not dig near the walls of the house for liability reasons, however I said if they dug as close as they felt comforable with I could hand dig the rest?
What do you think?
David
Re: DR Hopper
08/28/2008 5:00 PM
Sounds good to me.......make sure that water is guided to run away from your building, no matter how much rain comes down.
Good Answers: 230
Re: DR Hopper
08/28/2008 5:02 PM
Hello DR Hopper
Accept their offer, and get the job done while you have fine weather.
They evidently accept their road works have caused the problem.
If the work done is not satisfactory, you are then able to encourage them to complete it to your satisfaction.
I can understand why they would not operate their digger close to your foundations, because in case of subsequent subsidence, wall/foundation damage, you may claim their work caused the damage.
Advise progress.
Kind Regards....
Re: DR Hopper
08/28/2008 7:11 PM
A valley drain and sloped paement away from your structure would be helpful, you do not want a valley drain near your structure as these direct the road surface drainage and collect it next to your structure. Next to your structure you want a trenched subsurface interceptor drain at foundation level backed with plastic liner on the structure side of the trench. This would intercept and direct subsurface water away from contact with your structure, as this is the purpose of an interceptor drain. An interceptor drain is easy, a screened PVC drain pipe, Gravel, encapsulated in geotextile filter fabric placed in the bottom of the trench. The trench should slope towards a drain outfall point like a municipal stormdrain system or outlet on a hillside. Paving the surface with AC and installing a valley gutter down the center of the road, with the road sloped to the center gutter, would help stop much of the infiltration into the subgrade materials. Alot of drainage however, depends on having sufficient slope available to drain the water away rapidly. It is easy to create slope in interceptor drains, much harder to create longitudinal slope (without substantially impacting others or the road function) in a pre-existing roadway near an intersection with other roadways.
Re: DR Hopper
08/29/2008 5:07 AM
Prior to purchasing the property, there should have been a technical report produced by a qualified surveyor highlighting the features of the property to the satisfaction of both the purchaser and the party providing mortgage funds. The prospecive purchaser pays for this assessment, in the UK. What does that report say? At the very least, it should have noted the dampness issue! There may be grounds for further discussion with the Surveyor on this topic.
Good Answers: 97
Re: DR Hopper
08/29/2008 12:11 PM
I am glad it is turning out fine.
Getting the runoff of a road correct often goes wrong.
Where I grew up the area is very flat sandy soil. What they did there was to build the road, wait for the first good rain and put culverts in where the water was damming.
Register to Reply 18 comments
Ace Boeringa (1); Andy Germany (3); dadw5boys (4); DR Hopper (1); Hendrik (3); PWSlack (1); RCE (1); Sparkstation (4)
