Previous in Forum: Chinese motorcycles/quadbikes   Next in Forum: Friction Materials Literature
16 comments
Motorized Roller Blades
11/06/2008 6:15 PM
Hi everyone,
I am very new to the mechanical engineering field, all I currently have is knowledge of basic physics.
I am trying to construct motorized roller blades (not for practical use, just a demonstration).
I need help either building a small/power motor, or after purchasing one, how to connect it to the wheels to be able to make them rotate, and how to make a mechanism to be able to turn the motor on/off.
Preferably it would be best to add the motor to already existing roller blades, but new ones can be created as well.
Can someone please help me out with this? Thank you very much.
Re: Motorized Roller Blades
11/07/2008 10:48 PM
The slickest rig of this sort I've seen does not attach to the wheeels of the skate, but rather powers another wheel-on-a-stick sort of thing. Looked like a ratehr easy type of fab out of a disused weedeater- check Make.com or Instructables. Putting ythe motor on the wheels is too heavy, cumbersome, and dangerous. With the hack I saw, shedding power was as easy as letting go of the driver.
If all else fails, read the directions. That's if, and only if.
11/07/2008 11:42 PM
I agree, the weedeater (or edger) idea is the safest.
If you really want to power the wheels, though, I'd mount a small motor on the ankle with the axis vertical. A flexible shaft would run to a wheel that could be disconnected by rocking back on your heels. Perhaps a release built into the brake. Batteries could be in a fanny pack (bum pack if you're British).
You might want to only power one side. It would be easier and avoid synchronization problems. You don't want one foot going faster than the other, now, do you?
11/08/2008 3:37 AM
Hello Guest,
Why not sign up with CR4 and let us know a little about yourself.
You could try mounting a cordless drill with the grip removed to the ankle to drive a friction wheel to power the roller blades. You could also drive the one of the wheels directly thru the axle, but the motor would be mounted to the side and not the rear. There are 90° attachments that mount to the drills. I have built aircraft dollies to move small aircraft around the hanger using a cordless drill so the torque should not be a problem. The batteries do not last long though and the speed is fairly slow. A simple momentary double pull double throw switch could be used for direction control.
Since this is just a proof of concept model and not for practical use, this set up should work well. I like the idea of carrying the battery in a fanny pack that someone else posted. You could even run the motors on higher voltage than rated to increase performance. This could limit the life if the motors though. Running both motors off of one power source, and through a motor controller should keep the each motor in sync. Running without a controller could cause problems due to different current demands for each motor as torque requirements change.
SAFETY DISCLAIMER. This can be a dangerous product. Being motorized, it could cause the user to lose their balance, akin to pulling the rug out from under their feet, resulting in a fall. Just a warning.
"If you need a machine and don't buy it, then you will ultimately find you have paid for it but don't have it" - Henry Ford. (Also my excuse when adding to my ever expanding collection of tools)
11/08/2008 11:03 AM
The motor is the wheel. Fixed axle/rotating housing.
Good Answers: 25
11/08/2008 2:32 PM
I think the remote drive is a good idea; the batts. and
drill type motor in a body pouch (bum bag) powering a
flexible drive to one or more of the wheels.
For safety you could incorporate a simple clutch on the
wheels, depending upon weight being applied. i.e. if the
foot is not on the ground the clutch disconnects the drive.
This way the drive could be cancelled by lifting the foot.
In the UK this set up may have a lot of mileage (no pun) in
that others, such as the Segway, are not accepted as legal.
(not for the road, and dangerous on the pavement)
If you get the system working well offer it to a manufacturer
with a licence / royalty?
Good luck with your blades.
jt.
Jesus said love thy neighbour, but he's 26 stone and has a beard!
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
11/08/2008 3:36 PM
Hot Dang, jt!
I think you're on your way to yet another GA! Nice concept. Worm drive on the wheels or a transmission? Of course, you could also skate in reverse, but if the direction switch is centered, it should go into drift/neutral rather than lock up like a drill.
Mark
Good Answers: 25
11/08/2008 7:20 PM
Thanks for the enthusiasm Mark. Yes.
I have lots of ideas on this; e.g. instead of a clutch,
use limit switches for both forward and backward.
This means no drive when the blade is not on the floor
(weight less) - which saves the battery; with a similar
limit switch reversing the polarity for backward travel.
Simpler, effective and trouble free.
(no clutch problems or attracting the wet and dirt.)
I also had another idea (I do some times) it escapes me
now (past my bed time) so I'll have to return after a nap!
Thanks for the (near) vote!
jt.
Sleep, perchance to dream..... that beautiful.......
11/09/2008 6:34 AM
Howdy:
Bicycles in times of quick power needed
just ran friction drive on a tire edge from
say a 1hp O&R "chainsaw motor" in 1980's.
New little model- brushless motors
(FOUND EVERYWHERE)
with
a common gear-tooth drive
right against a roller-blade wheel
would demonstrate plenty!
Estimate the torque of say a 3/8" dia gear
required with about 3-5- (?) lbs of pressure
against a roller wheel, do a quick measurement
of loaded- controlled amps (someway)
or talk to a r/c-modeller/ hobby shop about this
to not burn out the motor in a short demo.
YOU MAY BE IMPRESSED BY HOW SMALL A MOTOR
WILL WORK FOR A MOTORED-HUMAN-DEMO !
11/09/2008 6:52 AM
You'll shoot your eye out
Good Answers: 15
11/10/2008 7:28 AM
These things are already on the market. I came across them when I was looking at motorized scooters for the kids.
http://gizmodo.com/archives/motosk8-motorized-rollerblades-022415.php
scotchdrnkr
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
11/10/2008 12:05 PM
Yikes! I know it takes a bit of horse power to move you along but that pic seems too much. HA!
-why bother doing it wrong when it will be anyway.......
01/02/2009 7:15 AM
Mate i have actually built a pair of motorized rollerblades. i have photos of the entire construction process and a video or two of my road test. my choice in engine size was limited to a 16cc snipper motor, however a 25cc to 30cc would be more appropriate. engine drives a transfer axle via chain (too noisy) on left side, transfer axle transfers power to right side, this then drives an adjustable idler wheel via friction drive, which then drives the rear wheel on the roller blade via friction drive. here's a few pix. . .
02/01/2010 2:45 PM
Hi, TheJudge!
Welcome to CR4!
Them's a mighty pair of skates you've built there. I think you are going to enjoy this engineers' discussion website a lot.
Mark
02/01/2010 1:58 PM
For Some Great Idea's Watch Air Gear DVD's It Will Help You.
04/04/2010 7:29 PM
haha watching air gear is what got me searching for motorized skates, and on this site. its also on hulu. you could go the brushless motor route. lots of power and torque. thanks. good luck
04/01/2010 10:02 AM
i know a perosn how can help my name is cory crubaugh and i live in norwake ohio and i would like to help you
Reply to Forum Thread 16 comments
Anonymous Poster (4); avi-tech (1); Duce (1); gdevine (1); HarryBurt (1); JNace (1); jt (2); ktel60 (1); MarkTheHandyman (2); scotchdrnkr (1); TheJudge (1)
You might be interested in: Saw Blades, Roller Screws, Fan Blades and Propellers
