Previous in Forum: Deadbeat partners   Next in Forum: Spider's Web
23 comments
Engineering Fields - Manufacturing Engineering - New Member United States - Member - New Member Popular Science - Cosmology - New Member
Length or material on a roll
11/17/2008 10:34 AM
We are currently, trying to account for some old inventory. It was moved from another location with no Inventory records, and we need to get in the ball park. What we need to count is a large quantity of rolls of fiberglass cloth, (various lengths of linear feet). The cloth is rolled onto 3" cores and a whole role measures in circumference 36 7/8" (including the core) and the linear length of cloth is 1150 feet. I Realize that as the circumference decreases the math will change as to how many linear feet are left on the roll, does any one know a formula or a rule of thumb that will help me get a close inventory with out re-rolling all of our partial rolls?
Thanks
Regards, and stay Positive
Good Answers: 66
Re: Length or material on a roll
11/17/2008 10:58 AM
This question comes up periodically...check this thread:
http://cr4.globalspec.com/thread/13976#comment140483
Aequam memento rebus in arduis servare mentem.
Good Answers: 266
11/17/2008 12:01 PM
If you have a scale you could weigh it to compute the length left on the rolls.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
11/17/2008 8:56 PM
You might also want to take a look at this thread:
http://cr4.globalspec.com/thread/10628.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
11/18/2008 8:03 AM
I have made a spread sheet that allows you to input numbers into it and it will give you your lengths based on the calculations the were derived from the discussion you mentioned.
I find it gets very close to the actual length of the rolls we use here. I can e-mail it to you if you like.
If necessity is the mother of invention then is laziness the mother of necessity?
Good Answers: 19
11/18/2008 9:14 AM
I don't know about him but I'd love receive it on my email: duconems@yahoo.com. thanks
11/18/2008 9:15 AM
that would be great
rwindbigler@yahoo.com
Good Answers: 26
11/18/2008 10:27 AM
I have sent it to you both I hope it works for you.
11/18/2008 10:48 AM
OD + ID x #wraps x .131
We manufacture belt conveyors and also use rubber/vinyl material and this is the formula we use for calculating materials at inventory.
11/18/2008 12:34 PM
This formula works on any thickness of material.
We have material that is 1/32" thick to 1/2" thick.
Good Answers: 26
11/18/2008 12:46 PM
the formula you provide is a good formula if you know the # of wraps. However the count for wraps can be up in the thousands for the types of material we run. Spiral calculating formulas work well to find the number of wraps.
The spread sheet I created does both calculations and takes into account the thickness of the core as well as the material and will also calculate the number of wraps on the roll and provide you with the lineal footage.
I hope it is helpful to those that needed it and if any others would like to have it let me know. I would not have been able to get it figured out without the help from others in this forum.
Good Answers: 19
11/18/2008 11:56 AM
Thanks
11/26/2008 12:14 PM
I WOULD LOVE A COPY OF YOU FORMULA FOR INVENTORY PURPOSES
Good Answers: 96
11/18/2008 1:07 AM
Yes, this topic has been posed before, but maybe I can also give you a simple way to do a fast estimate:
OD minus ID ... divide by 2 (keep this number handy) ... add to the ID. That gives you the average diameter. Multiply that by 3.14 and that will give you the circumference of the average diameter.
Measure the thickness of material on the roll, and divide the number you kept by that thickness. That will tell you how many layers or 'turns' there are on the roll.
Multiply the turns by the average circumference and you have an estimate of the length of material on the roll.
Example: 6-inch OD, 3-inch ID, and the material measures 0.010 inches thick.
6 minus 3 = 3. Divided by 2 = 1.5. Plus 3 = 4.5. Multiply by 3.14 = 14.13 inches.
1.5 divided by 0.010 = 150 layers or 'turns'.
150 turns times 14.13 inches = 2120 inches per roll.
Just an estimate because in the winding process there may be compression of the material, or loose 'turns', or varying thicknesses of materials. BUT, it's close.
Kind regards ...
"Just when I had all the answers, they changed all the questions"
Hobbies - Musician - New Member Engineering Fields - Manufacturing Engineering - New Member
11/18/2008 1:18 AM
Yes...the length of an archimede's spiral.
L= length
r0= radius of outside roll diameter
ri= radius of core diameter
t= thickness of material
pi= 3.1416
This should get you Very close. The complete formula folllows. (1n) is a natural log. Most of the time the difference in answers between the short and long versions are of little consequence. If the material is Very thick, use the long version for better accuracy. Hope this helps you.
Courage is not the absence of fear, but the inner resolve to rise above it....or the inane lapse in judgement brought on by copious imbibitions....Egre Flagrus
11/18/2008 5:20 AM
What is very thick ?
Thank you.
Coming together is a beginning. Keeping together is progress. Working together is success. Henry Ford
11/18/2008 12:36 PM
Hi Sal
Sorry for delay. I should have been more precise.
The short calculation doesn't take into account that each layer has a bottom radius and a top radius. So the thicker the material the less accurate the short version becomes.
I've used both on fairly thin materials like papers and films that are wrapped tightly and at known lengths of 5000+ feet and the answers were correct within a 1 1/2 feet of the total length.
Of course, neither takes into account any air space that may exist, but they are good tools for accurate estimation.
Jeff
11/18/2008 3:14 AM
All the mathematical methods are fine if you have any real dimension for the thickness of the material on the roll. However, GRP mat and cloth does not really lay well on the roll and thus the thickness is arbitrary.
We manufacture in GRP - see www.explorermarine.co.uk - and we buy glass by weight in kg. Hence we would do the easy stock take and count the rolls and weigh each one, and deduct the weight of the empty card tube.
Good counting
HM
Hugh Mattos Chartered Engineer...... :---------: Through helping others we give purpose to our time on this earth and take pleasure from it.
11/18/2008 12:05 PM
You got several very good answers here, didn't you?!? I'd go for the "by weight" method myself, but only if you have to relocate the rolls anyway. Otherwise, the "measurements and math" methods are less effort. I'm also thinking that unless you are seeking very quantitative results, a simple diameter ratio might be ballpark-y enough. Full roll diameter/100% : partial roll diameter/x and solve for x.
Say the full roll is 36" for simplicity's sake. 36"/100% : 18"/x; then 36x = 1800, and then x = 1800/36 = 50%, or half of a roll. Most any fractional percentage can be determined by this method, and the carboard tube doesn't have to be subtracted.
11/18/2008 1:05 PM
Because we have a good scales here and we do a lot of other work by weight, I believe we are going to use the weight method. Our rolls are not always wound as tight as we would like because they go through several process's, (but the end result is consistent in weight) so the measuring does not always seem to be a good guide. Yes I have gotten several good replies and formulas. I will save much of this information because we do use other types of rolled stock where it may come in helpful for the future. I appreciate all of the replies I have gotten you have all been great.
RW
11/26/2008 2:32 PM
I used to work in the paper industry. We had the same problem. Go here and check out the math. If you know the caliper thickness of the sheet, outside diameter of the roll and the outside diameter of the core, this will work for you.
http://findarticles.com/p/articles/mi_m3116/is_/ai_n15691841
12/01/2008 6:41 AM
Thanks that was a very helpful website.
12/01/2008 10:55 PM
If we imagine that the roll is unwound and laid flat on the floor,the total area at the side of the roll will be equal to length multiplied by thickness. This gives the entire area on the side.This is equal to the area of the one of the sides after rolling in the roll form.Area on the side of the roll is equl to area of the outer dia minus the area of the inner dia.Now we can equate the first part with the second.
To know the length we have to divide this area by the thickness of the sheet.The result is accurate if the rooll is wound tightly.Otherwise we shoud take the factor of bulk density also in to account.
03/01/2011 4:02 PM
A lot of Data na d a lot of help thanks to all>>
Register to Reply 23 comments
3Doug (1); Anonymous Poster (1); CSM Engineer (1); DCaD (1); double_j_b (3); ducon (2); EnviroMan (1); HughMattos (1); Janissaries (2); k.v.gopalakrishnan (1); ozzb (1); rwindbigler (4); Sal (1); snygolfgs (2); staceyroberts (1)
