Previous in Forum: HAPPY CHRISTMAS TO ALL CR4 MEMBERS & FAMILIES   Next in Forum: It's "What's This?" Time Again
Heating a Driveway in Ontario
12/11/2008 4:17 AM
Hi Folks,
My son lives in Southern Ontario and has a driveway some 180 foot long and a slope of 1 in 8. They suffer from lots of snow and below zero temperatures.
Has anyone any experience of heating such a driveway. My thoughts were to use an IC engine, diesel or gasoline and circulate the cooling water /glycol mix through pipes. Turn the output energy from the engine into heat via a generator and add a insulated tank and another larger pump to cope with the head, This way we should get 60%+of the engine power into heat. Any thoughts welcome.
Oliver Dunthorne (England)
United Kingdom - Member - British
#101
In reply to #100
Find in discussion
Re: Heating a Driveway in Ontario
12/26/2008 12:37 PM
you don't say....
bondy111
#102
01/16/2009 1:35 AM
I live near North / West Vancouver. many driveways are steep and long. some at higher elevations. I know of several heated driveways. I was told that they were all electric and must be put on at least 24 hours before snowfall. I have no idea of cost or how to. There is a supplier who makes long distance "heat trace". The dock i worked at had steel rails, about 600 both heated to keep troughs clear. Our club just paid $ 965 for 6 hours of bobcat plowing. not all the snow got cleared. Cold climate citizens would probably laugh at what we call snowy treacherous conditions.its not really snow, more like "white mud".
In reply to #102
01/16/2009 2:45 AM
Pretzel,
Quite good summarisation of the problem.
When the heating needs to be on for to long time the cables are buried too deep and the power will be to low.
The power selection is also a tricky one: it all depends on the climatological situation once the snow has gone. You need to keep the heat in the driveway until all water has evaporated, when the power is to low this will take forever.
The same problem is occuring with roof heating: to be efficient the power needs to be sufficiently high. But as a roof wich has snow load issues is typical >1000m² the power needed goes up very quickly. The decision is then mostly negative.
But removing the snow by hand is also a problem: each winter people die or get seriously injured while getting the snow of their roof.
agua_doc (1); Andy Germany (1); Anonymous Poster (5); bob c (6); Bondy111 (3); Bricktop (2); BruceFlorida (1); bwire (10); ca1ic0cat (1); Campbell Lighting (1); ddk (1); Duckinthepond (13); elnav (9); emc_c (3); Gwen.Stouthuysen (11); HarryBurt (1); HUX (1); marcot (1); mircoconsultant (1); Oliver Dunthorne (11); pretzel (1); Ried (13); saddlechariot (1); The Commoner (1); user-deleted-1105 (2); YoshP (1); YUMASQ (1)
