Hi all! I have acquired a two tonne site articulated 4WD dumper to use as a powered trailer on my farm (make and model are unknown but is similar to a Thwaits)! My problem is that it has a very low forward/reverse speed. Usually, articulated dumpers have a top forward speed of around 19kph but my one is less than half that.
It is powered by a 16hp Lister Diesel. It has a three speed gear box followed by a dropper box (driver, driven and three intermediate gears) to the two drive shafts for front and rear axles.
I'm looking for a simple way to double the forward speed of the m/c that isn't going to cost me a fortune.
I've looked at the gear box but it doesn't look hopeful that I could swap a gear in there. I've looked at the dropper box. This is probably an area that I could modify. Perhaps remove all gears and convert to chain drive (then I can please myself with the speed ratio's). The axles could be modified (probably at great cost) and lastly, I could double the circumference of the wheels (with all sorts of knock on problems).
Without doing something really expensive like, converting to hydrostatic drive, does anybody have any ideas that I may not have considered?
Thanks in advance!
