I have been interested in designing a human powered - helium filled aircraft for a while now, but a major hurdle is in containing the helium. As you may or may not know, no film known, can contain helium for an extended period of time. If it could, we would have seen this type of craft before. Helium is an extremely small molecule, and (atom?) and migrates through the membranes. Mylar is one material that takes a couple of days for the pressure to deplete, but I want something that could last longer.
I have an idea, and wanted to gather some input. Would it be possible to create a surrounding envelope of nitrogen (inert), and have the nitrogen at a slightly higher pressure than the helium, to contain the helium. First, is nitrogen (N2) a larger size molecule, as I believe? Can it be contained within cheaper membranes than mylar? Will it oppose the migration of helium molecules, by essentially filling in the holes in the membrane containing the helium? Of course, the pressures involved are low enough for the bonding of plastic films to withstand.
If so, maybe we can all be flying bicycle powered aircraft....
Chris
