Previous in Forum: Why Are People Like This?   Next in Forum: vegetable wastes
The Engineer
Good Answers: 129
Arctic Sea Ice May Be Gone in 30 Years
04/03/2009 10:46 AM
Here's the story:
WASHINGTON – Arctic sea ice is melting so fast most of it could be gone in 30 years. A new analysis of changing conditions in the region, using complex computer models of weather and climate, says conditions that had been forecast by the end of the century could occur much sooner.
A change in the amount of ice is important because the white surface reflects sunlight back into space. When ice is replaced by dark ocean water that sunlight can be absorbed, warming the water and increasing the warming of the planet.
The finding adds to concern about climate change caused by human activities such as burning fossil fuels, a problem that has begun receiving more attention in the Obama administration and is part of the G20 discussions under way in London.
"Due to the recent loss of sea ice, the 2005-2008 autumn central Arctic surface air temperatures were greater than 5 degrees Celsius (9 degrees Fahrenheit) above" what would be expected, the new study reports.
That amount of temperature increase had been expected by the year 2070.
The new report by Muyin Wang of the Joint Institute for the Study of Atmosphere and Ocean and James E. Overland of the National Oceanic and Atmospheric Administration's Pacific Marine Environmental Laboratory, appears in Friday's edition of the journal Geophysical Research Letters.
Article Found here
In reply to #109
Find in discussion
Re: Arctic Sea Ice May Be Gone in 30 Years
04/15/2009 8:03 PM
"Bear in mind that in this area I'm no more than a sceptical amateur."
No problem, so are the rest of us including R.P.
In reply to #107
Find in discussion
04/16/2009 7:22 AM
Hi StandardsGuy
I was hoping someone would comment on the sun's magnetic field being 2X+ what it was in 1900. That is a very significant change. Let's make this a discussion now that the debate is over. What do you say?
So far my searches on this haven't shown much.
I would like to know where the BBC got the info about the sun's magnetic field being 2.3x that in 1900. I can't seem to find it.
The magnetic field of the sun does seem to be subject to very large fluctuations, although I haven't quantified how big yet. It seems likely that normal variation with the sunspot cycles is more than this 2.3x and this occurs over a 22 year (some say 11 year) cycle.
Longer cycles of a couple of hundred years also seem to occur. It is suspected that much longer cycles are also operating.
There is a theory that a significant proportion of cloud cover is due to ionization in the upper atmosphere due to cosmic rays and that the level of these is regulated by the sun's magnetic field.
Increased cloud cover leads to global cooling, while decreased cover allows warming.
The effect is most noticeable in the tropics, which provides the heat engine to drive the world's air circulation and hence global climate.
I wonder if the guy who came up with this has ever spent much time in the dry tropics? At Mt Isa we could go a month without seeing a single cloud.
I don't know if this is much help, but it does provide something to think about.
If you would like to make this a separate topic, please do. I'll happily observe and participate (Having no knowledge of a subject has never yet interfered with my having an opinion)
Good Answers: 109
#117
In reply to #114
04/16/2009 3:58 PM
"I would like to know where the BBC got the info about the sun's magnetic field being 2.3x that in 1900. I can't seem to find it."
I suspect this is from geomagnetic data, some of the protons from the Sun may cause changes in materials on Earth. Either these changes or the crystallographic disturbance from passing high energy particles that can be made visible by etching may be used for estimates on the Sun's magnetic field.
This is speculation only, not based on any knowledge.
"There is a theory that a significant proportion of cloud cover is due to ionization in the upper atmosphere due to cosmic rays and that the level of these is regulated by the sun's magnetic field."
Not this way as these are far too energetic. But if the sun's magnetic field is high then this seems to be in parallel with high particle emission at moderate to high energies.
These particles - the solar wind - are mostly electrons and protons.
Any particle inside a magnetic field will move along a spiraling path around the field lines.
Radius can be calculated by centrifugal force equaling the Lorentz-force.
If the velocity of the particles is very high then the path of the particle will not change significantly.
If there is a medium velocity of the particles and the resulting radius is in between 500 to 6000 Km, then the particle is directly diverted towards Earth (one side only) and by hits on atmospheric molecules generating ions and electrons that act as nucleation and condensation sites thus creating clouds.
If there is a low velocity of the particles (radius of path below 300 Km) these will spiral the field-lines until near north-pole or south-pole the field lines plunge into Earth. The particles will collide with atmospheric molecules, excite these so that the effect is to be seen as polar light.
At very high sun-activity (very many particles extending to high energies) these may be seen down to 30° latitude.
http://cr4.globalspec.com/thread/26330
http://science.nasa.gov/headlines/y2007/13nov_africa.htm?friend
Links are from earlier discussion on the effects of magnetic storms on the sun.
RHABE
In reply to #117
04/16/2009 11:06 PM
"I suspect this is from geomagnetic data"
I don't think so. "... the strength of the Earth's magnetic field has been steadily decreasing, at a rate of about 5% a century, since we first started directly measuring it in the mid 1800s."
Good Answers: 109
#125
In reply to #122
04/17/2009 4:06 AM
Hi,
yes, declining of Earths magnetic field is a reality,
easily measured in the magnetisation of new basaltic seafloor.
This had triggered a debate about a next reversal of Earths magnetic field with some severe showering of fast solar particles reaching us. These reversals take place roughly with (80+-50) Kyears intervals.
I had in my mind a speculation about the fast particles emitted by the sun leaving their signatures (as trajectories of disturbed crystal lattice) in some minerals.
So I should have formulated more carefully: "I suspect from traces of fast particles in minerals". (Speculation only, no real knowledge about.)
RHABE
Good Answers: 38
#126
In reply to #125
04/17/2009 4:36 AM
So a (minor?) cause of the "global warming" maybe due the enlargement of solar "wind" particles hitting the atmosphere?
Good Answers: 109
#128
In reply to #126
04/17/2009 6:15 AM
Most experts think that the solar wind is responsible for some cooling,
as there are more condensation nuclei to form clouds and thus enhance reflectivity of earth.
But atmospheric physics is a difficult topic as more clouds will also block infrared radiation or cooling at clear sky.
So in total it may come out as an equilibrum of daytime to night-time cloudiness.
Cooling opr warming may be possible.
RHABE
Good Answers: 38
#132
In reply to #128
04/19/2009 9:17 PM
Thanks i am not an expert on Solar winds
Good Answers: 109
#127
In reply to #125
04/17/2009 6:10 AM
Thank you for the link, very good information.
RHABE
In reply to #127
04/17/2009 6:46 PM
Same link I gave you. So, any ideas for titles for a new thread, or should we just call it over?
04/12/2009 2:13 PM
Hi Roger,
I have more on the lack of consensus about global warming. The following link has the names of 690 scientists from 404 separate research institutions in 40 countries that disagree with you. Please watch the video that has a graph:
http://www.co2science.org/
Here is another one with a video with graphs. It point out that the CO2 is not the cause, but the effect of the global warming.
http://www.youtube.com/watch?v=iMDi_u0dcig
Here is more about the sun's magnetic field affecting earth's climate:
http://www.cgfi.org/2007/07/26/water-experts-find-earths-warming-rainfall-linked-to-sun/
Some highlights are: "…They say variations in South African rainfall patterns are keyed to periodic reversals of the sun's magnetic field—and to the constantly changing distance between the sun and the earth as both move through space."
"Earth's recent global warming occurred too early—before 1940—to be blamed on human CO2 emissions. The net global warming since 1940 is only 0.2 degrees C, with none at all since 1998. There's little correlation between the earth's recent temperatures and CO2 levels, but a strong correlation between the sunspot index and subsequent changes in our sea-surface temperatures."
"The evidence for a sun/climate connection keeps pouring in, while all we hear from the Kyoto crowd is "The computer models agree with each other."
With your knowledge of statistics, the word "correlation" in paragraph 2 should be significant to you.
The sun's magnetic field affects the rotation of the billions of tons of metal in the earth's core. That, in turn, can affect the activity of volcanoes (that, BTW, produce CO2). Here is a link about volcanoes and ice melting:
http://www.environmentalgraffiti.com/sciencetech/volcano-not-global-warming-effects-may-be-melting-an-antarctic-glacier/714
With all these conflicting "facts", what are we to believe? Convince us that your "facts" are really the facts.
-S
Good Answers: 93
#93
In reply to #92
04/12/2009 3:10 PM
Dear StandardsGuy, I feel you are close to convincing yourself that essentially Roger is correct. Now I have noticed that predictions made in the 70s about Global Conditions seem to have been borne out.
My education is a bit odd. I had a job once recording an entire series of ecology lectures at UNCG, so though I was not a "student", I did end up listening to the entire course. From what I can tell this university level was of the same caliber that Mr. Gore was exposed to at Harvard.
In the end what I took away from all the information was that where we needed to be most concerned, and it was vital that if we wanted to survive as a species, we needed to pay very close attention to effects of what we did on the oceans, and the food chain there.
Hence when discussions of Global Warming, Climate Change, or even weather come up I pay particular attention to reports on the conditions in the seas.
As a bottom line I want to know if the seas are rising. To my simple mind if they are, this is evidence of Global Warming.
Now even if the oceans are not rising the second thing I am concerned with is whether or not basic foundational food creatures of the ocean food chain are being diminished.
Are the oceans rising?
Seems like I heard that they were.
How many of us on this particular Blog Thread agree that the Oceans are rising?
You don't get wise because you got old, you get old because you were wise.
The Engineer
Good Answers: 129
#94
04/12/2009 11:51 PM
I'm moving on from this thread. I simply don't have the time to debate three different people. Many points being brought up now I've addressed multiple times on multiple threads. Others are new and should be addressed, but I'm not getting paid for this, and lets face it, I'm not convincing any of you of anything. I wish I did have the time for the interactions, but I just don't. I'll see you guys around cr4. I'm sure we'll probably pick up this never ending debate in another thread.
In reply to #94
04/13/2009 1:33 AM
Sorry you are leaving. I'll miss you.
All the best
The Engineer
Good Answers: 129
#105
In reply to #95
04/13/2009 9:54 PM
Thanks man. It's been a real pleasure interacting with you, but I don't think I'll be doing it anymore. You're a little too much for me to handle. I'm going to run back to my ivory tower, sit around and group think with the other scientists. Send my regards to S.G. and his ancient Egytian map with the ice-free Antarctica on it. He's a rock in the foundation of your CR4 consensus.
In reply to #94
04/13/2009 7:25 PM
Seriously?
The Engineer
Good Answers: 129
#104
In reply to #100
04/13/2009 9:45 PM
Seriously?
04/13/2009 1:46 AM
I think one obvious thing to emerge so far from the discussion is that support for anthropogenic global warming is far from unanimous among the scientific community.
Our politicians should be cautious about following the IPCC because threre is considerable disagreement among scientists about the validity of the IPCC reports.
Precipitate action now could have the world economy stuffed for years to come.
I suspect man is still too small to be able to make a significant alteration to the long term climate. (That last suspicion is not a majority conclusion from this discussion but more in the nature of a private opinion).
Personally, I think one good thing to come from this is the emphasis being placed on more efficient use of our resources. When global cooling commences (probably within the next 20 years, although the Russians seem to believe within the next decade), I hope we don't lose this efficiency emphasis.
We need to continue debating this issue, not to change other people's minds as more to bring additional facts to light.
I have certainly learned a lot from it.
The Engineer
Good Answers: 129
#97
In reply to #96
04/13/2009 8:06 AM
You Wrote:"I think one obvious thing to emerge so far from the discussion is that support for anthropogenic global warming is far from unanimous among the scientific community."
I don't know how you can possibly write this as a conclusion of this debate. I provide a link below that shows that, far from your conclusion, there is consensus among the major scientific societies which has been demonstrated by their official statements on the subject.
http://en.wikipedia.org/wiki/Scientific_opinion_on_climate_change
I find it insane that I have to address "facts" like Mars Temperature is rising over and over, and even after you yourself admit on another thread that I had probably convinced you (which is no small feat), you don't so much as utter a whisper when it was brought up by standards guy in this thread. When things like this occur, it reminds me that this isn't a debate for the truth, rather a debate to win an argument.
Go ahead and review this thread and imagine the hours I would have to put in in order to address all of these points being raised. Points I have addressed in many other threads in the past and some already in this thread. There is a difference between debate and filibuster.
In reply to #97
04/13/2009 6:56 PM
Roger
I don't see how you can see the divergence of opinion among the (generally well informed) CR4 community and say there is consensus.
Evidence has been produced of dissenting views from scientists working in the field, yet you still try to pretend there is no dissent!
I follow the chain of evidence as best I can. That is why I back pedaled on Mars warming. I didn't reply because I knew you already had a quick reply handy, and I was working on other streams of evidence, some of which I will be bringing up shortly, when I get the time. For your peace of mind I will find the answer I gave on this on the other thread (I forget which one it was now) and repost it here shortly.
There is ample evidence that the IPCC reports are primarily political, masquerading as science.
The fact that the temperature curves they use don't fit documented historical evidence should be enough warning, but to find the pre industrial CO2 levels quoted are the result of selective use of available figures, and that the real pre industrial average could be higher than we have now definitely robs the IPCC of all credibility.
You mentioned earlier that the speed of temperature change is unprecedented. The fact that we have frozen carcases of woolly mammoths shows that climate can change very rapidly and that this rate of change is only rapid measured against a particular set of assumptions. The mammoths show these assumptions to be dubious.
AGW is basically a result of "group think" rather than reliable hard evidence.
The more I have investigated this, the worse the case for AGW becomes.
The Engineer
Good Answers: 129
#103
In reply to #99
04/13/2009 9:24 PM
We are never going to agree on this.
In reply to #97
04/13/2009 7:43 PM
Did you even read my posts?
"I provide a link below that shows that, far from your conclusion, there is consensus among the major scientific societies"
Your own link has lists of dissenting scientists with high credentials, and lots of them!
"fact after fact after fact"
Say what? As they say "put up or shut up". well I guess your shutting up.
Good Answers: 38
#102
04/13/2009 8:34 PM
Roger interesting thread but one notion, you link wiki too much, wikipedia is great for basic information, but a highly debated thing like "global warming" doesn't give the wiki links much value as any pro- or contra- global warming scientist can change the wiki-page.
IMHO it is better to give links to the scientific papers themselves it give your replies more weight
04/16/2009 8:36 AM
A few more problems with AGW
http://www.physorg.com/news3694.html
Here the authors point out that the climate models were wrong in their handling of the cooling and rebound to normal temps from the Mt Pinatubo eruption in 1991.
If the rebound to normal was far faster than any models predicted, there must be mechanisms working which the models are not taking into account.
http://www.geocraft.com/WVFossils/greenhouse_data.html
This points out that anthropogenic greenhouse gas contribution accounts for 5.53% of greenhouse contributions if water vapor is ignored.
Total effect of CO2 is 3.62% of total greenhouse effect, if water is ignored.
If water vapor is taken into account, total anthropogenic effect is 0.28% of the greenhouse effect. Of this anthropogenic CO2 contributes 0.117%.
When this was pointed out, a spokesman for the IPCC said it was customary to ignore the contribution of water vapor! (How effective can any computer model be if the dominant effect is ignored?)
If CO2 is operating as a greenhouse gas, it works by absorbing long wave radiation from the earth and re radiating it. About half of the re radiated heat returns to earth. Note that the CO2 must first heat up, ie the atmosphere must heat up before the surface.
In fact, satellite measurements show no atmospheric warming, only surface warming. (I had an excellent reference for this showing NASA satellite data. My magnificent "filing system" has lost it. It will turn up when it is no longer needed.)
Then there is the lack of correlation of temperature rise with CO2 rise.
Assuming the normal temp curves are correct back to the 1880's, and the CO2 measurements back to then are correct, (a previous post of mine casts considerable doubt on these assumptions), then 1880 to 1920's temperature rise lags CO2.
1930 to early 1940's temperature rise leads the CO2 rise.
1950's to 1980's it lags CO2 again as temperatures fall then rise.
1990's to 2007 they rise in step.
2008 was the coldest year in the US in 128 years, so AGW proponents leave it out of their figures. (It may well be a simple anomaly of no relevance to the subject, but it should at least be shown).
It appears the physics of AGW change with time, here lagging, there leading, there in step. In short, a science of variable constants.
Of course if AGW proponents admit that other factors were responsible for these anomalies, they then lose the argument for AGW, as it is obviously only a minor influence.
To return to the theme of melting Arctic ice, it should be noted this is a Northern Hemisphere phenomenon. The Antarctic ice has been thickening.
This would indicate, not global warming, but a redistribution of global temperatures.
Because most measurements are taken in the Northern Hemisphere, this would readily lead to the assumption that the entire globe is heating.
If the Russians are right and we are heading for global cooling within the next decade, I wonder what the IPCC will say?
Good Answers: 109
#116
In reply to #115
04/16/2009 11:38 AM
Hi Sceptic,
thanks for the data on CO2 and water on greenhouse effect. This helps a lot with arguments. (GA).
We can only speculate why this is not known widely.
The references are from so many different well reputed sources that there can be little doubt.
"To return to the theme of melting Arctic ice, it should be noted this is a Northern Hemisphere phenomenon. The Antarctic ice has been thickening."
This statement you made is explainable if you think about Antarctica and the nearby oceans are also warming, more evaporation will result, that will yield more snow over regions that stay -despite warming- below freezing point thus accumulating ice.
This happens in regions that have been very cold with not much snow.
Now developing into regions that are not so cold and get more snow.
So although warmer there will be thicker ice.
I never heard about estimates how much of the snow is going to be transferred to ice, how much is evaporated, how much is molten in contact with warmer ground and in antarctic summer.
RHABE
In reply to #116
04/16/2009 8:42 PM
Hi RHABE
I initially thought so too.
Apparently Antarctic precipitation has stayed similar for the last few years, but the ice has been thickening, therefore there must be less melting.
In addition, temperatures have been down rather than up.
Of course warmer oceans some distance away could still cause increased snowfall, but this doesn't seem to be happening.
The concern of the 1990's that Antarctic warming was increasing has since disappeared. You'll notice that it rarely gets a mention now.
Sorry not to include a reference to support this. I'll look one up and post it when not so rushed.
(BTW is there a treatment program around to cure people of CR4 addiction? I think I've got it! or or ?)
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
In reply to #118
04/16/2009 9:52 PM
"(BTW is there a treatment program around to cure people of CR4 addiction? I think I've got it! or or ?)"
I almost wish there was. I tried going cold turkey but only lasted about 2 days. Maybe we should form a support group.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Good Answers: 38
#120
In reply to #119
04/16/2009 10:25 PM
Or a new topic?
In reply to #119
04/17/2009 3:31 AM
I thought that was what CR4 was for, or is that the response of a true addict?
In reply to #124
04/17/2009 1:56 PM
Sorry,
They don't exactly have a smiley for tongue in cheek, unless maybe this one .
In reply to #118
04/16/2009 11:16 PM
"(BTW is there a treatment program around to cure people of CR4 addiction? I think I've got it!"
Me too, otherwise why would I jump back into a topic I said was a dead horse?
Help somebody!
04/17/2009 8:24 PM
Hey guys, why don't we switch to this one or this one? Watch out though, the second one doesn't want any extremists, and Riger Punk has been there!
2tinker (1); agua_doc (1); Anonymous Poster (12); Bayes (33); bwire (4); Delmar (4); dkwarner (1); edignan (2); emc_c (2); Epke (8); HoleInTheSnow (1); marcot (2); North of 60 (1); palinurus (1); PWSlack (1); RHABE (11); sceptic (19); Shadetree (2); StandardsGuy (17); Transcendian (5); U V (4)
