Previous in Forum: Graphite Dust Explosion Potential   Next in Forum: Plastic Beverage Bottles
16 comments
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Specifying Water Treatment for Release into Mains Drainage
09/22/2009 8:54 AM
Hello Guys - time for me to ask a question.
We are developing a new process (patent pending) for cleaning diesel particulate filters (DPF). The result is a water stream with both solid particles and dissolved chemicals. At the current location of the test site (West Midlands, UK), the local water authority is happy to treat the water (at a cost) after it's been through a settling tank with an oil scoop. Sorry, I have no more details than that.
A pair of us "back at base" have been tasked with taking another look at the waste water treatment: Do we have to treat the water ? What will it cost ? What equipment do we need ? Yup, that's our brief - so we're writing our own scope and a specification to go out for tender and that is where I need help. Neither of us have any waste water treatment experience, so I'm after some pointers.
I'm going to divide my questions into the groups that I see to try and keep things clear.
Regulations
We've been told that regulations vary from UK Water Authority to UK Water Authority as well as across national boundaries. The first sites will be in the UK, but the intention is to roll this out across Europe.
Are tales of this plethora of regulations / requirements true ?
Is there a central source of regulations ?
Is there a central point of contact for the water authorities within the UK ? (Is it OFWAT ?)
What are the appropriate EU Directives ?
Input Information
As with any engineering project, I know that the more the better, but what information is necessary for a prospective supplier to make a good judgement on a budgetary figure for a treatment plant ?
We can supply
  • expected water usage per cycle (50 litres)
  • number of cycles (60 per hour)
  • average TSS
  • some info on chemical composition
  • a figure for COD
  • particle size distribution
Is there anything that is needed?
Recirculation
In order to reduce the clean water usage, we would like to be able to recirculate the "filtered" water. One report we have says that the high sulphate and silicon content of the water may inhibit further use. How can we deal with this ? Is this likely to prevent us re-using the water ? Can my questions get vaguer?
Sludge Disposal
The sludge will have a high carbon content, plus other combustion products. We estimate that in the first few years, 50 - 200 tonnes/year may be collected, across various sites. Are there any viable alternatives to landfill for its use? I don't think there's enough to interest a power generator, so I wondered if anyone had any novel ideas.
I haven't asked for specific solutions as we've decided that we should let the tendering companies decide and justify their choices. What we what to be clear about is how we explain what we're starting with and how to define what we want to end up with. I don't believe we need to end up with potable water - just with water that's clean enough to use again or clean enough to go "down the drain".
Thanks in advance for the help.
Chaos always wins because it's better organised.
Re: Specifying Water Treatment for release into mains drainage
09/22/2009 10:25 AM
You might want to consider the footprint. Settling tanks, clarifier's, or membrane filters are going to take up a lot of real estate.
Sorry I couldn't help more. Good luck!
Good Answers: 75
09/22/2009 11:46 AM
Thanks kilowatt - I think that will frighten the bosses (if not the horses!).
Good Answers: 97
09/22/2009 1:41 PM
About discharge standards : The UK should have some.
Even SA will eventually have a standard.
You could also contact the World Health Organization for a more global approach.
I seem to remember that the US raised their standards recently - You may have to be prepared to design at higher than regulated standards.
About disposing
There was a study done in SA under the Water Research Commission (2005) and it proposed a lot of measures to dispose of abundant supply of sewage sludge including for example mixing it with clay to produce bricks. But you need to analyse the composition and determine some solutions.
Good Answers: 101
Re: Specifying Water Treatment for Release into Mains Drainage
09/22/2009 11:28 PM
Hi Rose,
Yes, wastewater treatment is required for your plant. Aside from the data you can furnish, please also furnish expected discharge effluent quality. I design such systems for a living, and if you can furnish the data I requested for, I can design a system for you so that you can get a better estimated quote from your would-be vendors.
"One report we have says that the high sulphate and silicon content of the water may inhibit further use"
Precipitate them out with lime. The good thing about this process is that you can recover valuable calcium sulphate (gypsum) and calcium silicate that you can sell off to defray the cost of the treatment process. You can reuse the water after this.
What can you do with your sludge? That depends on its exact composition. If there's nothing toxic in it, it can be subjected to anerobic decomposition or composting. If it contains toxic substances such as heavy metals, you'll need to get a toxic waste disposal specialist to remove it. Let them worry about what to do with it if this is the case.
Feel free to contact me if you have further questions.
Good Answers: 75
09/23/2009 5:13 AM
Hi Darth,
How's the asthma?
That's one of the things I'm trying to find out. The Water Authority that deals with the test plant waste is happy if we take out the solids and skim off the oil. Bar phoning each individual Authority (don't fancy doing that across Europe), I don't know where to look for legislative minimum standards.
Thanks - I wondered if you could be "that simple" . I think the issue we'll have with selling off by-products is the low quantity, but it's good to know there's a market if quantities increase.
Sludge
Type 1
  • Mostly inorganic carbon, with some organic carbon ( in the form of HC), other trace elements.
  • 4.8 < pH < 5.4
Type 2
  • 60% Iron Oxide
  • 20% Carbon & Sulphur (LOI)
  • 17% Calcium Oxide / Phosporus Pentoxide / Zinc Oxide
  • Trace elements
The two will be mixed, Type 1 predominating. Specialist disposal is looking favourite - especially in the quantities (50 - 200 tonnes/year total) we're estimating.
It would be good PR if we could show that the waste is going somewhere useful (gypsum, road tar, power generation etc) as the DPFs are pollution control devices...
Thanks again, I'll be back (sorry wrong film...)
Good Answers: 101
09/23/2009 12:11 PM
Hey, I like the Terminator movies myself. Actually, I'm not asthmatic; the reason why I wheeze is because I breathe through an air pump.
Okay, your basic process should go something like this.
Influent → sedimentation → oil skimmer → lime precipitation → coagulation → flocculation → clarification → pH balancing → effluent reuse. The accumulated sludge in the clarifier should be pumped into a sludge thickener before being pumped into a filter-press prior to final disposal. A word of warning: oil and lime don't mix. You'll get a really horrible sticky mess if they do.
Going by the contents of your sludge, it would be best to let a toxic waste specialist deal with it. They'll probably sell off the sludge for roadworks or construction or something similar.
Glad to be of help. I guess my mom was right when she told Qui-Gon that few things make me happier than being helpful.
Good Answers: 94
09/23/2009 12:25 PM
I was listening to John Lennon singing 'Give Peace a Chance' as I read this & it fitted the music quite well.
Good Answers: 75
09/24/2009 3:40 AM
Thanks Darth, that's really helpful. The tip about oil and lime is noted !
You know, not everything Obi-Wan said about you was true
Good Answers: 94
09/23/2009 5:04 AM
We also end up with water waste with particles in, mostly phosphor but, because it is used in very small quantities the outfall is also small. The local water authority insist that we settle out the solids which we do with a settling tank. This tank is just a domestic cold water tank baffled into a series of compartments. The quantity we produce is so small that, after several years of using this system, we have not yet had to deal with disposing of the solid waste. We are aware however that the local water people regularly take samples from the drains to ensure that we comply.
Good Answers: 75
09/23/2009 5:17 AM
Thanks Nigh. One of the things we have been told is:
"Water Authorities make their money treating water...so let them do it and just pay the disposal premium."
I want to keep with this, we just need to understand what the minimum is we have to do and how to do it economically to the quantities we're dealing with / expecting to dealing with in different locations.
Good Answers: 42
09/23/2009 10:11 AM
English Rose,
Water from your cleaning plant need to be taken and all possible parameters and characteristics need to be analyzed and then comes the apt treatment process setting, the cost of which is bothering your end it seems.
I have an alternate suggestion- if your cleaning fluid can be replaced by a non pollution prone fluid, will it be acceptable to you?
If your answer is yes, Now I would recommend you to go for the air based cleaning process since Air does an excellent cleaning job and escaps away with out any suspended or dissolved pollutants. Think and try out this option to solve your water treatment problems.
I have no idea about diesel particulate filter, which may have to be borne about.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 75
09/23/2009 10:57 AM
Thanks for your comments - unfortunately air cleaning will not work in this case, it has been tried. Diesel soot is quite "sticky" and air is not able to remove enough of it from the substrate pores.
Water does a very good job of cleaning the filters - it's finding appropriate cleaning methods for the used water that is needed. This is outside my field(s) of expertise, hence asking for help.
The water does NOT need to be potable at the end, just suitable for mains drainage disposal or re-using in the cleaner.
Thanks again, I'll post updates.
Good Answers: 109
09/23/2009 8:58 PM
Great question but very open ended. I would check with the local utility for sewer use bylaws that may provide you with targets for treatment. The BOD and COD levels will be specified in any use bylaw. With regard to volatile compounds, most do not have any tolerance. The utility will worry about gas build-up in manholes and mains. Related safety is a serious factor. I am not sure of the type of treatment that will be required but air stripping could be a consideration. The volumes of treatment are low and hydrogen peroxide/activated carbon could be a good polish after removing the big gunk. Sorry I cannot be more specific.
Cheers and good luck
Good Answers: 75
09/24/2009 3:46 AM
hi Kevin, thanks for the tips. I was hoping someone could point me to a central source for by-laws, but it seems that was hoping for too much. I should have known: the UK Statutory Instrument amendments are not kept together...it's a miracle anyone knows what the law actually says....
If we can reuse the water, with losses being in wet filters that air dry by evaporation; wet sludge and general evaporation, we may be able to avoid the drains entirely, which would simplify things in one way by avoiding local bylaws. We'll be able to assess that once we have quotes and understand the complexity of the treatment plant.
09/28/2009 11:49 AM
Check out the discharge consents already in place at each facility where it is intended to operate this process, as consents vary from location to location within the same Water Authority's district. Local offices can advise as appropriate. If the additional load on existing facilities were not to send it out of consent, then no additional treatment is necessary.
If the added materials sends the combined effluent outside the pH limits, then add either acid or alkali to bring it inside as appropriate, ensuring that the pH instrumentation is linkable to an appropriate calibration standard at appropriate intervals. Some tankage might be necessary to achieve this.
Consider blending the new stream with other existing streams, as the combined stream may require less treatment than the original, with savings to both facilities. This technique is already done with a factory and a hospital in South Essex.
It depends upon what is present in the "chemicals" as to whether or not any additional treatment is required in each case. Of particular concern are turbidity, heavy metals and oils, and these parameters will be stated in the discharge consents.
Maybe it is time to open a dialogue with a specialised treatment company?
It is way too soon to provide "a budgetary figure for a treatment plant".
Good Answers: 75
09/28/2009 12:10 PM
Thanks PW.
I wanted to understand more (something) about what was required before we did that ... currently working on the RFQ to send out.
I was after understanding what I needed to tell the specialist company so that they would be in a position to give us that - we're now thinking that "total" recirculation is the way to go.
Register to Reply 16 comments
DVader1000 (2); English Rose (7); Hendrik (1); kevinm (1); Kilowatt0 (1); Nigh (2); PWSlack (1); s.udhayamarthandan (1)
