Previous in Forum: What Does That Sentence in Bold Mean?   Next in Forum: about energy consumption in whole life cycle of compact fluorescent lamps
Wind Turbine Blades
11/21/2009 12:07 PM
I have recently designed a set of blades that self feather when the wind gets too strong.I have them attached to the hub in such a way that the presure of the wind can feather them. I have them spring loaded to return to their original position when the wind dies down. I am curently trialing them. So far they are doing what I expected of them. They start up in very low wind and reach a maximum speed based on the strength of the springs. I am still at a trial and error stage with the tensioning of the springs.
Has anybody out there ever tried this design of self feathering blades. I would appreciate any input please.
Re: Wind Turbine Blades
11/21/2009 12:57 PM
and
spring load. what I see can be one of the problems is that it wold build a resonance and basically be uncontrolable.
IMO, A mechanical governor type of control......I do not think you would have enough mechanical advantage for this.
p911
Good Answers: 93
11/21/2009 3:00 PM
Have you looked at complex propellors for aircraft, or now ships?
It has been awhile since I flew so I haven't flown a craft with auto feathering capability, though I imagine there is a system around by now.
If it is working for you, good.
You don't get wise because you got old, you get old because you were wise.
Good Answers: 109
11/22/2009 3:38 AM
Hi,
around which axis are the blades moving if the "self-feathering" is working.
This axis can be oriented parallel to the length of the blades, turning the blades to give lower torque,
or this axis may be oriented perpendicular to turbine and blade axis, folding the blades back to result in lower air-flow within blade area and thus lower torque.
The first version is speed limited by centrifugal force, the second one can go up with speed if folding back the blades.
Any orientation inbetween may be useful too?
Next choice: do you like the the force that operates your mechanism be derived from the centrifugal force or from drag or lift?
I never worked on a mechanism like this but on many other flexural devices so this is interesting me.
(Previous work was on precision instruments.)
Last question: do you like this mechanism to act in a linear manner or like a trigger and complete shutdown if the set-point is reached?
RHABE
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
11/23/2009 5:36 AM
I have heard of a similar system some years ago, but I have completely forgotten the reference.
India - Member - ROBOTICS Engineering Fields - Marine Engineering - New Member;I believe in integrating several disciplines of engineering.
11/24/2009 10:33 AM
Why not use a simple anemometer input to a simple Controller with variable set limits (Upper/Lower wind velocity) to trigger the feathering mechanism?
D.Ramakrishna Naidu
Design & Build HOMOPHILIC Suprahuman ROBOTS
Hobbies - Musician - Guitar and Banjo Engineering Fields - Construction Engineering - Project Engineer Engineering Fields - Piping Design Engineering - New Member Popular Science - Evolution - New Member Popular Science - Cosmology - New Member
11/24/2009 10:58 AM
Standard modern turbines all pitch the blades in high winds. Since pitching requires acting against the torque on the blade, it requires some form of pitch angle control. Many turbines use hydraulic systems. These systems are usually spring loaded, so that if hydraulic power fails, the blades automatically furl. Other turbines use an electric servomotor for every rotor blade. They have a small battery-reserve in case of an electric-grid breakdown. Small wind turbines (under 50 kW) with variable-pitching generally use systems operated by centrifugal force, either by flyweights or geometric design, and employ no electric or hydraulic controls.
Register to Reply 6 comments
Chankley (1); D.RAMAKRISHNA NAIDU (1); Don103 (1); phoenix911 (1); RHABE (1); Transcendian (1)
You might be interested in: Wind Turbines, Torsion Springs, Saw Blades
