Previous in Forum: Toyota Pickup Trucks - Not a Tacoma?   Next in Forum: Auto Repairs and Diagnostic Codes
Linear Actuator for Continuously Variable Transmission (CVT)
12/29/2009 2:57 AM
Hi, I need a linear actuator for a Continuously Variable Transmission (CVT). The CVT is intended primarily for automotive use but is applicable to anything or any size requiring a transmission. With the primary application being automotive, this makes for some quite wide ranging operating conditions: - 12 VDC + 6VDC / - 4 VDC These ranges are typically encountered in 12VDC automotive environments. - Wide temp range: -65C (environment) ~ +300C both from the heating of the lubricant due to loading and the proximity to Exhaust pipes. - Compact: except perhaps for an external stepper motor on one end, a shaft extending out from either ends of the transmission casing is unacceptable. This is also unacceptable because of the very dirty operating environment. - Needs to be very fast acting and have a very high duty cycle. The acceleration and linear movement speed will be a challenge to the most obvious solution of a lead screw. - Requires that a linear accuracy of +/- 0.005" be maintained over an extended lifetime of at least 20 years. Preferably it will have (self) correcting positioning from measuring and feedback to compensate for wear etc. - Rotational movement: there is very little tolerance for this in the components with linear movements either initially or at the end of its life cycle. I would think that +/- 0.002" of rotation would be the maximum tolerable. - Low cost Having been a mechanic and a millwright for over 40 years and a machinist for ~ 15 (overlapping) I'm well aware of the utilization of lead screw arrangements. The primary problem I see with this is the significant loss of accuracy of the linear placement both initially and increasingly over an extended period of time due to wear. Also the tendency to impart a rotational movement to the linear components is detrimental. ~ 10 pounds of force in linear motions should be sufficient. The highest force that will be encountered will be due to cold temperatures and the resultant increase in lubrication viscosity. As referred to above, linear accurate positioning with active feedback and correction both initially and for the duration of service is desirable, however cost and environmental conditions are significant factors and limitations. Operating inside of a transmission with lubricant being constantly thrown around vigorously would seem to rule out anything optical for positioning, feedback and self correction sensing and adjustment. Though the linear components will have movement in both directions. However a slight 'over shooting' and reversing of the linear placement to correct for this is not tolerable primarily due to time constraints. Thanks to one and all for any assistance that you are able to offer.
"‘Mathematics is the language with which God hath wrought the Universe.’ Ancient Greek Mathematician_-_ CKUA.Com 'Eclectic music at its very best!’
#103
In reply to #87
Find in discussion
Re: Linear Actuator for Continuously Variable Transmission (CVT)
01/14/2010 6:51 AM
Geeze I hate it when I make a SNAFU and lose all or significant portions of things such as this. I usually do them in Word with its excellent auto-save features. Especially as I am very slow at doing them. I also very much dislike having to do the same thing twice so when it happens either I just say to hell with it or recreate and less comprehensive abridged version )< 8(
Hi GarthH et all.
My PopUp blocker must be doing what you are referring to as I have no such 'rectangular box' in he upper corner nor the '+' sign to try and locate, expand and view specific new postings with either.
I have never been overly monetarily motivated and also the older I get the less I can relate to the 'wage slave' thing.
My health cratered rather badly a few years ago and because of this attitude and aptitude I am now paying for it (pun intended) and live in abject poverty so I have very little extra 'up time' and even less money in trying to get these things happening with. I am now in significant debt for my income level from trying to get this happening and I currently have no surplus income to get this happening, including generating income to do this with, but as I said in a previous posting, I am working on that as well.
Like most other 'human' beings I have a fairly basic desire and need to 'contribute' and our world is in a crisis that can not be over stated. So in some ways I'm torn between just publish everything as opposed to taking the proprietary patent route, but as well as needing some security for my old age if I should need it (which is looking less likely) as well as wanting significant funding for other similar project, some of them considerably more fundamental including some that will need some pure scientific research if they are to succeed. Some of them are such that if I am able to manifest them, unless I take steps to protect my self form it, I would never be around long enough to get them anywhere near being well established and globally available. If some of my more basic inventions such as this CVT, very low cost, simple, low part count, very compact flexible IC engine /pump, very high power to weight ratio and is well as having many other applications including as realistic contender to making a personal (urban) transportation mass market vehicle a reality.
I think it is quite likely that we may be somewhat similar and that we are capable of doing so many different things that we don't bring in others to help when it could be beneficial as you have pointed out. Having such capacity like many things is a double edged sword: and can tend to render us, or me in particular anyway, ineffective from being spread to thin and trying to do to many things at once and hence never really accomplish anything.
One event in my past that came about as a necessity in a court case over custody and access to my youngest son was that I was the subject of a quite intensive and in depth 'analysis' of me on numerous levels. The professional in charge of this was quite surprised at my response when they asked me what faculty would I enroll in if I returned to university. My response was an MBA. As I said, given my attitudes, activities and interests they were quite surprised and asked my why. My reply was that I already knew and understood most of the things that I wanted to do, and that when I needed and Engineer to calculate and optimize designs for appropriate material, dimensions etc I could readily hire one. But what I don't know how to do, or haven't done so far is how to get from where I am at to where I want to be and that this required 'business and finance' to get it happening. While I have experience at and am very good at middle management, as far as being 'the source person' that gets it going from the complete starting point where there is basically nothing and make it into something very substantial and successful. A significant part of this is primarily interests and aptitude. I have never been very monetarily orientated, and frankly the older I get the less I can related to being a 'wage slave'. This has resulted in me being in the dire financial circumstances and position that I am now in: living in poverty on VERY low income and significantly in debt for my income level trying to get these things going. An obvious answer is to obtain investors, but frankly I'm to busy and to disinterested to take the time and energy to climb the learning curve necessary to even do a proper business plan. I am open to taking an 'angel' on as the finance & business end of it, but at this point in time anyway and where I am on the process, I am not going to give up almost entirely everything to obtain venture capital etc. This may change under the right circumstances and as I said there is a VERY good opportunity for the right 'angel' and I would limit it to (this) specific project and not to all of my inventions, ventures etc. I plan to have them all be entirely separate corporate, LLC ventures as much as I can. However, depending on (personal) changing circumstances, by necessity I might be willing to give up a significantly larger portion of this initial project that I am very much counting on being a spring board. I have chosen this project as being my initial 'spring board' very careful as it is the one that is substantial enough to generate significant enough revenue to start to get some of the other major ones underway and in place, but requires the least R&D, including financing and that can be done the quickest and being utilized on global mass markets the fastest. Also, though I am a little late with it, now is a good time for this CVT. My engine likewise though I would of liked to have it market ready 5 years ago.
I have a number of much smaller mass market items that if I can 'get around to it' and fine the right business, money, marketing and sales partner I may take one on to get these happening. Obviously I would have to finalize the design, though most of them are very rudimentary and are basically done. I would just have to make a detailed drawing for production, and if necessary will handle the 'supply' end of it. These is another low end 'mass + vertical market' item that require very little investment other than (redoing) the deign which is quite involved and finicky. Also there are several 'variations/models' that this can be transposed to target specific sectors of this vertical market. It would require variations some further specific research for each segment and suitably modifying the original design. This would take some time but significantly less that the initial finished design.
When I get this one 'up and running including patented, in order to establish some presence and credibility I may manufacture some for industrial applications such as HD portable duty welders and compressors as well as larger stationary industrial applications. It design is such that this could be accomplished without a lot of specialty machining capacity that generally is only found in mass market auto manufacturers. I have good CAD software as well as CAD-CAM software that covers every available CNC controller, and can easily and cheaply get one made for it that are not currently available if I need them. The design is such that though it would require some capital to start small scale manufacturing.
If I get to the point where I am running out of time to manifest these things, which is looking more likely, then I would try to establish a 'for profit' foundation to try and get them manifest posthumously. There are some others that are at a far more basic level and will have even more of an impact on transforming power production and applications on a global scale which are very badly needed. Because of this I may not patent these but publish them regardless of me still being here this time around or posthumously. This may be necessary regardless due to their potential scope and scale and the major disruptions and devaluations of other VERY large global monetary interests as otherwise they may never see the light of day. I'm not being paranoid, just realistic.
One of the reason I have not published such things other than the obvious ones of that I want to be the one to manifest them and perhaps benefit from them is that I need to get some of these other things that I am currently working on is to establish some credibility otherwise the could quite likely just be dismissed and something very important on a much larger scale other than my own personal one.
Got stung again! I redid the start of it and now for some reason the end of it is missing! GRrrrrr.... )< 8( Maybe one 'Can't teach an old Doug new tricks'!? That better not be the case or I will never get any of this accomplished and pack it in!.
Regards,
Doug
Engineering Fields - Nuclear Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: From going to and fro on the peninsula and walking up and down on it
In reply to #103
01/14/2010 8:10 AM
hi doug,
just read your latest post. One of the most important things you've got going for you is your sense of humor, don't lose that.
Not to diminish your other talents, but being able to take life's little annoyances on the chin with a chuckle is a great strength and resource.
Maybe Johndg could advise you on wrestling with the Cr4 posting nuances, he's pretty good at helping sort that stuff out.
Keep at it,
Packrat
oderint dum metuant
#110
In reply to #106
01/14/2010 2:45 PM
Hi PR,
Thanks, you've got that one right. By virtue of the fact that you realize it makes it very likely that you have as well. (< 8)
I can't remember what it was, but some time ago when I was watching and 'adult' AV drama of some sort: Not 'porno' but the demographics for Hollywood take a huge drop of at about 20 ~ 25. As Sisckel and Ebert knew only too well and often pointed out: 'Holywood makes movies for kids, Europeans make them for adults'. Anyway, in one scene, (one of ?) the main characters is dying in his old age. His beloved mate of his entire lifetime is at his death bed sobbing. He replies to something she has said with 'Heavens no, I'm only dying, but to lose my sense of humor WOULD be serious!' (< 8)
Have a better one!
Regards,
Doug
Good Answers: 114
#107
In reply to #103
01/14/2010 12:10 PM
I use a laptop & from time to time was frustrated by losing all or parts of posts. I finally figured out my hand was brushing the mouse pad as I type & that I could retreive the missing comment with the back or forward buttons...
You can compose on word & copy/paste the entire contents in the CR4 reply box
You should edit your profile:
Off-Topic Comments
How should off-topic comments be shown?
I want off topic comments to appear like any other comment
You'll find that there aren't that many off topic, usually just a bit of cross talk or chit chat... many time better than the actual discussion
I feel your pain on the life/health/finances front...
I don't have a solution, I tried what you are attempting [bootstrapping] & it was going well until I[we] got tripped up by circumstances & bad timing. I too had picked what I considered to have the best chance of success, hoping to built on the credibility gained. You have at least outlined & backed up you potential solutions, haven't you?
The patent process only provides protection equal to your ability the afford legal representation. Venture capitalists are held in similar esteam to lawyers & whale shit
You need a partner in which you can trust whose skills compliment your own. I don't have a suggestion in that regard. These are all common themes, often repeated on this site.
One more shot on my twist on the original problem... 2 racks, one for neutral positions & one for engaged positions. I would consider blinks opinion of the actual number of ratios needed to be correct. Limiting to say 20 would help redefine the problem to a more manageable level. Your short term goal is to have a working prototype to shop around.
#109
In reply to #107
01/14/2010 2:34 PM
Hi GarthH,
Thanks for the configuration tips, I've made the changes thanks. Will worry about and decide about the cookies latter.
I usually do them in Word but get caught out once in a while.
I use a 3 button tack ball and have global muscle tremors and the buttons are very easily depressed so get caught out by numerous such things. I've had a bit of a go at fixing it, and might of but in order to do it I might of broke the circuit board trying to get it detached. Like my ergonomic keyboard that I like both of them so much I wouldn't worry too much about it. I have used the KB for so long that on a significant number of the keys the characters are no longer legible. In my case this might be a good thing as I type quite fast but I am one of these lame typists that mostly watches the keyboard while typing. So my ti[ng & spulng rnt gret. LoL (< 8)
I'm aware of the patent situation that you are referring to and am not laboring under and delusions about them. I was happy to hear on the radio a little while ago about a small computer company in central Canada that won a $275,000,000 judgment over MicroSoft about them stealing their code and using it in MS Word and were also ordered to stop welling it about now or in another month or so. I'm not sure how old you are but by the things you've said including life experience I doubt if you're an 18 year old testosterone hyped up kid that is invincible and immortal. LoL I'm surprised that as many of us do survive it! But we both know that the court judgment might not mean it will necessarily happen. When it comes to law and the courts it's definitely the 'Golden Rule': 'Those with the Gold Rule' )< 8( Don't get me started on this !!!
In regards to the CVT having only 20 gear ratios, it won't cost a whole lot more to make a 2 stage one than a single stage to proto type and the effectiveness of it WILL be considerable enhanced. I want to make it something that IS a significant enough difference and provide for substantial benefits that it will merit serious consideration and not just given a casual once over and then be dismissed. This will be VERY hard to walk away from with the current and future realities of the personal transportation industry. I'm pretty well versed and have hands on experience in many aspects of these sort of things and not just theoretical ideas and unrealistic ideals. Out of the hundreds of options I've yet to encounter any solution that can compete with this one. The same goes for my (IC) engine/pump. Even more so for the latter. I can't think of any application that can come close to being better suited than my design. This isn't being egotistical, false bravado, wishful thinking or delusion but is a fair assessment and the facts. I also have a development path laid out that goes far beyond this and surpasses these current items significantly.
Thanks for the suggestion of two racks, but there is no need for it. It just adds unneeded complexity and expense and is just more to go wrong.
In regards to the coverage I'm not going to get into it on here but it would likely be good for me to connect with you and others on it. I'm not an egomaniac, but we are in a situation never faced before on our lil mote in the cosmos is the only potential home that we are going to have for quite some time to come. I don't remember if I've already done my 'our poisoned planet, so I'll do my 'abridged' version. I'm sure you are likely just as aware of how bad things are for us as I am. Our current situation makes the period of ~250,000 years where the dinosaurs along with 90% of the rest of life on this planet died of was so rapid that scientists label it as 'revolution' and not evolution. That period looks like the Garden of Eden in comparison to where and what we are in now, regardless of if you count it from about 10,000 years ago with the advent of agriculture or from the industrial revolution. 10K or 1K is insignificant. We were fortunate in that we were the last generation to be born just as our consumer society peaked. Democracy is the best we've come up with so far, but having to win popularity contest every couple of years doesn't lend itself to good long term planning. Especially with modern communications. Most are in the 'Not on my watch mode'. We have bankrupt the eco system and we are only artificially keeping the economy upheld that has already caved in quite some time ago and is based on scientific theories that are not valid for Economics, if at all. It has been said of democracy that it is the subjection and enslavement of the minority by the majority. In Canada we have had a national minority government for at least two years now. They don't usually last that long, and the blanket statement that nothing ever gets done under them is always thrown about. But on the contrary, our federal government political systems has HAD to make concessions and take others wishes and will into account to stay afloat. I see this as a good things, especially as there isn't any party here now that I'd want to have in as the holding the majority. Our world most definitely now is a global village and lines on pieces of paper mean nothing to pollution, Mother Nature and the ecosystem. Either we are going to finally all start working together out of need or revert back into tribalism which is where most of our current problems now stem form. 'Consensus' IS a much better form of government than Democracy, though much harder to achieve. With the state of communications in the industrialized nations especially, government is already more form the 'bottom up' rather than the other way around, which should be, can be and needs to be if we are to have any hope at all. Which is highly unlikely.
Even 40 years ago when a reporter asked Henry Kissinger what would happen if the whole world had the same standard of living as the USA what the result would be? He thought about it for a bit then replied: "All of the worlds resources would be gone in 15 minutes!"
No matter what you say about the Chinese, and like most I don't like the human right abuses by them or anyone else for that matter and they certainly don't have a monopoly on it; They do have a society with a much longer view point as most eastern cultures do just because of the shear age of them. Where I live it was horses and carts and the 'major provincial road system were 2 dirt tracks that turned into huge mud bogs in the rain and were impassable to anything on wheels in the winter only a hundred years ago. One of the things I like about Canada is that we are really a nation that is no 'nation' at all. The only 'nationals' here are the First nations peoples. As a species we have close to a million years of tribal reality programmed into us and that doesn't change anywhere near as fast as our world has and is. What was once a necessity is no lethal for all of us. I don't have problems with people being different. Unlike many, I celebrate it and am not threatened by it. I used to think that I didn't have any prejudices, but that is not true: I do. My prejudice? 'Prejeduce!' LoL (< 8) The Gods forbid that everyone was just like ME ! Yuk! What a horrific thought! Not because I am a 'monster' but there wouldn't be much point in going to all of this effort to differentiate and create individual Ego/Spirit beings and nature if we are all just the same what there only was to start with: 'The 'Unity' the 'One', the 'All' the Everything/Nothing, God, Allah, or whatever term one chooses to describe this aspect of creation. But one thing for sure, we are all in this together now and that is our only hope, which quite frankly doesn't leave me with much hope at all. I'm too much of a discerning realist and not prone to self delusions.
Our population explosion is compounding are already multiply compounded problems. If it were any species other than ourselves, we would label it for what it is: An infestation of biblical proportions. The Chinese did legislate limitations to their population growth decades ago is it IS necessary. Though it is a well documented fact that as nations move up the economics ladder there population growth and rate drops off considerably and there is an economic basis for both aspects of this. An international media asked a senior Chinese official what he thought would be the result if all of China ended up with the same economic basis and lifestyle as the western world (ok it was about the US, but there are a lot of others that fit in the same category). He looked at the reporter like he was a crazy idiot and replied" It would take 6 other planets doing nothing else but supplying China and not themselves". Sorta like the economic inequality is on our planet now. They are now calling for one global currency, which IS the only thing that could be sustainable. We both know that this is not going to happen voluntarily but it will be a VERY short period of time and we will be back on a much more realistic and sustainable economic basis: Need and NOT want! Those that are still spouting off about an imaginary economic global recovery are only…. _________! Enough already, fill in the blanks. Anyone that doesn't believe this or is in denial about it are DoDos and Lemmings and we both know their fate. Alas is will be the same for most if not all of us and most of the higher life forms on our planet. The planet and life will survive, but we are up the proverbial creek, literally.
Speaking of which: it back to the 'gold mining' for me Talk about ironies and split psyches!
Have a better one Garth,
Regards,
Doug
Good Answers: 247
#115
In reply to #107
01/15/2010 1:15 AM
That's pretty insulting to whales.
In reply to #67
Find in discussion
01/11/2010 11:42 AM
Hi PackRat et al,
I also have wondered about the durability and wear of such spring loaded detents to locate the shifter mechanism. Others have addressed it and I have to agree them with proper design and utilization of the correct materials I think it will do the job and will most definitely be a LOT cheaper than any active sensing and feedback self correcting locaters will be. As I have stated, there is virtually no sideways forces on the shifter mechanism in neutral and VERY little even under the heaviest loads and under full power.
A spring loaded mechanism would be a lot more positive and reliable than any such 'gravity' mechanism. As you can read in my reply #76 & ~ 78 or 79 I'll utilize a likely use a cylindrical plunger with a hemispherical end instead of a ball bearing that will be able to seat itself deeper and much more positively than a simple ball bearing would. The small, light and inexpensive spring loaded positive locators and grooves would be much more reliable than any such gravity mechanism. In order for the gravity mechanism to work reliably it would have to be VERY large and heavy which isn't warranted and there is no room for. Also jarring during operations due to road conditions etc would make these unreliable.
I'm familiar with the desmodromic valve trains and it is definitely heavy 'over kill' in this application. There is nowhere near the type of forces, accelerations and deceleration that requires any such mechanism and it would be way to complex and expensive to utilize.
Thanks for the reference to the OnLine cataloging of the wide variety of leavers, slider and crank mechanisms. I have encountered such things before and have a number of books of similar devices in my technical library myself.
On this note decades ago I found out about a book that was a comprehensive compendium and cataloguing of a VERY wide variety of designs and (theoretical) possibilities for internal combustion engines. It took me ten years track one down. I am in western Canada and there was a copy of it in an Ottawa branch of the Canadian Research Council. In conjunction with a technology institute in the Vancouver, BC area I managed to get it sent out to the BC tech institute for me to look at. I was allowed to take it and look at it for 3 days! I photocopied the whole thing, but at the back of it there was about a 25 (double sided0 page listings/array of catalogued and classified possibilities of mechanism for IC engines. Out of necessity it was in full color. Alas I had no access to any such color photocopy machine. The great IC engine design that I have come up with that is truly outstanding in many ways and has a LOT of advantages to it including being a realistic contender to make mass flying (urban) personal transportation vehicles a reality was not included in this very comprehensive cataloging of such IC engines.
Please don't take these as a personal invalidations because they most definitely are not. I appreciate your ongoing insights and input so please continue to be involved with this and share anything and everything that you care to.
Regards, (< 8)
Doug
Good Answers: 114
In reply to #66
Find in discussion
01/10/2010 12:01 PM
I don't know if you are hooked up to the various newsletters or global spec data base?
I saw this today:http://www.drives.co.uk/fullstory.asp?id=2729
Good Answers: 247
In reply to #66
Find in discussion
01/10/2010 2:36 PM
There are a couple of problems with this. They first one is wear, primarily of the grooves, and the weakening of the springs and the cylindrical followers/positioners' that they operate within.
Ball detents are used on essentially every manual transmission, car truck and motorcycle. If you can possibly use such an arrangement it would be far less costly and more reliable than the linear transducers and actuators used on CNC machines (less costly by about 1/100, 1/1000 etc -- i.e. far more than one order of magnitude.)
Remember that, in practice, there is no difference in engine efficiency between a 5 speed manual gearbox and a well-designed CVT (if both operate at about 95% efficiency when not being shifted). Audi's tests of about a decade ago showed this. The breadth of the sweet spot (best BSFC) in engine efficiency has continued to increase (largely because of variable valve timing), so that an accurately-shifted transmission of either type can keep the engine at its optimum (for a given load condition). Consider that the Volvo turbo engines have had a perfectly flat torque curve from 1500 - 4500 for about a decade. (With most engines, the BSFC curve at a given throttle setting is roughly the torque curve flipped over.) So even with only 5 speeds, there is no need for a 4 1/2 speed or a 2 1/2 speed: the increments are already sufficiently small. (For acceleration performance alone, there can be a slight advantage to always running the engine at exactly its HP peak, but even there, the difference is very small.)
Back when I was racing motorcycles, 12 speed transmissions were necessary in 50cc GP bikes because the power band was so light-switch-peaky, but even flat out racers in slightly larger classes did well with 5 and 6 speed boxes. Modern car engines are about an order of magnitude less peaky than those old racers. 6 speeds were first introduced in production bikes with the Suzuki X6 Hustler (a 250 twin) in 1964 or so, and still, 6 speeds is the standard in the 600 cc sport bikes that are essentially road racers with lights.
The Porsche (etc) double clutch 8 speed transmissions have the advantage of lightning fast shifting, but the overall efficiency (of the engine transmission unit) is little different than a five or six speed. The improvement in lap times has as much to do with the slight power delays at each shift (in a conventional trans) adding up through the many shifts in a lap as it does with keeping the engine in a very narrow rpm range.
So... if your transmission is to compete with modern transmissions it will need to do so primarily on cost, and secondarily on function. Reliability is simply no longer an issue (other than when design flaws are incorporated -- which happens far too much). No one is screaming "If only we had more reliable transmissions!" For example, I could be a potential buyer for your transmission, but for my application, a 4-speed transmission works as well as a CVT, in terms of overall vehicular efficiency. The deciding factor for me would be the overall cost, including the shifting mechanism (which would need to be automatic, for marketing reasons).
Therefore, if you can use a simple detent for location , and if a simple fixed-stoke actuator can nudge the transmission from one ratio to the next, then I'd forget about linear actuators, precise feedback, etc. Properly designed, a detent spring never wears out. Consider engine valve springs, which are routinely flexed more dramatically (re the torsion angle per unit wire length) over billions of cycles. A spring design firm (Diamond Wire in Pittsburgh is good) can tell you in a couple minutes the spring characteristics required for a detent spring to be able to last for 100 years, assuming a cycling rate of only twice per second (which would suggest 20 shifts on the way to 60 mph in 10 seconds -- which is too many shifts). In the same 10 second period, an engine, running at an average of 2500 rpm, will flex each valve spring 21 times per second, or 210 times in 10 seconds.
Ball and grove wear? Essentially none, given correct material selection, hardening, and lubrication. A ball going into a detent has a very easy life -- it is far less stressful than a the life of a ball in a ball bearing.
Keep it simple. If you can deliver a 10-speed transmission that offers instant shifts but does away with the astounding complexity of the Porsche style double-clutch transmissions, you've got a winner. Any more than ten speeds are useless, other than in special cases (such as haul truck that has to creep well, but also go pretty fast).
In the auto manufacturing as in many manufacturing businesses they try to keep the manufacturing costs as low as possible but actually work at making the repair costs higher.
Auto manufacturers have to pay for warranty claims, so the successful manufacturers (e.g. Toyota) have low claim rates and low claim costs. The same design decisions that make cars faultlessly reliable through the warranty period also make them highly reliable afterwards. My auto trans in my Honda van has never been apart in 200,000 miles, and I would be completely shocked if the manual trans in my other Honda required any attention at all before 300,000 miles. It has been a while since I consulted for Ford (back when they said "Quality is Job One"), but back then they were struggling just to make stuff that worked right throughout the warranty period, let alone trying to figure out how to make a piece last for 100,000 miles but fail at 101,000.
Imagine the complexity and cost of first getting your transmission to work reliably and then having to go back and figure out how to make pieces fail reliably and predictably.
#81
In reply to #71
01/11/2010 12:36 PM
Hi Blinky et al,
Please see submission # 76 first.
I'll use a ball nosed (hemispherical) end mill to either mill the slots or perhaps just even use the same cutter and just put small round indentations in the positioning strip. As I said I may also 'mirror' it and there would be both spring loaded locating mechanisms and there complementary locating spots on both the moving and the stationary parts; though very minor inaccuracies in such a design could very well result in it being less positively located than it would be otherwise. Another option and the one that at this point in time I'm inclined to use would be not to mirror it, but to put between 2 to 4 such spring loaded positioning plungers for each locating groove. There is also the possibility of not just using one 'locating groove' positioning it, but a pair of them, most likely with more than one spring locating plungers in each groove. In this instance I would 'stager' the spring located plungers so that they did not locate in the same spot in the grooves of the locating strip, but lodged into a different location along the strip, thus the wear would be distributed by half. This arrangement would also help ensure better accuracy over a longer period of time. Though as I mentioned before, I have to strike a balance between locating the shifter mechanism firmly enough to be effective and reliable, but not so stiff that the motor will be able to disengage it to move it to the next position. Still, a lot of more lightly loaded plungers is a better overall arrangement than just one or two spring located There is the problem of interference from machining inaccuracies in this design as well, but that would only be a problem in manual fabrication by myself in prototypes, but that would be sufficiently accurate enough for prototyping R&D.
It sounds like the 50cc racing motorcycle you are referring to was a 2 stroke and with the type of designs they use are very 'peaky' and have a very narrow power band. A more highly tuned racing engine would be even more so.
Though the one instance that you sight of there being no advantage to having dozens or even hundreds of possible 'gear ratios' that are both much more closely spaced and have a much broader range as well may very well be true in this one instance. But taking a very wide variety and implementations into account I can't say that I agree with you as this being 'comprehensively' and generally the case. If it were, there would be no such hybrids that add considerable complexity and expense in order to keep the IC engines operating within a very narrow speed range were they are significantly more efficient and with a lot less pollutants. I think that if one had a book that was a cataloguing of hundreds of speed versus power/torque outputs and just 'fanned/flipped/ though them like it was a sequential animation book, you would find that this is most definitely not the case. Also there are more and more small mass produced cars with IVTs in them for very good reasons. Also I don't think that you are taking into account an engine designed specifically to maximize the advantage of such a IVT or CVT as opposed to IC engines that are made with the broadest, flattest power and torque vs speed output curves just because they DON'T have any such transmissions that they are going to be operated with. In essence, you are comparing apples with oranges as opposed to taking into account these very significant design factors and compromises made just because there are only a few widely spaced gear ratios with a limited range.
Though we all know what we are referring to, when there are no actual gears involved, I wonder what the correct terminology would be as opposed to using 'gear ratios'?
Likewise, what is the metric equivalent of 'mileage' (M/G, MpG, Miles to the Gallon)?
Regards, (< 8)
Doug
#99
In reply to #71
01/12/2010 5:13 PM
[]pHi Blink,
The CR4 bot says that you posted # 98 in response to my #97 submission, but when I try to access it with by clicking on the link to your latest posting, or searching for #98, it doesn't and can't access it.
Would you mind posting it again thanks?
Regards,
Doug
In reply to #99
01/12/2010 5:54 PM
Hi Doug you will find it at the bottom of the page - you have to click on the + sign to expand it.
“Don’t worry, they usually don’t swim backwards.” Steve Irwin
In reply to #99
01/12/2010 6:31 PM
If you're still stuck, click here.
Good Answers: 247
#102
In reply to #99
01/13/2010 11:14 AM
Hi Doug,
My post was more-or-less off topic, being a series of random thoughts not relating to linear actuators specifically, so I voted myself off topic (which gives me 5 "off-topic" votes, and minimizes my post). To maximize such posts, you click on the little plus sign in the upper right corner of the gray rectangle standing in for the post.
The idea of voting yourself off-topic is mainly that if someone (later) is searching through threads looking for info on linear actuators, if a bunch of the posts are talking about invention and prototyping issues more than linear actuators specifically, that makes it hard to find the linear actuator info.
Ordinarily you can also click on the link showing the post number, as I think you tried to do. This opens a new window, with that post alone, so might be stopped by your browser if you have it set to block pop-ups.
If you respond to an off-topic post, your own post defaults to off-topic (5 votes) too... although you can change that prior to posting it, by unchecking the box before "Yes, this comment is very likely to be considered to be 'off topic'. "
#104
In reply to #102
01/14/2010 6:56 AM
Geeze, I can't even find my lengthy reply to this that I had to do some parts of it over a couple of times! Needles to say I am not impressed! I hope it at least got posted somewhere and is not gone into the internet version of 'single socks in the dryer' ! (< 8)
#105
In reply to #102
01/14/2010 6:57 AM
Hi'
My PopUp Blocker must be preventing them as I have now plus signs nor small grey rectangles that you are referring to.
FYI: I'm not ignoring rating any/all postings, but intend ongoing through and reating them once the thread has pretty well come to and end. I know that this makes it less likley that I will do it (contumaciously and thoroughly). but in keeping with the 'brain storming' I don't want to discourage anyone that just may have some seemingly minor insight, idea or tip that may turn out to be quite crucial at times. I've also learned that from past experience, there are times that I know of a solution or technique to overcome a problem but am not making the connection to it or have forgotten about it so......
In reply to #66
Find in discussion
01/10/2010 4:24 PM
In reply to #72
01/11/2010 9:03 AM
Hi Kyzine,
Your Posting and the link are SNAFUD, please try it again thanks.
Doug
In reply to #73
01/11/2010 9:18 AM
In reply to #74
01/11/2010 9:50 AM
Thanks JD, it was fine - then I guess it wasn't, but you got it - good. tar
#86
In reply to #75
01/11/2010 2:10 PM
Hi JohnDG and Kyzine,
I've just given both of your catalogues some quick searches. It's obvious that you have a wide variety of solutions for a wide variety of applications.
The timing belt drives are out for obvious reasons, though the purely mechanical ones are not.
What do the smaller mechanical linear actuators have in the way of active linear position sensing, feedback and correction mechanisms?
Think you have any that are in the ball park for my needs?
If so, please post the references for me.
Regards,
Doug
In reply to #86
01/11/2010 6:15 PM
Sorry, I've got no input here - I've just been reading along & I helped out with a missing link.
In reply to #91
01/11/2010 11:16 PM
Yeah, funny that JD, and now it seems to be back, or is it just back for me?
In reply to #92
01/12/2010 1:41 AM
It's back - picture an' all .
In reply to #94
01/12/2010 2:04 AM
Um indeed. Maybe part of their server was down. However that blue bucket ferrari shot was up - then not - and not back - could be linked to 'what has Kz done now!?'
#85
In reply to #74
01/11/2010 1:46 PM
Cost effectiveness is a VERY important factor here. I think that these would likely be too expensive an option and unlike a lead screw or a feed rod on Lathes, these lead screws would be constantly be exposed to a lubricant with very fine metallic particles in them that will lead to increased wear rates. Though I am very well aware of how dirty lead screws on manual lathes usually are, the lead screw is rarely used except for threading. Also, it is not constantly bathed in abrasive particles. Even then, relative to the life of a lathe it does not take long for the half nuts and/or lead screw that are used for thread cutting to become quite worn and sloppy. The machinist has to take this into account and utilize appropriate techniques to ensure repeatability in order to cut threads of acceptable quality and within tolerance limits. The feed rod is used for all cutting operations which is what lathes do most of the time.
In my application I need to be able to mount the shifter mechanism directly to it and there is no allowance for any rotary movement of it at all. I don't know how much of this you have read, but the linear locating is very critical and the 'nut' would have to be both self adjusting for wear and perhaps be square in cross section that so that it could run along a milled groove to keep it from rotating and so that they shifting mechanism could be mounted directly onto the 'square nut' in linear motion. I doubt that this would be sufficient to prevent the nut from rotating at all though of course the design factor is significant in this. The slot could be very deep with three sides of the linear nut running very deeply within it and almost completely 'submerged' in it. Woodruff keys running in a milled slot is another possibility either with or without the square nut running in a milled slot in the casing. Likewise there is no tolerance for movement of the 'height' of the nut: ie it being lifted in and out of the groove by the lead screw etc. The forces required are very minor, and space and volume are minimal so regardless of what mechanism is used, it has to be quite compact. With the lead screws mechanical advantage, I would likely only need one that was about ½" in diameter and lengths of between 8" ~ 16". The linear accuracy tolerance is very high: ±0.005" with 100% repeatability over an extended life time. The spring loaded locating plungers that extend into machined locater spots or grooves being referred to in this discussion thread, especially in about this part of it could be incorporated into the square nut though. If using this sort of passive mechanical linear locating system, as with other linear solutions; some linear play, sloppiness and movement would be acceptable and even desirable within limits. But again, there is no tolerance for any rotational movement of the nut at all.
Thanks for your input, I welcome more of it. (< 8)
Regards, (< 8)
Doug
In reply to #85
01/12/2010 12:17 AM
Hi Doug, ball screw systems are preloaded, so 'zero backlash'. The rods and nut races are quite hard (like a ball bearing) . Positional accuracy is virtually absolute, given the expansion coefficients of rod vs driven assembly are the same. I.e something like 0.005 mm "repeatability" is 'common' in CNC machines. (0.005 mm = 0.0001968")
Encoding can be done on rod, or drive, or on driven part. However the ball screw pitch is coarser than it first appears and the very low coefficient of friction, means they will go backwards under load, so you need 'active' encoding feed-back or motor brakes to hold a station.
They like dirt as much as a regular ball bearing. There are seal and wiper options.
Thompson is first google on the net I got. You should also look at INA and THK and....
Overall I think you are over-training on the accuracy and life aspects of this.
A car has a service life of around 6000 hrs = ~ 2.2 years for a production machine (which is still "as new").
Cost? Doing once and properly is always cheaper.
But these things exist in a range of printers and similar - try the tip?
They may be the 'soft' and/or Russian ones, but printers are way more accurate than 5 thou. You may also score all the ancillary junk to run it.
Keep the major rod force in 'pull', and quite a tiny one is all you need.
OOO XXX
Kz
#96
In reply to #93
01/12/2010 2:11 AM
Hi Kz et al,
I have no interest in getting into manufacturing these myself, only in licensing them. Thus I could utilize such new off the shelf items like the industrial feed rods etc. But the Automotive industry has huge very effective blinders on when it comes to solutions from outside of their own organizations and industries. So I'm doing the best I can to come as close to a very cost effective final production model so that when the suits are taking a first look at it they don't look at the two sophisticated active industrial linear actuators that are worth a few hundred bucks each and thus immediately dismiss it as being way too expensive to manufacture and turn around and walk away. Mind you with the auto manufacturers all being turned on their heads recently with the downturn they may, and should be open to new, different and BETTER ideas. One great advantage of this CVT over and above the immediate ones of it being a CVT with a LOT more closely spaced gear ratios over a much wider range is that it's design is very simple and elegant with a much lower part count and considerably less (very accurate) machining to make it. The only actual gears in it will be an idler for reverse. I'll be very surprised if it couldn't be massed produced for about ¼ ~ 1/3 of the cost of the types of automatic transmissions that have been in use for decades. It requires no new technology or machining and manufacturing tooling or processes. As a machinist that has worked on a lot of very old, very worn out manual machine tools, I'm only too well acquainted with the 'work around' techniques of always working from the same direction to keep the repeatable accuracy in place. But it is a reality of this mechanism that it WILL be constantly reversing travel direction. Though on here I've worked this aspect through and because of the very low motive force required and almost negligible sideway force vectors while operating, I have come to the conclusion that just some passive spring loaded plungers and detents can eliminate the need for the very high accuracy active components.
As you may have read, the forces required for the shifter mechanism are very low, so thanks for the tips on scrounging old printer drives etc, the biggest problem with this may turn out to be getting the source code or hacking it in order to utilize it. This is starting off from a shoe string budget and I don't want to waste a considerable amount of time climbing the specifics of the learning curve for the scrounged printer mechanisms, drive, positioning and feedback etc. If I had to learn Russian on top of it to do it we would all be flower food before this ever happened. As it is, and likewise with my very compact, versatile and simple engine design that shares all of the same advantageous of this CVT design, they should of been shown around about 5 years ago or more. Though obviously the timing belt wouldn't stand up for long in R/L service, just the fact that it can be made to work with something that is now a very mature technology and just seeing it work with such small, low powered parts that were scrounged for almost nothing could actually be a marketing advantage. I would point out that obviously they wouldn't use a timing belt for it, but if it works with this, then…..
FYI: For the R&D and demo models I'm just going to fabricate a suitable sized metal box made out of steel plate and welded with bolt on bearing end plates, access/covers etc, stress relieved (oven and freezer) and machined. I'll have to do a lot of grinding to make the demo models presentable as it is a toss up which is worse: my OxyAcetelyn or welding skills. As my welding instructor in my machinists training observed: "Well Doug, it looks like it has been hit by a low flying cow, but it will most definitely hold together!" LoL Alas, sad but true (< 8) I'll likely put a piece of Plexiglas or similar as the removable top for the demo model, including when it is running hooked up to and operating on an engine dyno.
Regards and thanks for your input and assistance., (< 8)
{p]Doug
Find in discussion
01/09/2010 10:00 AM
Hi GarthH,
When I am looking at the specs for sensing distances, there seems to be different conventions utilized to specify the 'sensing zone'. Some of them seem to be just the proximity of the sensor to the locater that specifies how close these 2 elements have to be together before they start to sense each other. In other instances it seems to be the overall linear travel distance of the shifter 'saddle'
In regards to the clutch I have a simple elegant design in mind that in effect is an 'automatic' mechanical manual clutch that doesn't require any hydraulic cylinder, lever, actuator etc to operate it. I'm not going to say too much about it on here for the moment until I check out the patent status of it.
Thanks,
DougRH[i
01/05/2010 6:23 PM
High-performance Electromechanical Linear
Actuator EGC Festo Corporation
Expanding on the most comprehensive range of electromechanical components, our new EGC linear actuator provides:
• Speeds up to 5 m/s and accelerations up to 50 m/s2
• Feed forces up to 2500 N
• Moment loads up to 1820 Nm
• Strokes up to 8.5 m
Optimized profile design delivers increased rigidity and efficiency.
Visit: www.festo.com/us/egc.
Festo…supporting advanced automation…as no one else can!
01/06/2010 9:25 PM
Kyzine,
Thanks for the info, I'll check them out
Regards,
DougRH
01/10/2010 8:50 AM
Hey Doug,
Getting a feel for the area of your mechanism, without digging into your potential propriety "secrets". If I understand it the indicator could be spring loaded, but then it might not have a long enough life cycle because of lose of spring tension over time?
What's the possibility of eliminating the spring and using a dense enough follower that would rely on gravity? Using enough clearance in the followers sliding contact surface to prevent it hanging up? Or any combination of the following:
a simple advance rotating mechanism similar to the valve train on an engine, can't remember the make, that would rotate the valve during it's operation to keep the valve/valveseat surface clear.
A desmodromic type valvetrain,, adapted for this application. In a engine , the cam would have two lobes, one to lift the valve ,one to close it. Some had a very weak additional spring on the closing side. If it was incorporated in the initial design stage,maybe it could have constant mechanical force keeping it located, gravity or springs not neccessary . Like a small walking beam with pivoted, sliding followers on each end. Visualize roller, cam followers on either end, fulcrum in center.
in Heckler&Koch rifle, the chamber that contains the cartridge is fluted, to prevent failure to function, regardless of debris/gunk buildup.
Packrat
oderint dum metuant
In reply to #68
01/10/2010 12:36 PM
something intriguingkinetic
Quick reference desmo
oderint dum metuant
In reply to #70
01/11/2010 11:24 AM
Hi PackRat et al,
A spring loaded mechanism would be a lot more positive and reliable than any such 'gravity' mechanism. As you can read in my reply #76 I'll likely utilize a cylindrical plunger with a hemispherical end instead of a ball bearing that will be able to seat itself deeper and much more positively than a simple ball bearing would. The small, light and inexpensive spring loaded positive locators and grooves would be much more reliable than any such gravity mechanism. In order for the gravity mechanism to work reliably it would have to be VERY large and heavy which isn't warranted and there is no room for. Also jarring during operations due to road conditions etc would make these unreliable.
On this note decades ago I found out about a book that was a comprehensive compendium and cataloguing of a VERY wide variety of designs and (theoretical) possibilities for internal combustion engines. It took me ten years track one down. I am in western Canada and there was a copy of it in an Ottawa branch of the Canadian Research Council. In conjunction with a technology institute in the Vancouver, BC area I managed to get it sent out to the BC tech institute for me to look at. I was allowed to take it and look at it for 3 days! I photocopied the whole thing, but at the back of it there was about a 25 (double sided) page listings/array of catalogued and classified possibilities of mechanism for IC engines. Out of necessity it was in full color. Alas I had no access to any such color photocopy machine. The great IC engine design that I have come up with that is truly outstanding in many ways and has a LOT of advantages to it including being a realistic contender to make mass flying (urban) personal transportation vehicles a reality was not included in this very comprehensive cataloging of such IC engines.
Regards, (< 8)
Doug
In reply to #77
01/11/2010 12:31 PM
Hi Doug,
I appreciate you replying.
I'm just throwing out ideas and in no way am I offended if none of them stick to the wall. Don't want to be a distraction to your endeavors, enjoy reading this thread, I hope you advance to the patent/demonstration model phase so we all can check it out .
Hardwood sounds good, or machinable wax, but aluminum might convey more "gravitas" for the demo model.
Keep at it.
Pack
oderint dum metuant
#97
In reply to #80
01/12/2010 10:46 AM
The aluminium is a good low cost choice because of the very easy machining but it will still be very accurate and durable to stand up to some actual usage. I'll use a fairly soft and highly malleable aluminum so that I can also use it as a 'stress, forces and wear indicator' running it for a while and see just exactly how and where it distorts and wears and what and where I have to focus on to improve it.
'Quasi' (non) destructive analysis and testing.
Good Answers: 247
#98
In reply to #97
01/12/2010 3:56 PM
You could spend a lot of time in testing and re-machining that might better be done by calculating the stresses so that there is no permanent deformation or meaningful wear. Then you could spend your time demonstrating the concept and lining up licensees, who can do the actual engineering involved.
A couple other thoughts.
I recently met a guy who has a CNC milling machine with 5' x 8' table and 8" z travel... in his garage, for fun! (This is not a ShopBot, but the real deal, that can take a 1 ton slab of aluminum and make a part for Boeing.) If you can find someone of that ilk, you could have a lot of machining done, perhaps for free, and perhaps without your having to spend the time doing it yourself. As I stand at my own lathe making $100 bushings (to serve the function of a $.50 one, if I could find one from production) I often think it would be nice to partner with someone who would do machining for a part of the business... although I have not done precisely that yet, so I keep turning out time-consuming parts that "should be" cheap.
eMachineshop is another possibility for getting stuff made without having to spend all the time yourself. I've used their design software and asked for a quote, and the price was fairly reasonable -- although not reasonable enough to decide to actually go ahead with them instead of making it myself. I tend strongly toward doing everything myself, to minimize out-of-pocket costs, but ofter wonder if it makes sense to do so. At times, I've thought "penny wise, pound foolish".
Yet another possibility, especially for a project like yours, (I think) is to find someone with a 3D printer, some of which can make powder metal parts of moderately high strength -- but even the plastic part type could be useful. I think If I were you, developing a new transmission, I would want to get to a working prototype as quickly as possible, and not worry at all about doing it in metal at first. Paying for the use of a 3D printer can be an obstacle, so again perhaps you could find someone who could do it far a part of the project, or perhaps an underutilized one at a university, etc. People can easily understand that metal parts are stronger than plastic: all you need to demonstrate is that the concept works -- it doesn't matter if it is transmitting 1/4 hp or 200. Analyzing tooth stresses, materials requirements, etc is easily done by a licensee.
For example, going from pull belt to push belt CVTs was a significant conceptual difference, and many people when introduced to the concept would have said, "Wait.. belts don't push, they pull!" So when DAF demonstrated the push belt, all that would be required is to demonstrate the concept is to show how it works on a fractional HP motor. (Then people say: "Oh, yeah, I knew that.)
Also, you can do a provisional patent application for very low cost, if you write it yourself, and I'd recommend that you do that immediately. You'd want to read up on doing this to make sure that your provisional is sufficiently broad and that it claims everything that might be unique. I once had a patent denied because between my search and my review date, someone from Japan came in with a much broader patent -- broader, in fact, than I initially thought I could have claimed. But basically the same idea, and they got there first: time is of the essence.
Good Answers: 183
#108
01/14/2010 1:22 PM
Although I did not participate I followed the evolution and I dare make a comment:
- according to what was written it will NOT be economical to have too many "steps" since the gain will not compensate the complexity, your goal being the lowest possible cost/price the number of steps should be maintained to a minimum. My estimation is 10..12 since the engine curves are quite flat. With 20 you increase in an important way the complexity but I doubt that decreasing the step from 8..10% to 5% will bring a gain such that the cost difference will justify it. I have no doubt that you thought about wear and maintenance and you will agree that more components increase the failure risk and the maintenance cost.
- the solution with mechanical indexes is a good one provided that you have still a signal for every position in order to have a situation recognition for the control. It is good because there is no more need for the control position since the mechanical index takes care of this requirement, it is enough for the control to bring the "slider" in a position where the mechanical index can be active. This way you can use lower cost motors for the movement since you do not need the motor neither to give the precise position nor to maintain the position. It will be enough to have a DC normal motor which stops when a signal from the target's sensor comes and the mechanical index brings the slider exactly in the wished position since no more torque is applied.
- the steel ball as indexing element is good for several reasons: cost/quality very low, high wear resistance even in polluted environments due to very high hardness (<HRc62), due to its physical property (magnetic) it can be the target for the position sensor, its holder can allow a "roll" so that wear is not on only one spot.
- the motor has to be strong enough to bring the indexing element out of the index grove when position is changed. This implies a good choice for the grove slope so that from one side the position is hold against disturbances and the force to leave is within limits.
Combining technologies and ideas I think that you came to a very simple and cost oriented solution.
Good luck.
In reply to #108
01/14/2010 7:06 PM
Sorry to everyone who has put so much in so far for not having read every word (I have a very short attention spawas that a skwrl ?...).
Quick thought springing from your post (nick name): a combination of the rack & detent and a DC gearmotor driven cam (to lift the detent against a spring) with a synchronised Geneva-type mechanism (to advance the rack 1 tooth per rev) may work, if it can be made to operate quickly enough for rapid large ratio changes.
Absolute position feedback wouldn't need to be either very precise or accurate - a simple linear (or geared rotary) encoder should fit the bill.
#112
In reply to #111
01/14/2010 11:13 PM
No worries John,
It's pretty lengthy and involved and has gotten off topic in places and I tend to be quite verbose. It's not like I am going to withhold your paycheck for not keeping up on your volunteered assistance, which I DO appreciate.
I tend to agree with you that the one rev clock mechanism will likely be to slow. If it was made to go fast enough to do the job the inertia would start to cause more headaches than it solves. I won't need any active solution to lift up a pall, there really will be no sideways force vectors of any significance if the shifter mechanism is designed and fabricated properly. Also you have to remember that it will be in almost constant motion including reversing the direction of travel constantly. I'm pretty well decided on using a passive slightly grooved strip and 4 spring loaded detents regardless of what else I do. I'm not an engineer but have decades of working with, designing 'solutions' and creating them from scratch, fixing up other's SNAFUs, repairing and fixing manufacturing defects, done a lot of varied repair work including mechanizing, machining, fabricating and welding etc and some millwrighting so I do have a good feel and sense for keeping things balanced, though I do tend to overbuild things. But getting one aspect of something out of proportion can create so many other problems that then have to be coped with and it just snow balls. If you haven't encountered it yet, the 'rack teeth' are likely only going to be ~ 1/8" deep at the most.
Though I know the basic concepts, I don't have much experience with servo motors, stepper motors, active encoders, positional sensor and feedback correction systems; but frankly the detents will do the job just fine for the demonstration prototype and likely for the production model as well. So the linear motive force and mechanism is not going to have to be REALLY precise, just get it into the ball park and have just enough free movement to allow it to be properly mechanically located and seated but not so much that it misses it. If I get it to tight I'll just bring PackRat in to 'loosen it up a little'. Don't force it eh PR, just get a bigger hammer! LoL
I'd prefer to stay away from gears for the linear actuators as likewise the finicky tolerance issues that are always present with gears. If I can find a low cost linear actuator stepper motor or encoder combo I'm open to it, if not it will be the 'steel belt' of some sort and a couple of pulleys. If I utilize a cable, I can even use a grooved pulley with a 'threaded circumference' for the cable to accurately to always seat into controlled positions. If I can get enough 'traction action' the thin (light spring) steel band that the generic Guru 'NickName' suggested. I'm not opposed to a prefabricated linear actuator, I just don't have enough firsthand experience to say: 'Yep I know exactly the type and one that will do it' Before I do get down to drawing up the actual design I'll get it nailed down precisely so that if I have to make some slight adjustments and compensate for a slightly different incremental movements to accommodate the stepper motor or whatever I end up using then I can and will do that. If I don't find a suitable, reasonably priced off the shelf solution, I haven't decided on the exact type of setup for the linear moving part to run in. I'm thinking that if I'm smart and careful enough I may get away with really low balling it with some cold rolled steel tubing, channel or angle iron that will require little if any machining at all. Time will tell. The suggestion of scavenging the complete mechanism off of a wide commercial (blueprint) printer is very attractive for a lot of obvious reasons.
None of this is going to start manifesting until money issues get handled one way or another and I'm open to collaborations, corporate or more likely at this stage, sweat equity partnerships or ??? If I get a 'business type' involved, which I need, on a sweat equity basis to put together a good business plan and perhaps find some outside financing, but frankly at this stage, I'm not willing to give up as much as I would have to in order to bring an 'angle/venture capital' partner in and give most of it up to them. I should be able to generate some substantial and significant enough capital to get it underway and have something concrete that can then be leveraged with government grants etc. Magna International, the major auto parts manufacturer is cooking up a deal with the federal government to pick up some dying auto manufacturing plants and equipment cheap and bring a whole new concept on stream for designing and building personal and light commercial and industrial vehicles. I SOOOOooooo much want to draft up some substantial correspondence and say to them: Hey, look at this CVT and engine I've got. I haven't brought this up before, but I'm fairly certain that I have a significant development that will make mass produced electric vehicles a reality as well as they will only need a couple of hundred pounds of batteries which is equivalent to an engine. This cuts down the battery pack by a few hundred to a 1,000 pounds of dead weight which further reduces battery requirements which translates into a lot longer range and less power requirements regardless of what the source is. This technology is applicable to many other things as well. The greatly reduced battery requirements cuts down the huge volume that they currently leaves no room for anything else in a vehicle and thus it would not be hard to adapt current major body styles to utilize these. They open up a lot of options that aren't otherwise possible, including a realistic mass produced flying (urban) transportation vehicle which would cut the urban transportation infrastructure costs VERY substantially. And after that, there may be things that will make all of these things minor in comparison…. But alas it is premature. But if I can get it rolling in the near future, things can change and will turn around and change VERY fast.
As I'm doing this, I'm thinking that I may just flog this actual thread here far and wide and heavy in multiple streams and see what comes of it. With today's global communications and media of many different types and orientations. I'd canvas them ALL. Nothing ventured….. I've got nowhere to go but up and our world NEEDS these things. NOW! I'm getting closer to the end of this life cycle, so now IS the time for these things. Considering the current global situations, it seems inconceivable that if marketed in the right way that I would have to work very hard at it for it not to succeed. So it's back to the 'Gold mining' for me now, but hopefully not for very much longer! (< 8)
'Whatever You Can Do, or Dream You Can, BEGIN IT!
For Boldness has Magic Power and Genius In It!'
Johann Wolfgang von Goethe
"‘Mathematics is the language with which God hath wrought the Universe.’ Ancient Greek Mathematician_-_ CKUA.Com 'Eclectic music at its very best!’
In reply to #112
Re: Linear Actuator for Continuously Variable Transmission (CVT)
01/15/2010 7:38 AM
Hi Doug,
Any time you get to the adverse condition/ham-handed operator/destructive testing phase; HAVE HAMMER&PASSPORT, WILL TRAVEL
Packrat
oderint dum metuant
#113
In reply to #111
01/14/2010 11:55 PM
No worries John,
I tend to agree with you that the one rev clock mechanism will likely be to slow. If it was made to go fast enough to do the job the inertia would start to cause more headaches than it solves. I won't need any active solution to lift up a pall, there really will be no sideways force vectors of any significance if the shifter mechanism is designed and fabricated properly. Also you have to remember that it will be in almost constant rapid motion including reversing the direction of travel constantly. Regardless of what else I do I'm pretty well decided on using a passive slightly grooved strip and 4 spring loaded detents in a square or rectangular layout, with the 2 sets of 2 being offset a little bit so they don't all utilize the same location in the groove which will cut the wear rate on the 'rack strip' in half. But getting one aspect of something out of proportion can create so many other problems that then have to be coped with and it just snow balls. If you haven't encountered it yet, the 'rack teeth' are likely only going to be ~ quite a light, thin (¼" ~ 3/8") with the grooves ~1/8" deep at the most.
I'm not an engineer, though I did have some training in it, but I have decades of working with, designing 'solutions' and creating them from scratch, fixing up other's SNAFUs, repairing and fixing all sorts of and a very wide variety of devices on significantly different physical dimensional scales and sizes. Fixing and improving manufacturing design defects, done a lot of varied repair work including mechanic, LOTS of varied machining, fabricating and welding etc and some millwrighting. So I do have a good feel and sense for keeping things balanced, though I do tend to over Engineer and overbuild things. I'm from the 'old school': I build things to last: take a licken and keep on ticking, not for an engineered and built in limited, 'disposable life cycle'. Our world cannot afford such needless waste of resources of all sorts of different types on numerous different levels anymore.
Though I know the basic concepts, I don't have much first hand experience with servo motors, stepper motors, active encoders, positional sensor and feedback correction systems; but frankly the detents will do the job just fine for the demonstration prototype and likely for the production model as well. So the linear motive force and mechanism is not going to have to be REALLY precise, just get it into the ball park and have just enough free movement to allow it to be properly mechanically located and seated but not so much that it misses it. If I get it to tight I'll just bring PackRat in to 'tune it up a little'. LoL . Don't force it eh PR, just get a bigger hammer! (< 8)
I'd prefer to stay away from gears entirely regardless of the final design including for the linear actuators as likewise the finicky tolerance issues including too tight and (inevitably) to loose that are always present with gears. If I can find a low cost linear actuator with a stepper motor or encoder combo I'm open to it. If not and I can get enough 'traction action' form ir, it will be the light spring 'steel belt' of some sort and a couple of pulleys, with the idler being under spring tension to keep it taught and accurate. If I utilize a cable affixed to the driving pulley that is 'grooved' with a 'threaded circumference' for the cable to accurately to always seat into controlled positions. If I can get enough 'traction action' the thin (light spring) steel band that the generic Guru 'NickName' suggested is also an excellent option. I'm not opposed to a prefabricated linear actuator, I just don't have enough firsthand experience to say: 'Yep I know exactly the type and one that will do it' Before I do get down to drawing up the actual design I'll get it nailed down precisely so that if I have to make some slight adjustments and compensate for a slightly different incremental movements to accommodate the stepper motor or whatever I end up using then I can and will do that. If I don't find a suitable, reasonably priced off the shelf solution, I haven't decided on the exact type of setup for the linear moving part to run in. I'm thinking that if I'm smart and careful enough I may get away with really low balling it with some cold rolled steel tubing, channel or angle iron that will require little if any machining at all. Time will tell. The suggestion of scavenging the complete mechanism off of a wide heavy duty used commercial (blueprint) printer is very attractive for a lot of obvious reasons.
None of this is going to start manifesting until money issues get handled one way or another and I'm open to collaborations, corporate or more likely at this stage, sweat equity partnerships or ??? If I get a 'business type' involved, which I need, on a sweat equity basis to put together a good business plan and perhaps find some minimal outside financing to get things in motion and rolling. Frankly at this stage, I'm not willing to give up as much as I would have to in order to bring an 'angle/venture capital' partner in and give most of it up to them. I should be able to generate some substantial and significant enough capital to get it underway and have something concrete that can then be leveraged with government grants etc. Magna International, the Canadian based major auto parts manufacturer is cooking up a deal with the federal government to pick up some dying auto manufacturing plants and equipment cheap and bring a whole new concept on stream for designing and building personal and light commercial and industrial vehicles. I SOOOOooooo much want to draft up some substantial correspondence and say to them: Hey, look at this CVT and engine I've got. I haven't brought this up before, but I'm fairly certain that I also have a significant development that will make mass produced electric vehicles a reality as well as they will only need a couple of hundred pounds of batteries which is equivalent to an engine. This cuts down the battery pack by a few hundred to a 1,000 pounds of dead weight which further reduces battery requirements which translates into a lot better performance and efficiency, longer range and less power requirements, resources and pollution regardless of what the initial power source is. This technology is applicable to many other things as well. The greatly reduced battery requirements cuts down the huge volume that they currently leaves no room for anything else in a vehicle and thus it would not be hard to adapt current major body styles to utilize these. They open up a lot of options that aren't otherwise possible, including a realistic mass produced flying (urban) transportation vehicle which would cut the urban transportation infrastructure costs VERY substantially. And after that, there may be things that will make all of these things minor in comparison…. But alas it is premature. But if I can get it rolling in the near future, things can change and will turn around and change VERY fast.
As I'm doing this, I'm thinking that I may just flog this actual thread here far and wide and heavy in multiple streams and see what comes of it. With today's global communications and media of many different types and orientations. I'd canvas them ALL. Nothing ventured….. I've got nowhere to go but up and our world NEEDS these things. NOW! I'm getting closer to the end of this life cycle, so now IS the time for these things. Considering the current global situations, it seems inconceivable that if exposed and marketed in the right way that I would have to work very hard at it for it not to succeed. So it's back to the 'Gold mining' for me now, but hopefully not for very much longer! (< 8)
Good Answers: 247
#114
In reply to #113
01/15/2010 1:10 AM
Oh no... you've finally lost it completely.
I, too, am that age where I think I repeat things. But rarely do I repeat things in exaclty the same word order and length, hundreds of word at a time. This may be a very advanced form of echolalia.
Hoping you can get a grip,
Blink
#116
In reply to #114
01/15/2010 1:56 AM
You gotta go with what you've got.
I'm still doing quite well with things that are important, and there qre always compensatory balances, . eventually!
Different times of Life bring different things. We have a world full of lots of very smart peoples with fairly individuated Egos and Spirit bodies incarnated into us now.
But all of us very smart people are killing us for want of the Wisdom to weld such Power
Wisdom (and wit) comes with Life Experience and Age, for some anyway.
Where do you fit into this spectrum now?
Touché, en guard Rapscallion!
Later Gator ! (< 8)
PS: I can't get the URL working here.
See? Just like I to told you: I'm Wise enough to know it, but apparently not Smart enough anymore to figure it out! . LoL
Nah, it's not that at all. I just don't need it enough to spend the time to get it going now. When it is I will. See? I'm Wise enough to know it and humble enough to admit it and ask someone else who already does. Pretty smart Eh ! . RoFLoL
I've still got it where it counts kiddo!
Have a Good One, If you can remember which 'one' it is?
OK, enough already.
Good Answers: 114
#118
In reply to #116
01/15/2010 8:41 AM
You should have a look at Chris288's latest extravaganza
http://cr4.globalspec.com/thread/49156#newcomments
Should be fun & Chris has autocad skills for days
#119
In reply to #114
01/15/2010 12:07 PM
Hi Blinky,
I know you were just kidding and my response was intended to be of the same ilk.
But I did get a little somber and serious and pointed in places in my responses. I hope you didn't take any offense because none of it was certainly meant to be!
I wish I had the kind of memory that allowed me to remember and quote my errata duplicate posting, but it is most definitely not the case with me.
My apologies if you got 'stung' in places, please don't let it inhibit you from subsequent postings of ANY type!
Regards,
Doug
Good Answers: 247
#120
In reply to #119
01/21/2010 1:55 AM
Hi Doug,
No offense taken at all. I've enjoyed this whole thread. In my opinion, you're a good addition to the CR4 crew.
#124
In reply to #108
02/02/2010 5:46 PM
Hi,
I have not forgotten about your last posting and appreciate you making it. I've been side tracked with higher priority tasks, but I will try and respond to it soon.
Good Answers: 204
#121
02/02/2010 2:43 PM
#122
In reply to #121
02/02/2010 5:16 PM
Hi Chris,
Thanks for the info. It appears that the functionality of it would fulfill my needs, but from the video it has a number of features that would seemingly rule it out. However I will check into it further thanks
{p]Quite the ambitious and wide ranging forum you have going. It looks like you are generating a lot of interesting and informative communication on it. As the Aziys say: 'Gud on ya mate!'
Good Answers: 204
#123
In reply to #122
02/02/2010 5:33 PM
I first heard about Uhing Amacoil back in the early '90s, and ordered a vhs video from a magazine (I think it was Machine Design). I was completely blown away. I was investigating Lead Screws for machining applications at the time. I do believe that they have an engineering department, and will work with entrepreneurs to develop custom applications... Wouldn't hurt to give em a call.
As for my thread on modular vehicles, I just hope it grows into something useful. I believe that there can be a system(s) that can work,and I hope that we can define the parameters of workable systems. Then people who have the wherewithal to create real products and vehicles can find a well thought out open-source resource.
Thanks. I'm still thinking and building my responses to you.
Chris
#126
In reply to #123
02/06/2010 2:50 AM
Because of numerous factors, small scale vehivle production and companies are returning with good prospects with the right formulas and mix.
(8 >) I thought I'd get a 'short one' off to you when I spoted teh opportunity (< 8)
#128
02/06/2010 4:58 AM
I will continue on the morrow
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
02/07/2010 7:51 AM
Doug,
Go to Globalspec and do a search for linear actuators. I can't find it right now, but there are a couple of producers of these things who use stepper motors as prime-movers. Relatively simple chip to controll these.
You might have to call on the assistance of an electronics guy to set it up for you though.
Just the thing you need, tight op tolerances, low mass, low voltage. Could have perhaps a mechanical overide as a redundancy.
The units I'm thinking of would be outside the influence of the 'geartrain' lubricant, although they have a high temp tolerance.
Cheers, Stu.
"Nothing, is as it seems." Dr Wally.
Anonymous Poster (4); Blink (15); chrisg288 (3); DougRH (76); Garthh (11); JohnDG (5); Kyzine (9); Luther M (1); MauriceS (1); nick name (13); packrat561 (11); Stueywright (4); tcmtech (1)
Previous in Forum: Toyota Pickup Trucks - Not a Tacoma?   Next in Forum: Auto Repairs and Diagnostic Codes
