I understand that the pressure is over 2000 psi so the air source would have to overcome that pressuer- Perhaps something like a welding tank would work
1. Get a thick walled rubber bladder with an air valve on it
2. Insert it several feet into the pipe that is spewing the oil
3. Inflate the bladder so that it plugs the pipe
4. Done
