Previous in Forum: Power Switch Question   Next in Forum: Capturing Lightning
8 comments
DC Servo Motor Speed Control
03/01/2007 4:56 PM
Hi Folks,
I am interested in building a simple controller to control the speed of a 24V DC servomotor. I do not need to change the speed very much. I just want to set it at a particular speed and leave it there. The servomotor in question has an inbuilt gearbox which has a ratio of 24:1. I just want to run the motor slowly to turn a spit for roasting a pig.
Any help will be greatly appreciated especially circuit diagrams etc.
thanks in advance
User-tagged by 1 user
Re: DC Servo Motor Speed Control
03/02/2007 12:59 AM
The speed of the servo motor can be controlled by variying the input supplys frequency.
normaly the input to servo is of square pulse so i have got some useful links for you
try this..
http://www.seattlerobotics.org/guide/servos.html
http://www.seattlerobotics.org/encoder/200009/S3003C.html
http://www.mcmanis.com/chuck/Robotics/projects/servo.html
http://www.aptronix.com/fuzzynet/applnote/servo.htm
http://www.worldservo.com/html/arc.htm
Mohamed Thalib
03/02/2007 1:06 AM
How many amps does your motor draw? I imagine you want something very simple, right? Or is this a fun project that you want to learn from?
03/04/2007 10:05 AM
Thanks Everybody for your comments about the servo speed control. The motor draws 6 amps and is rated at 24V DC. I have it sussed now. I am building a PWM controller based on a 555 timer. I think that this will work for me as I only need to slow the motor down. I do not need any feedback for this project. As a mater of interest for some of you, the motor I am using is off a CNC machine and it has a rotary encoder on the back of it. It also has a 24:1 ratio gearbox built on to it.
Sorry about the delay in getting back to you as I was away for a few days.
once again thanks to all who replied, it is greatly appreciated.
Good Answers: 97
03/02/2007 4:04 AM
The speed can be controlled accurately by counting the steps on the encoder.
For your application slight variations would not matter.
A stepper motor can also be used (a scraped pen plotter can be adapted for the controller).
CAUTION! Make sure the pig is dead otherwise it might take your roasted potatoes or other food every time it comes around.
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
03/02/2007 5:21 AM
DemCon,
Depending on the particular servo motor, since the load will be relatively small, you may be able to get by fine just by reducing the voltage. If it doesn't exhibit any signs of overheating, your done.
Alternately, you could construct a large rotating frame in which you could, with carefully directed blowers and reflectors, keep your pig stationary in the center, while you rotate the fire around it.
Regards, Greg
03/02/2007 7:05 AM
I've used a car windscreen wiper motor for similar purposes, it has a worm drive gear built in and can operate at very high power levels.
Also they usually have two windings for fast and slow operation. speed control is easily done by varying the dc voltage drive...
John.
Good Answers: 18
03/02/2007 9:51 AM
Try running it off a 12V car battery or charger. If the speed is O. K. then problem is solved. If too fast, try 6 VDC charger.
04/16/2009 4:21 PM
I have built a few simple PWM controllers for motors before. Just watch the supply voltage as a lot of the 555's are limited to 16 VDC or so, whereas your FET will likely handle a lot more.
I used IRFZ44V MOSFETs, Great for this kind of thing.
Register to Reply 8 comments
Anonymous Poster (1); Bill (1); DemCon (1); Electroman (1); Greg G (1); Hendrik (1); James Miller (1); mohammadthalif (1)
