Previous in Forum: Fast Switching Cv=>2.5 Pneumatic Valve   Next in Forum: Heat Seal Model HDS-215
9 comments
Steam Trap
09/17/2010 11:01 AM
how does air removed by trap in steam lines
Pathfinder Tags: Mechanical
Good Answers: 60
Re: Steam Trap
09/17/2010 11:57 AM
you english viry bad unabile t undir stand
Re: Steam Trap
09/17/2010 1:08 PM
I should smack that silly smile off your face! Smart arse answers like yours only serve to complicate communication, even if it did leave me LMAO!
Good Answers: 60
Re: Steam Trap
09/17/2010 1:24 PM
what does LMAO
and can you inderstand what op means.
Re: Steam Trap
09/17/2010 3:10 PM
LMAO = Laughing My Arse Off (I wanted to give you a GA, but you had posted Off-Topic)
how does air removed by trap in steam lines = How is air removed by a steam trap from steam piping (I think).
I hope you did not take my post as being serious!
Good Answers: 60
Re: Steam Trap
09/17/2010 4:44 PM
as if
Re: Steam Trap
09/17/2010 3:44 PM
A steam trap does not remove air. Instead, it allows condensate (liquid water) to pass through while stopping the passage of steam.
Good Answers: 137
Re: Steam Trap
09/18/2010 7:58 AM
That's right, but if it's any help to Yogananth, a steam trap turned upside down can be used to release air from a liquid system.
Cheers..........Codey
Re: Steam Trap
09/18/2010 5:51 PM
There are many kinds of steam traps.
Steam traps with thermostatic bellows will remove air until the vapor inside the bellows expands and closes the air vent valve. When the air has been expelled the remaining steam heats up the bellows. The bellows are very susceptible to damage by water hammer.
In the common float and thermostatic trap, condensate will be forced by the pressure difference across the valve until the float drops and pushes the needle against the seat.
When a steam trap removes air and condensate from a steam system the condensate and air is expelled into to the condensate line.
Do not confuse steam traps with air eliminators or air vents for steam systems.
In low pressure steam systems as often used in older buildings air is often expelled from the system by air eliminators that sometimes are located on the steam mains, but nearly always on the radiator and other heat-emitting devices. Either closed by a thermostatic element or a float, the air is released to the atmosphere.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
Good Answers: 19
Re: Steam Trap
09/19/2010 10:35 PM
During startups:
The Ball Float Steam Traps have built-in air vent valve to remove air .
The Inverted Bucket Steam Traps have a small hole on the top of the bucket to remove air, however an air vent is recommended prior the steam trap.
The bi-metallic & Thermostatic steam traps are temperature-sensative and hence face no problem in removing air.
If you have excessive air then you can also install an automatic air vent prior each steam trap/s.
Suggest you log on to www.spirax.com site to see these in details. The www.tlv.com site shows you animation to help you understand better.
Register to Reply 9 comments
Codemaster (1); Coldspot (1); ducon (1); Mikerho (2); peterg7lyq (3); Tornado (1)
