Previous in Forum: How to Correct Run Out   Next in Forum: Wall Thickness
Proper Selections of Motors
09/26/2010 1:20 AM
Sir, What are the parameter to select the proper motor rating for desired load ? and secondly the proper calculations of load , running as well as starting load ? Correlation between torque and load , what is safety level desired ?.and finally advantage and disadvantage between direct drive motors or gear driven motions ,please suggest .
Good Answers: 19
Re: Proper selections of motors
09/26/2010 1:52 AM
???? What? Is this your homework?
09/26/2010 4:37 AM
I have some suggestions, but I don't think you'd like them.
Good Answers: 74
Re: Proper Selections of Motors
09/27/2010 12:10 AM
You wait till redfred sees this. He is not a happy camper and has a bit more steam up his sleeve, I think.
The Twain Has Met
09/27/2010 1:54 AM
<sigh>
If the motor is under-rated for the load, it will stall, and there will be a loss in the output from the process that the motor is driving. So the motor has to be rated at or over the load requirement.
Torque and load are related by the angular velocity of the drive shaft.
09/27/2010 5:14 AM
1.The load torque characteristic is the first parameter to consider (TL).
2.The second parameter is the speed of driven load(w)
3.Then once you know these two parameters,you can calculate the mechanical power output(Pmech) which will lead you to the select the desired motor.
4.The speed-torque characteristics of the driven load must be compatible with the speed-torque characteristics of motor.
5.Other parameters like ambient temp,protection level will be specified by manufacturer depending on where the motor is going to be installed.That is what I know from my little knowledge of Elec. Engineering
09/27/2010 7:33 PM
ask newton.....c/o nidec
Tmotor = Tload + Tinertia can't cut and paste, to many formulas cheak out nidec site excelent paper on motor or send email icjr2@yahoo.com i'll send to u
Anonymous Poster (1); ducon (1); ky (1); lyn (1); PWSlack (1); THOBIAS MABUGO (1)
You might be interested in: DC Motors, Torque Tubes and Torque Arms, Torque Sensors
