Previous in Forum: Autoclave cleaning   Next in Forum: Pressure of Main Steam Stop Valve
Measuring Electricity Usage By Machine Compressed Air Supply
09/27/2010 5:40 AM
Hello, I want to measure the electricity usage by compressed air supply on a per machine basis. The compressors feed multiple machines in a plant. What I am trying to do is calculate the electrical power used in compressed air supply per machine, over a minute for example. I was going to install air flow meters (measuring m3/hr) on the lines to the individual machines - How exactly do I relate that back to kWh used by the compressors? ( I was hoping i could obtain the compressor efficiency from the manufacturer....) - Where does the pressure come into the matter? Many, many thanks, Aaron
Good Answers: 97
Re: Measuring Electricity usage by machine compressed air supply
09/27/2010 7:28 AM
Why don't you take the kWh required to be proportional to the volume of air used?
power used[machine] = Total power used / Total volume x volume used [machine]
09/27/2010 7:31 AM
I don't know if this is feasible, but could you put an electrical usage meter on your compressor and just run one machine at a time, for a given amount of time? That seems like it would give you an accurate measure of each machine's usage.
Re: Measuring Electricity Usage By Machine Compressed Air Supply
09/27/2010 2:32 PM
There would be some correlation between air flow (at given pressure conditions) and electrical usage, but it is not likely to be precise. For instance, if a compressor is worn or has lube problems, it will consume more electricity per volume pumped.
You need to mearure the electricity usage directly, as in kramarat's suggestion.
Good Answers: 19
09/27/2010 8:22 PM
Install an electrical meter on Compressor and each machine to take reading kwh. Install an air flow meter on compressor to give m3/hr Vs kwh.
So now you have all readings for Energy Audit.
Register to Reply 4 comments
ducon (1); Hendrik (1); kramarat (1); Tornado (1)
