Previous in Forum: Pressure Vessels Design   Next in Forum: ARC Welder
ID/OD Controlled Pipes
12/10/2010 4:36 AM
All,
How can one know whether he has to use ID Controlled Pipe or ID Controlled Pipe in his model and how the material selection activity depends on the controlling factor. Pl. explain briefly.
Thanks
Be simple and specific for a great success in Life
Good Answers: 97
Re: ID/OD controlled pipes
12/10/2010 5:15 AM
Sachin
Do you ever read the replies to your questions?
This must be your nth question about ID/OD.
Pipe dimensions are not controlled by ID/OD but either may be kept constant over classes for practical , economic and other reasons,
To avoid having to make fittings for each class the OD may be kept constant.
With constant ID pipe classes may be changed without much change in friction losses.
Re: ID/OD Controlled Pipes
12/10/2010 7:01 AM
12/10/2010 7:29 AM
Who did your work for you before you found this site?
Register to Reply 3 comments
Anonymous Poster (1); Hendrik (1); lyn (1)
