Previous in Forum: The Physics of Santa and His Reindeer   Next in Forum: Loose Bearings - Will Anaerobic Paste Really Work?
11 comments
What Does "Food" Mean in Relation to Air Compressors?
12/22/2010 9:12 PM
Info related to air compressor:
Guttering should be attached on all of suction ducts. Inner side of suction ducts have 45° food. If you can't intall the food, inner guide louver should be attached on all of suction ducts. Suction ducts should be installed slit within intervals of 600mm.
I am wondering what the meaning of "food" is? Can anyone please explain?
Re: What Does "Food" Mean in Relation to Air Compressors?
12/22/2010 10:42 PM
the golden arches comes to mind.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
12/22/2010 10:47 PM
food.= hood?
12/23/2010 3:48 AM
Thanks for your contribution!
I think you are right.
12/23/2010 8:27 AM
Lynlynch comes thru again. Hood makes a lot more sense!
Of course we could go for an RFI and waste weeks getting a reply!
Cost Effective Answer to Concrete Corrosion
12/22/2010 10:49 PM
It looks as though multidisciplinary language has gone completely off the rails here. Sort of like an opera house in which awkwardly pronounced English is translated into English in the projected supratitles....Just listen to a D'Oyly Carte production, and you will understand right away.
Good Answers: 12
12/23/2010 11:06 PM
My guess is that it is "Feed" as in feed hose written by a Chinese manufacturer.
Doug
A robot must risk his neck for his brother man, and may not cop out when there's danger all about. - Isaac Hayes' First Law of Robotics
12/24/2010 4:44 AM
Kooks loke s middrkkubg to me.
perhaps it is Hood?
12/24/2010 10:11 AM
I think it's a typo; should be fold.
Mr.Ron from South Ms.
Good Answers: 130
12/24/2010 5:50 PM
I think you should ask the typist
12/24/2010 6:16 PM
This sounds as though it pertains to fans rather than compressors. If so, speaking of suction ducts would make more sense. Either make any elbows or tapers less than 45°, or use inlet guide vanes (louvers), for the purpose of making the air flow fairly uniform into the fan.
12/27/2010 10:25 AM
A duct supplying makeup air to a compressor room should be designed for low pressure drop and the ability to prevent rain/snow from entering the compressor. The most important instruction is never, ever, install a compressor in a room with an operating boiler...ever!
The instructions quoted (are they part of the compressor installation instructions?) should be tossed...they're pure gibberish and make no sense at all.
Register to Reply 11 comments
34point5 (1); Anonymous Poster (1); darren2264 (1); drobertson (1); Glenn Summers (1); Lou Bindner (1); lyn (1); ronseto (1); Stankane (1); Tornado (2)
You might be interested in: Wiring Ducts, Food Additives, Food and Beverage Gases
