Previous in Forum: Power Frequency Testing for EHV Cables   Next in Forum: Dangers of Extra-High AC Voltage Transmissions (500 kV)
DC Motors and Speed Control
04/05/2007 1:35 AM
why do we use dc motor to control the speed?why not ac motor?
Re: dc motor
04/05/2007 5:43 AM
The simplest form of speed control for a safety-extra-low-voltage DC motor is a series rheostat; slot-car racing springs to mind as an example.
Good Answers: 97
Re: dc motor
04/05/2007 6:02 AM
DC motors can be controlled by altering voltage (restricting the current) or by changing the load.
AC motors cannot be varied that easily. for example the speed in an existing normal motor setup can only be varied by changing the frequency.
Re: dc motor
04/05/2007 6:27 AM
...which requires a bucket-ful of electronics.
Re: dc motor
04/06/2007 2:59 PM
Nah just about a dozen well chosen things and pulse wave modulation. I built a speed controller years back with a 555 timer and three transistors a few caps and res. Back then total cost £4.00 including the box.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 54
Re: DC Motors and Speed Control
04/07/2007 3:24 AM
Control the speed of what? People are making assumptions here. An AC motor can be speed controlled also. Where did you get the idea that only DC motors can control speed?
For your info, we have two machines here made by the same manufacturer. One has a DC motor and the other has an AC motor. Both have speed control.
04/07/2007 10:16 AM
Yes you are quite corect but I was only saying about my own experiance. Many devices appliances used modified DC motors that will run on AC (the humble washing machine) for instance. Also as used on Clive Sinclairs C5 car 24V DC. both have speed controllers.
BrainWave (2); Hendrik (1); PWSlack (2); Vulcan (1)
