Previous in Forum: Insulating Steam and Condensate Lines Together   Next in Forum: Impact Force From a Tree Being Fell
26 comments
Name for Special Threaded Ring for Adjuster?
05/11/2011 9:33 PM
I am searching for a piece which I don't know the name for and after dozens of tries I decided to come to you guys for help. I call it a threaded adjuster disc but that won't work on the internet. So let me describe it.
Imagine you have a round piece of aluminum 1 inch in diameter and 1/4 inch thick, a sort of disc. Now you drill a hole through this disc at the center and tap the inside with lets say 1/4-28 thread. Finally you knurl the outer perimeter on a lathe to provide a rough surface for gripping. You use this knurled threaded disc on a long threaded rod for adjusting the height of something resting on the disc, say fork shaped. I need too many to make by hand, which is fairly easy, so I need a supplier but cant figure out what to call them. Any ideas?
Thanks
John
Re: Name for Special Threaded Ring for Adjuster?
05/11/2011 10:09 PM
I would call it "adjusting knob" and then give the the same description as you used, and/or a drawing. It seemed pretty clear to me.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
05/11/2011 10:18 PM
It sounds like a locking nut that you could tighten with your fingers (large diameter + knurled) in place of a normal nut which needs a spanner and is less accessible. Like this but with your piece in place of the nut.
The last I recall was the locknut to the flash attachment used with the older 35mm cameras.
05/13/2011 11:59 AM
Sucess is going from failure to failure without loss of enthusiasm... Winston Churchill
India - Member - New Member
Good Answers: 164
05/11/2011 10:39 PM
Would you be looking for a knurled nut by any chance ?
May look like this ...
You would need a lock nut along with this anyway, to keep it in place, as has been mentioned by Aussiebob.
05/11/2011 10:41 PM
Good answer!
But he did say that he wanted Al.
Good Answers: 164
05/11/2011 10:51 PM
Wouldn't you say Al is rather weak, both for the threads and the knurling ? i would recommend brass...or even plastic with a threaded brass insert...
05/11/2011 10:56 PM
Material selection depends on final intended use and cost parameters. He could go for injection moulded plastic, sintered bronze overmoulded rubber ..... As you indicate he will find many options now that he has some search names to use.
In "The good old days" such knurled thumbwheels were used to adjust pairs of compasses used in geometry to draw circles. Now we use the knurled thumbwheel on our mouse.
Good Answers: 164
05/11/2011 11:08 PM
Heh heh. What a superb example ! Like ... in the good old days we used to jump for exercise, now we jump to conclusions.
05/12/2011 6:36 AM
perfect again but whats it called
Good Answers: 164
05/12/2011 6:54 AM
Please click on the hyperlink i gave in post # 3. It will give you many webpages, and you may find a source near where you live, good luck.
05/11/2011 10:47 PM
Also known as a "thumb nut".
05/13/2011 8:06 AM
I agree, it's a thumb nut. Alum. is often used for adjusting equipment up down side to side. what you need would not have the bottom part (C & D)
05/12/2011 6:34 AM
Thats it exactly. Do you know who makes these?
Thanks
05/11/2011 11:06 PM
OD knurled; ID machine threaded, disc washer
05/11/2011 11:57 PM
seems like:
in german it's called "Rändelmutter"
Good Answers: 46
05/12/2011 12:11 AM
I believe what your looking for is called a thumb nut McMaster Carr has them in about the size you described.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
05/12/2011 6:37 AM
excellent. thanks
Good Answers: 266
05/12/2011 6:54 AM
Note John that you do not want to lock the thumb nut with a set screw. The screw will damage the threads and make adjusting it by hand difficult. You want to use two nuts and jam one against the other.
05/12/2011 10:22 PM
There are nylon-tipped setscrews that might work.
Good Answers: 15
05/12/2011 10:47 PM
Walk across the shop to the drill press. Mine has a couple of them to stop the depth and recoil and are very adjustable.
For every action, there is an equal and opposite criticism.
Good Answers: 74
05/13/2011 2:15 AM
It would be easy to get the disc made and then insert one of these:
internally threaded rivets
Good luck, Ky.
The Twain Has Met
05/13/2011 4:18 AM
I think you mean to a " LEVELLER " Nut?
05/13/2011 7:32 AM
OK, WOW you guys are really great. I've got tons of info now. Thanks a lot.
John
05/13/2011 10:37 AM
This component you wish is called a "thumb nut", McMaster Carr has an online catalog.
Try page 3195 catalog number 116.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
05/13/2011 10:44 AM
Call Penske shocks and ask them what they call them. Maybe even get a supplier name.
Nothing exceeds like excess.
Good Answers: 204
05/13/2011 8:08 PM
a knurled thread lock.
(similar to a lock knut or jam nut)
Register to Reply 26 comments
AussieBob (1); Beenaround (1); bobco (1); chrisg288 (1); DGCYS (1); Jaguar (1); JOHN H VAN ALLEN (4); Just an Engineer (2); kvsridhar (4); ky (1); lyn (1); metalSmiths (1); Niranjan_ngp (1); ozzb (1); Q (1); Tornado (3); WilhelmHKoen (1)
