Previous in Forum: How to Find Loss Factors in Ansys Workbench Using Modal Analysis   Next in Forum: Virus that Destroyed My USB Flashdisk? or RAW Format?
44 comments
Popular Science - Weaponology - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Electrical Engineering - New Member
Square Puzzle
06/26/2011 2:31 PM
hello CR4 users,
is it possible to divide the square into 7 equal squares? if anyone know the logic how to do it please help me out.
knowledge is increased by sharing!!!!!!!!!!!
Re: square puzzle
06/26/2011 2:39 PM
You can't do it with simple whole squares, but if it is allowed to assemble the 7 smaller squares from triangles, then it can be done. It might be an interesting challenge to do this with the minimum number of pieces, or with the fewest number of different shapes.
If you search on "geometric dissections" you might find some good ideas.
Re: square puzzle
06/26/2011 3:37 PM
y^2=7*x^2
y^2/x^2=7
y/x= srqt(7)=2.6457513....
So, since y/x is not a whole number, it is not possible.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: square puzzle
06/26/2011 4:07 PM
Not all 7 equal to each other, but 7 squares:
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: square puzzle
06/27/2011 1:15 PM
Nothing against usbport, but who voted this as a GA? The question is very clearly stated. It's asking for "equal squares". This solution doesn't solve the problem in any way whatsoever.
Re: square puzzle
06/27/2011 3:30 PM
I for one: the question as it stands is unanswerable, unless you count the answer of BeenAround (and someone marked that as off topic: I've cancelled that). So it seems reasonable to look for ways in which the question could have been corrupted.
Good Answers: 39
Re: square puzzle
06/27/2011 3:55 PM
I'm not following you. The question, as it stands, couldn't be more clear. There are only three requirements for the answer.
1. That they be squares
2. That they be equal
3. That there be 7 of them
I'm sure usbport wasn't saying that he had the solution. I suspect his drawing was tongue in cheek. Either way, it doesn't satisfy both requirements, so it's as wrong & useless (aside from the humor value) as any other wrong answer.
Saying that "the question is unanswerable" could potentially be a valid answer. The only thing we don't know in regard to the question is: Does the OP know the solution, and is challenging us to come up with it? Or... Does the OP not know if a solution exists, and is asking if any of us know?
But the drawing above is not a valid answer at all.
Re: square puzzle
06/27/2011 2:52 PM
cute
Re: square puzzle
06/27/2011 8:45 PM
I was thinking of seven different sizes, but the three of one size and four of another looks more elegant. Now, he says he wants seven equal size squares. Even though they wouldn't fit together to make a square, you could take the total area, divide by seven, and then make a square using that 1/7 area. I think we need more clarification.
Being peer reviewed requires you to have peers
Good Answers: 74
Re: square puzzle
06/27/2011 9:27 PM
A bit late to get into this Usbport
I kept counting but always found 8 squares.
I once made a 7 cornered frame for my boss when I was working in picture framing. I had young Charlie as an apprentice. He said it was impossible but I showed him how to do it. He was the co-creator so it was an Xmas present from us both. The boss couldn't believe it either but he had two left hands at the best of times.
A few circles here and there, a straight edge and jigs and bobs your uncle. Same goes for glass or cutting in marble floors. My back hurts just thinking about it. Stuff all the numbers, if the customer asks for it its gotta be done by some one.
Try it, its fun when it works out, Ky.
The Twain Has Met
Re: Square Puzzle
06/26/2011 9:30 PM
Basis: Area of square = 100in2
100in2/7 = 14.28571in2
The square root of 14.28571 = 3.780.
Your seven squares are each 37.8% on a side compared with the original.
Good Answers: 15
Re: Square Puzzle
06/26/2011 10:47 PM
NO
For every action, there is an equal and opposite criticism.
Re: Square Puzzle
06/27/2011 1:31 AM
I do not think that it is possible to divide a square into a prime number of equal squares.
bioramani
Good Answers: 130
Re: Square Puzzle
06/27/2011 2:30 AM
I was thinking "odd number" but that too.
It seems to me the 'logic' is; the divisor must be even* or the square of a whole number.
But I could be wrong - just something about the 'square concept' seems to whisper that to me
*fixed in edit
Re: Square Puzzle
06/27/2011 2:47 AM
You are right. It has to be a number that is a square, odd or even. Sudoku has 81 squares, consisting of 9 squares each with 9 small sqaures.
I do not think even number per se work. For example, one cannot divide into two equal squares or eight.
bioramani
Re: Square Puzzle
06/27/2011 3:24 AM
Cancelled. (My question was already answered.)
Good Answers: 130
Re: Square Puzzle
06/27/2011 3:32 AM
42, 6 ..... Wot? canceled - rats
Re: Square Puzzle
06/27/2011 4:10 AM
We don't know yet if the puzzle allows the smaller squares to be assembled from yet smaller pieces.
As has been noted, if you divide a square into smaller equal squares whose total area equals that of the original square, then the number of smaller squares must be a a perfect square (4, 9, 16,...). But that is too trivial to be of interest.
In the present puzzle, you can get at most 4 smaller squares of the right size; the remaining 3 squares must be assembled from yet smaller rectangles or triangles. I haven't yet found an elegant solution for this, such as the smallest number of pieces or the smallest number of different shapes.
Good Answers: 130
Re: Square Puzzle
06/27/2011 5:16 AM
Well I got insecure and 'edited in' "even number" thinking of 'even sides' but as "8" pointed out that flaw, I'll just stay with 'square of a number'.
The cutting to triangles is interesting. Essentially a diagonal division. I guess the target is 28 x ¼ squares, or 56 x 1/8 squares - but all I get is multiples of 4. LCM seems a way lot of cutting
Of course if we are cutting, we could assume a scrap allowance, so divide into 8 and just chuck the scrap one?
Good Answers: 130
Re: Square Puzzle
06/27/2011 6:40 AM
But on thinking further - it might be done if you divide the area by 7 then draw 6 squares of that 1/7th area, then divide the remaining 'border areas' (side and top) into squares the size of the remnant in the top corner - which should then assemble into the 7th square.
Re: Square Puzzle
06/27/2011 7:49 AM
Good point! (Although I agree with somebody else, I suspect Usbport's answer is the desired answer, with some corruption in the question.)
Taking your approach, maybe only 4 squares can be drawn directly (calculation below), then 3 squares assembled from the left over bits.
Just using a 10x10 square, area = 100, 1/7 of that is 14.285..., so to make a square of that area, take the square root (= 3.779...), so in a 10x10 square you can draw 4 "whole" squares 3.779... x 3.779 (in a 2 x 2 configuration).
Could you do something with the remaining area to make 3 more squares--something like creating triangles and (short of grinding it up in a blender and "painting" 3 more squares).
From some quick sketches it doesn't look easy / straightforward.
Good Answers: 130
Re: Square Puzzle
06/29/2011 7:41 AM
Well I had some time so;
Gets a bit "mouse milking' in the last annoying bit.
Total 4900 mm2 - 4 x 700 mm2 + 4 x 350mm2 half squares = 2, so total 6 equal squares, at first pass.
And, as said, 'building the remnant on the corner' - now demonstrated = 1 = total 7
But the way I did it: it's just down to getting out the very sharp scissors and microscope, because to get the tiny 450 pointy bit I had to cut one resultant 900 end in a half mm wide bit, at 450, at the mid point, and glue it back on.
Perhaps the new competition can be doing 'more elegantly'
Re: Square Puzzle
06/27/2011 2:48 PM
Very difficult to have a square as remnant.
The nearest I got was 1764 / 7 = 252 which is the square of a fractional number 15.87450786638750...?.
A square number is X = a2
(X/7 - Int(X/7)) = b such that 6 * b = Int(X/7) and Int(X/7) = c2
Therefore, 6*c2 + 6b = 6*6*b + 6b = 6b(6+1) = 7*6*b = X or = a2
Then 6*b = a2/7 and b = a2/42
Take b=42
Then 6*b = 252
Then a2 = 7*6*b = 1764 this is the square
Divide this 1764 by 7 = 252
And 252 =(15.8745078663875000??)2
Re: Square Puzzle
06/27/2011 5:41 AM
Sajal,
Bravo88 and Mikerho have shown why it's impossible (Good Answers).....
Do you need any more explanation?
Tornado and USBport have also had good ideas. (I bet USBport's is the answer and the question has somehow been corrupted).
Good Answers: 53
Re: Square Puzzle
06/27/2011 5:46 AM
Forget 7, can you divide it in two equal squares? answer is no.
you can only divided it in equal pieces of 4, 9, 16, 25, 36, ---------
Good Answers: 266
Re: Square Puzzle
06/27/2011 8:00 AM
If the square is a market square. It can be divided in to equal area, equal number of shops, or maybe equal in the fact they all have one fountain. Each one named as a separate market square.
Ok play on words But it can be done!
Good Answers: 94
Re: Square Puzzle
06/27/2011 9:28 AM
Easy, divide it into 8 squares & throw away the spare bit. The OP says the 7 squares have to be equal but not that the total has to equal the original square.
(OK, I know I'm clutching at straws here).
Re: Square Puzzle
06/27/2011 9:41 AM
8?
Good Answers: 94
Re: Square Puzzle
06/27/2011 12:18 PM
Sorry, I meant 9 but my PC keeps printing the keys I press instead of what I meant to say.
Re: Square Puzzle
06/27/2011 10:20 AM
Think about it. If you are dividing by cutting the square, one edge of the smaller square is the same as the edge of the original square. So the length of the edge of the original square is a multiple of the length of the edge of the smaller square.
Let's call the multiple, n.
And, as we are cutting squares, the multiple along one of the adjacent edges is also n.
So we are cutting the original square into n*n smaller pieces, or n-squared.
(As has been said elsewhere in the thread, you can only cut it into a square number of equal sided squares)
So unless it is a carpet-remnant problem where it is allowed to stitch together separate pieces...
Divide it into 9 equal squares, and hide two of them.
or since, I prefer dividing by 2's than 3's, might as well divide it into 16, keep your seven, and I'll take the other 9.
Good Answers: 15
Re: Square Puzzle
06/27/2011 3:46 PM
ok, since my answer of "NO" wasn't considered very good, go to a search engine of your choice (google, bing, yahoo, etc) and look for a square root calculator and enter 7 then find, which would be the needed length of one edge of a square. If you don't understand that answer, make sure you find a calculator that has about 100 decimal points. Dang, I forgot to ask, is this a metric square? Maybe they have different rules for them.
Good Answers: 39
Re: Square Puzzle
06/27/2011 3:59 PM
I wouldn't rule out your answer of "NO" as not being a good answer. It may indeed be the only correct answer.
Re: Square Puzzle
06/27/2011 9:08 PM
"is it possible to divide (a) square into 7 equal squares?"
It turns out the answer is simple, no. But you can cut it into smaller squares that can then be assembled into 7 equally sized squares. It takes a minimum of four squares to assemble into a larger square, or think of it as 2 squared. The next multiple would be nine, or 3 squared. All we have to find is the lowest multiple of 4, or 9, or 16, or 25, etc., and our key value of 7 that is the square of a whole number. Oviously, 7 times 49 works, but is there a smaller one?
Good Answers: 39
Re: Square Puzzle
06/27/2011 9:39 PM
Okay, time to earn my name. Tell me if this satisfies all the requirements:
1. You take a 7" x 7" square piece of paper.
2. You draw 6 parallel lines on it, 1" apart.
3. You fold it on each line in a zig-zag fold.
4. This gives you a strip that is 1" x 7".
5. You draw 6 parallel lines on this, perpendicular to the folds, 1" apart.
6. You crease on each line, in the same direction, and form a heptagon.
7. You now have 7 equal squares, forming that heptagon.
Good Answers: 15
Re: Square Puzzle
06/27/2011 10:10 PM
Nope, when you divide something, you should always be able to add it back together to be whole (not me , Einstein said it). You trying to sell that 7 one inch squares would be equal to 49 square inches that the original square was.
Good Answers: 130
Re: Square Puzzle
06/27/2011 10:31 PM
I like it origami!
"Satisfy"? except for the part where you make it 3D - so now have 14
Re: Square Puzzle
06/28/2011 5:19 AM
hello everyone,
after reading all of your answer it is look like it is not possible
or possible in the squares of numbers or in whole or if it is unequal squares.
now if question is changing little bit let now we have to divide the square in 7 parts in which some of them are equal squares and some of them are equal rectangles and only two values of area is possible one for square and another one for rectangle.
Anonymous Poster #2
Re: Square Puzzle
06/28/2011 2:08 PM
Haha, bravo88 answered this question perfectly some 30 posts ago... GA
Re: Square Puzzle
06/28/2011 11:06 PM
In Euclidean 2-space, it can't be done, as others have ably shown previously, however...
In mathematics, a square could easily have sides named ''s'' such that the area
of such a square would be such that A = s^2.
And, one seventh of such an area could be expressed mathematically as:
A/7 = (s^2)/7
Then, the side of such a square would mathematically be of a length;
l = /\/(A/7) = /\/((s^2)/7) = s / ( /\/(7) )= ( s /\/7 ) / 7
which has one mathematically real root, and one imaginary root.
This is a mathmatically sufficient solution, but not a physically sufficient solution...
So, yes it is possible in math, but not in two dimensional real space, really...
Good Answers: 15
Re: Square Puzzle
06/29/2011 5:09 AM
Hmmm imaginary root... is that like the imaginary collateral that lead to the banking collapse not so many months ago? Let just imagine we gave you a score.
Re: Square Puzzle
06/29/2011 6:03 AM
This is a 2-dimensional problem that doesn't involve high-dimension hypersquares, isn't it?
Re: Square Puzzle
06/29/2011 12:41 PM
....or put another way, can 7 equal squares be arranged into 1 big square.......
Re: Square Puzzle
07/04/2011 7:34 AM
hello everyone,
everyone said that division of square into 7 equal squares is not possible but now i am chnaged the problem in comment no. 35
But no one comment on it what happened it is also not possible with some number of squares or rectangles????????/
if anyone know the logic please help me.
Re: Square Puzzle
07/04/2011 7:51 AM
Like one of these?
Re: Square Puzzle
07/04/2011 8:58 AM
thank you randall
for your answers
you are very quick
Register to Reply 44 comments
34point5 (6); Anonymous Poster (1); Beenaround (4); bioramani (2); bravo88 (1); davidmac (2); Kris (1); ky (1); LAA_Lucke (1); Mikerho (1); MR. Guest (1); Nigh (2); Out of Box Experience (4); ozzb (1); p.k.datta (1); PWSlack (1); rakesh_semwal (1); Randall (4); rhkramer (1); sajal mittal (3); Tornado (3); Usbport (1)
