Previous in Forum: PLC Specification   Next in Forum: Impact of Device ID of HART Devices
21 comments
Seeking a Way to Detect Underground Voids in Lava
06/26/2011 5:46 PM
I'm trying to find a device that can locate underground caves, tunnels, tubes, chambers, etc. in lava - something like ground penetrating radar, maybe? There are many tubes and caves in the area surrounding of my location, most of which were found only when part of the roof of one had collapsed. I'd like to find a way to "look down" through the surface lava to detect voids. I understand that I will most likely need a subject area expert to interpret any "readings" a device may give. Any suggestions about the type of device to try, as well as possible consultants or contractors who might be available to assist me in the Eastern Columbia River Gorge area of Washington, will be appreciated.
Good Answers: 146
Re: Seeking a way to detect underground voids in lava
06/26/2011 7:17 PM
You might want to talk to the archaeologists involved in this project:
http://news.discovery.com/history/pyramids-egypt-nasa-satellite-110526.html
incus opella
Good Answers: 145
Re: Seeking a Way to Detect Underground Voids in Lava
06/26/2011 8:42 PM
Please check back and let us know how this is going. You may or may not find anyone here with the knowledge to help you but there are a lot of people here who are interested in your results.
06/26/2011 9:34 PM
Maybe a bunch of dowsers will show up and offer their services.
06/26/2011 9:52 PM
Wouldn't the underground tunnels, tubes and chambers have to be flooded for dowsers to work?
Not being a dowser, I don't know all the finer points.
06/26/2011 10:04 PM
I really miss that region (used to live in Kennewick). Although there is evidence of volcanic activity in that area, I wasn't aware that there were lava caves/tubes/chambers. What is your focus? What do you hope to find?
Hobbies - Fishing -
06/26/2011 10:49 PM
Looking for Mel's Hole?
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
06/26/2011 11:19 PM
There are some geographic (as well as editorial) errors in that article. (As might be expected in "Coast to Coast" productions.)
Manastash Ridge is on the west side of the Yakima River; the Yakima Firing (now Training) Center is to the east of the river, roughly 15 miles away from the ridge.
The Ape Cave, near Mt. St. Helens to the SW, is an example of a rather large lava tube, roughly 10-30 feet diameter and over a mile long.
The DeLorme topographical atlas has a joke symbol of a sasquatch about 13 miles NNE of Mt. St. Helens.
06/26/2011 11:16 PM
You have asked most of the right questions.
If you google "Ground penetrating radar" (Or "locating underground pipes") you will come across three different types of entry. Those that want to tell you what GPR is and the theory of operation, those that want to sell you GPr equipment or accessories and those that contract their services using GPR.
There are conractors out there who provide services to sewer authorities to locate underground pipes (especially plastic ones with no meatalic trace).
GPR has some limitations that work in your favour for voids in solidified lava.
The greater the difference in density of the surround and the void the better. That's why they offer to find sewer pipes (mostly full of air), but rarely offer to find water pipes.
The lava should have a reasonably consistent density, so there should not be intermediated density changes to give false reflections.
You can use different frequencies to "look" deeper into the material.
Have fun!!
06/27/2011 10:41 PM
Using infrared they continue to find civil war soldier graves in many soil types. This is similar to what artsmith describes for locating the pyramids.
The size of what you are looking for determines how far away you need to be to "see" the difference in temperature, the solar heating provides the heat source, which a void looses its heat quicker then a solid, but the depth and size of the void determines the rate of heat loss. If the void is large you may only see an edge, if the void is at a descending angle.
I have had a professor from New England who wanted to look for the underground caverns in Florida with an infrared camera mounted to an unmanned aircraft and transmitting video to a receiver at his mobile location on the ground.
Usually the infrared camera has a very wide angle lens between 25 and 5mm depending upon how big an area you want to see and the number of pixels in the infrared camera detector. For a 256x256 pixel detector and 5mm lens at 5,000 ft each pixel is about a 3x3 foot area on the ground. Flying slow, using high-high sensitivity infrared camera (check out www.infraredcamerasinc.com ).
The application is very similar to border patrol. You will want a visible camera and an infrared camera looking at the same area at the same time, i.e concentric focused, auto focus is unlikely to work due to changing scene (best to get into the infinity focus part of the lens), and probably sychronized shutters will make it easier to match the images.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
Good Answers: 204
06/27/2011 10:59 PM
no problem...
the device is called a "Drilling Rig"... and can easily and routinely detect those types of things.
that was easy
chris
06/28/2011 3:20 AM
Check with the USGS for Cross hole Tomography. I have first hand experience and this type of Cross hole will show you the tunnels or lava tubes quite well. The USGS would be a good place to check. Check out this link http://walrus.wr.usgs.gov/geotech/highres/. Good hunting.
07/02/2011 8:48 PM
Good suggestion. I think USGS has a large office in Vancouver, WA to study Mt. St. Helens - about 40 miles or so from me - and the other Cascade volcanoes, among them Mt. Adams, which is about 8 miles from me. I'll give them a call after the 4th and ask about Cross hole tomography. Thanks.
Good Answers: 266
06/28/2011 6:59 AM
Thumper truck and seismic equipment same way they explore for oil and gas.
06/28/2011 10:20 AM
You mean one of these?
*Thumper the Rabbit, character in Walt Disney movie, "Bambi".
Good Answers: 266
06/28/2011 10:54 AM
hey to scale he might just be able to do the job.
But wouldn't want to have to feed him or clean up after him.
Just think how big those round balls will be.
06/28/2011 11:00 AM
Yeah, and alfalfa pellets the diameter of telephone poles.
BTW, I like your tagline. Kinda fits my risk-enhanced lifestyle. Dirt and street motocycles, downhill skiing, water skiing, voting Republican in Maryland, . . .
06/29/2011 12:07 AM
Gee Ozz, I think we pissed someone off. Never mind we already self-marked ours as off-topic. Oh, well some folks have no sense of humor.
Good Answers: 151
06/28/2011 8:12 AM
There are a number of Geophysical methods that might be employed for this. One method that I recall from my Geophysics course many years ago was seismic refraction.
This method measures the change in velocity and direction of a seismic wave as it encounters a change in density of the underlying rock or soil. An open void in the rock would stand out clearly.
I recommend that you contact the Geology department of your state university. I am sure that they will have the necessary equipment. Your interest may lead to a good project for a Geophysics student.
Good Answers: 27
06/28/2011 10:13 AM
You may try echo or ultrasonic imaging devices used to detect voids or inconsistent material characteristics. We had used same technique back in the '60s in doing quality assurances for concrete slabs and foundations to detect flaws in constructions prior to final acceptance. Had success in detecting old construction debris /buried lumbers left behind, or had been purposedly thrown into the mix of a supposedly spec'd solid concrete foundations for oil refineries.
Some can be found by searching the web under echo or ultrasonic scanning.
vsar
06/28/2011 11:22 AM
Depending on depth, take a look at this website.
06/29/2011 1:40 PM
That looks like just what I need. The cases on their site show examples of work almost identical to what I have in mind. Thank you.
Register to Reply 21 comments
Anonymous Poster (1); artsmith (1); Brave Sir Robin (3); BruceFlorida (1); chrisg288 (1); CoronaCameraMan (1); GRA (2); gringogreg (1); Just an Engineer (1); lighthasmass (1); lyn (1); Mikerho (1); ozzb (2); relee1950 (1); Tornado (2); vsar (1)
