Previous in Forum: Source of Carbon Brushes for 12 Volt Auto Motors   Next in Forum: Tube Tyres into Tubeless Conversion
18 comments
Brakes
09/06/2011 1:02 AM
why is the brake pedal stiff and the car doesnt stop brake booster or vacumm leak?
Re: brakes
09/06/2011 1:12 AM
Vacuum leak in the brake booster.
Have it replaced.
If you are really an ex mechanic, you would know how pitifully inadequate your question is.
Take it to a real mechanic.
Better yet, have it towed to a real mechanic.
Re: brakes
09/06/2011 1:18 AM
I was a diesel mechanic not sure about car braking systems
CR4 ADMIN: Modified Post
Vulgar/Rude/Improper Behavior: This post was modified because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Re: brakes
09/06/2011 2:04 AM
Diesels don't have brakes?
Since you admit that you don't know anything about braking systems, why would you even ask? There are safety implications here that a real mechanic would recognize.
Like I said, have it towed to a shop and and have it fixed by someone who is, " sure about car braking systems".
Re: brakes
09/06/2011 2:08 AM
They have air brakes not hydraulic
Good Answers: 44
Re: brakes
09/07/2011 11:11 AM
Ah...Lyn...PWN!
Don't worry Ex...he comes down hard on anyone who he perceives to be a danger to themselves or the public at large.
But you get the pwn...
Good Answers: 266
Re: brakes
09/06/2011 7:20 AM
A mechanics a mechanic no matter what area or field he works in. Most of the enjoyment of the job is to figure the puzzle out. So if you were a true mechanic you would have sought out the knowledge to do so. Not asked strangers on a web site that may lead you to death or injury. What Lyn un-tactfully tried to imply is seek out someone that you can trust to give the right information. Like a mechanic that does work on brakes in you area. I am a mechanic by trade and it could be any one of the devices you mention or something else. With out the car in front of us it very hard to make a diagnoses.
Would you seek out medical care for youself or a love one off the internet. I hope not!
So why would you put yourself or those loved ones in a car that the advice to repair it came from some forum. Anyone can lead you down the wrong path.
Re: brakes
09/06/2011 11:05 AM
Weil said, I believe what we're looking at here is a common condition of our times. There is a major difference between a mechanic and a technician. Technicians are trained, mechanic ability can be cultivated but there must be something there to grow.
Mechanics inexorably possess the ability, for lack of a better term, to apply cross platform knowledge. Mechanical problem solving is fundamentally enjoyable for a real mechanic, particularly when it involves dealing with something that you previously have little or no experience with.
Several years ago I went through about 6 HVAC service trainees. Of that lot 4 were completely useless; one was motivated and could've eventually been trained as a technician, it would have probably required two years to get him to the point where he could confidently be sent out on his own.
One nineteen year old possessed remarkable mechanical ability.Had he not had other problems, drugs probably being the most prominent one, he would have been on his own in a matter of months. I'm confident that with fundamental training and a cell phone that person could have handled most problems.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Good Answers: 123
Re: brakes
09/06/2011 9:30 PM
I remember when I was hired many years ago. The supervisor was making a comment on another employee. "After two years here, he is now smart enough to go to a training seminar without embarrassing us."
Sounds like the same problem.
Bob
Good Answers: 150
Re: brakes
09/06/2011 9:47 PM
Sad fact, you either have mechanical aptitude or you don't. It cannot be learned.
Who is John Galt?
Good Answers: 97
Re: brakes
09/06/2011 1:32 AM
The car is not supposed to stop the brake booster (malfunction) or a vacuum leak by itself, mechanic intervention is required.
(could not resist)
The method you should follow is to start at the customer end of the brake system and tick of every thing that is working.
For example start with the bake pedal mechanical links and work towards the pads step by step.
If you cannot tick an item adjust / repair / replace
you will have the car braking (or breaking) in two ticks.
Good Answers: 150
Re: Brakes
09/06/2011 1:56 PM
If there is trash and/or water in the system the brake equalizer valve may have frozen up/become clogged. Other possibilities are: a crimped line, frozen wheel cylinders/calipers, maladjusted shoe adjuster, brake pads/shoes that have been contaminated with brake fluid from leaking wheel cylinders/calipers.
Power Brake systems are designed to operate (but with increased pedal force required) even when the booster has failed as a failsafe. Power steering systems also will operate (but without any power assistance) if the hydraulic system fails for the same reasons.
Who is John Galt?
Good Answers: 123
Re: Brakes
09/06/2011 9:51 PM
Some one forgot to remove the Club. Or, there is a brick under the pedal.Or the pivot has rusted. Or Lyn put motor oil in the master, months ago. Or there is water contamination of the brake fluid, and the piston has corroded to the cylinder wall. Get the picture, there are many things that could cause the results you have. Look closely, and you will be able to eliminate many of them.
Automotive brake systems have power assisted hydraulic brake systems. ( except some Rolls Royce brake systems) The vacuum booster is used to help push the pedal down, relative to how hard you push the pedal. Air brakes on a heavy truck have no breaking action if there is no air pressure. That is why there is spring apply parking, or emergency brakes.
Bob
Re: Brakes
09/07/2011 1:09 AM
replace the vacuum lines along with the booster grommet. ckeck for vacuum leaks. i use an unlit propane torch. if you have a leak, the engine will speed up.
don't bother commenting guys. i've aready heard all the preaching.
Re: Brakes
09/07/2011 1:11 AM
could be a bad diaphram in the booster.
Good Answers: 44
Re: Brakes
09/07/2011 11:53 AM
I still cannot believe all of the belittling attitudes towards anyone who asks a legitimate question on the board. If we don't know the answer to the question why can't we keep our comments to ourselves? Just because the OP's moniker is ex-mechanic doesn't mean they are an "ex-mechanic". And, yes, mechanics do specialize in certain systems on a vehicle and one may only be expected to profess expert knowledge on any one system when quizzed. Engine or diesel mechs may have never touched a brake system (hydraulic or air), and vice versa. I wouldn't expect an exhaust guy (a "mechanic") or a brake guy ("mechanic") to adjust my drive by wire system or troubleshoot a gremlin in my electrical system ("technician").
I am not from Cuba...nor am I the original Cuban Pete. It's just a handle. Any reader doesn't know any more or less about me by my profile or my handle. For all you know I am a 10-year old female from the Ukraine who happens to like engineering topics.
There are a lot of people who comment on posts and start out by saying they aren't engineers or it comes out during a discussion...so we get best guesses by educated people...maybe. It may be valuable, or it may be worth a pile of crap...either way it's an unpaid opinion (which oh-so-many people also point out that a paid-opinion should be got...as if it would be worth as much or more).
I suggest we keep on topic or have people mark their responses off-topic so I can use my little plus/minus to hide the off-topic banter. I hope that people don't come here just for the witty "bash-the-OP" rapport.
Good Answers: 123
Re: Brakes
09/07/2011 12:40 PM
Do you have an older sister?
Bob
Re: Brakes
09/07/2011 1:18 PM
I'm sending myself to the naughty step.
Good Answers: 44
Re: Brakes
09/07/2011 1:52 PM
Awww man...I was really hoping for something better...it's cool.
Register to Reply 18 comments
Anonymous Poster (2); bob c (3); cuba_pete (3); ex mechanic (2); Hendrik (1); lyn (3); ozzb (1); Rorschach (2); YWROADRUNNER (1)
