Previous in Forum: Searching For an Ethernet Panel Jack   Next in Forum: PIC Programming
10 comments
Hobbies - RC Aircraft - New Member Old member.  Heidi;  need to develop paper glider technique.  Use to
Retired, No Title
11/19/2011 1:43 AM
Having worked in the San Jose postoffice for about four or five years a long time ago as a Mail Handler I once submitted an idea to them about getting the mail which was dumped out from mail sacks to a conveyor belt and then taken to the clerks at some distance who knew the scheme of the various zones. This was done by first taking the mail off the belt and then placed into trays which were then placed on the top of a cart. After stacking a reasonable amount of trays on top of each other, the cart was wheeled to various clerks who were processing the letters. My idea was to just place the letters into something shaped like a football which could be opened and shut and using the idea of fluid dynamics have the football shaped containers "flowed" to funnels in front of each clerk processing the letters. The funnels could be opened at desired times to drop the letter containers in front of separate clerks who could open up the "footballs", take a handful and start their job of placing the letters into the correct pidgeon holes. Probably the post office now has their own system. My idea was naturally rejected. But are there any worthwhile comments on this Rube Goldberg idea at this point in time?
Re: retired, no title
11/19/2011 2:24 AM
Why use conveyors? Just throw the footballs from one station to another.
This would give retired quarterbacks something to do.
Good Answers: 97
11/19/2011 3:48 AM
► 2:46► 2:46 www.youtube.com/watch?v=bB7dhE_TW9g
Heidi
You saw a problem and applied your ind to it (good)
Good Answers: 102
Re: Retired, No Title
11/20/2011 12:59 AM
Your idea sounds like the "old" pneumatic tube system that once proliferated. Still has some niche applications
I don't think that mail is sorted manually anymore. Not in the developed world at least. I stand to be corrected on that one.
11/20/2011 5:37 AM
In the early`90's it required 17 people to process about 40,000 pieces of mail an hour.It consisted of 12 keyers,who had 1 second to look at,read,interpret,fetch bar code from memory, and key in the results.The mail piece was either keyed in that 1 second interval, or it moved on to a no-key bin.It took 4 sweepers to remove the sorted mail from the bins.It also required a supervisor for each machine.They had to key 99%+ or they were sent back for retraining.Their results could be audited at any time by the supervisor without their knowledge. Some streets had multiple zip codes, depending on address, so they also had to remember the changes on each street.This was an amazing mental and physical feat, and these people did it night after night, all the while listening to headphones and keeping a 1 second beat.
Everything now is basically computerized and automated.The machines run 40,000 pieces an hour,with 1 operator, 1 sweeper per machine, and 1 supervisor for the whole operation.No memorization of zip codes is required,training required is minimal.Conveyors are used prolifically throughout the operations.
Manual casing of mail is very minimal,usually odd shaped or damaged mail,(ink pens, bottle caps,jig saw blades, etc) or mail that is out of specification for automation.
You really should visit a local large post office to see the changes that have occurred in the last 20+ years.
Good Answers: 25
11/20/2011 6:41 AM
Now a days who sends mail as print out? Everyone uses e-mail which is faster and free.Post offices are mostly empty, once they were fully packed and there were long ques. Post boxes are only quarter filled. Post offices are running losses, they are adding new services to survive.
Good Answers: 102
11/20/2011 7:03 AM
I still get postal mail. I can't remember the last time I ever sent a letter that way.
11/21/2011 11:26 AM
Your first mistake was in attempting to use logic and reason at the Postal Service! I stopped doing that many years ago and things are going swimmingly for me now. Frankly I'm surprised that they didn't promote you to Post Master on the spot just to stop that sort of behavior! thinking...thats crazy talk!!!
CARPE CRUSTULORUM!
11/21/2011 6:32 PM
You have it backwards.The people on the bottom do the thinking, not the top.The :"PETER PRINCIPLE "Promote to the highest level of incompetence, then back off one level.") Except, at the P.O. they don't back off, they just keep on moving up.
"Screw up--Move up" seems to be their motto.
11/22/2011 1:14 PM
(Crap, this guy has figured us out! We gotta get him!)
CARPE CRUSTULORUM!
11/22/2011 11:38 PM
I had better drop out of this discussion.
Register to Reply 10 comments
Heidi (1); Hendrik (1); HiTekRedNek (2); not so smart (2); suresh sharma (1); Tornado (1); Wal (2)
