Previous in Forum: FPS Bricks   Next in Forum: What is it??
45 comments
Where Do Smells Go????
12/08/2011 10:29 AM
Where do smells go??
If you burn toast or make coffee the smell hangs around, but after a few hours its gone! even in a closed room, so where does it go?
I suppose a smell is some form of volatile organic compound (VOC) which decomposes into ... what?
I must know the answer PLEASE..... :-/
Good Answers: 266
Re: Where Do Smells Go????
12/08/2011 10:55 AM
Settle to the ground where they are attracted to peoples feet.
12/09/2011 6:14 PM
Partially correct. Actually, it depends on the molecular weight of the particular compound. Anything with a molecular weight much above 40 will sink to the floor and stink up your feet and carpet (CO2 = 44). Anything in the range of 30 - 40 will just diffuse below detectable limits due to Brownian movement and local breezes. Anything much below 20 - 25 will go up and stick to the ceiling. (Or the bottom side of airplanes) Note that the MW of Oxygen is 32, Nitrogen is 28. Those that are soluble in water are washed out by rain, fog and dew.
Just because it has a patent doesn't mean it is the best solution. Just because it has no patent doesn't mean it won't work. A patent is only a license to litigate.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
12/08/2011 11:50 AM
Nowhere, mate. Nowhere. <Splutter, cough>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 918
12/08/2011 6:35 PM
That's leveraging you name!
Good Answers: 918
12/08/2011 12:08 PM
Put a drop of colored water dye in the ocean and watch where it goes. :-)
The process is called diffusion.
At some point the molecules that you "smell" may decompose or settle out of the atmosphere.
12/08/2011 1:15 PM
Oh shoot! Now look what you made me do:-
Good Answers: 918
12/08/2011 2:08 PM
That was waaaay too funny!
12/08/2011 2:13 PM
NO! NO! Just a drop.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
12/09/2011 4:19 AM
That can't be the answer. After all, repeated dilution makes the medical effect stronger. Or is it only water that has memory?
---Gypsy Rose Lee
<creeuch>
Sorry folks, I've been channelling again....ER
Chaos always wins because it's better organised.
12/09/2011 4:26 AM
Gypsy Rose Lee is not a bad channel, though.
Good Answers: 75
12/09/2011 4:48 AM
Wrong time of year for performances...a tad chilly....
Good Answers: 16
12/09/2011 3:11 PM
Good answer. You might add that below a certain concentration most human noses can no longer detect the smell/odor (most animal noses, especially dogs, can beat us badly in detecting weak and old scents). The scents disperse due to wind and heating/Brownian motion. Most of the scents are composed of long chain organic molecules that break down over time due to exposure to sunlight (UV radiation) and oxidation.
12/08/2011 12:21 PM
a slogan from the big polluters from the 60'. The solution to pollution is dilution!
12/08/2011 12:23 PM
Well I've asked around and we're down to two possibilities...they get smelled up....they all go to the city dump...
12/08/2011 12:29 PM
12/08/2011 3:34 PM
Depending on what I eat, the aroma might never go away. And it follows me from room to room.
Good Answers: 61
12/08/2011 5:18 PM
That's a very good question and one that I have pondered. Apart from diffusion into other rooms and the exterior, could some odors condense out as liquids or solids on to everything in the house? The actual mass of strong odors might be extremely small and would form a very thin film on walls, ceilings, furniture etc. If you have ever moved into a house that has not be painted or cleaned for years, you may find all surfaces slightly sticky and discolored - I know from experience - and it's particularly so in the kitchen. I would suggest that this is the "ghost of odors past."
Also, your nose gets used to odors fairly quickly. When the odor seems to have dissipated, someone else walks in from outside, their first reaction may be "who burned some toast?"
In the days when smoking was normal in pubs, restaurants & cinemas etc., I used to return with my latest sweater or flairs (!) reeking of smoke. I developed a simple method of desorbing the smell by holding the waist of the sweater over a fan heater, which would inflate the clothing with hot air. After about 1 minute the smell had all been desorbed. Marvellous.
Good Answers: 38
12/08/2011 9:17 PM
destroyed by febreze
12/08/2011 9:52 PM
Houses are not nearly sealed as well as you think and a closed room still breaths through the cracks and seams in the walls, floors, ceiling and obviously the air ducting.
In a few hours most of the volume of air in your home has probably been exchanged to the point of having taken enough of the associated smell with it to be at the point well below the average persons ability to smell anything.
12/08/2011 10:07 PM
Well, I can see there are no dog owners on this thread.
It's obvious to me, my dogs sniff them all up (especially the nasty ones), concentrate them, and then emit the rankest farts you have ever smelled. Then they sniff those up, and use them as a "yeast starter" for the next batch - which are even worse.
12/09/2011 12:17 AM
Some of them just soak into sofa cushions....
12/09/2011 7:42 AM
When the front office at the company I worked for received new office chairs, engineering received the used ones.
One of my designers absolutely refused to except them, the girl that brought it up to us was so offended, and a spat developed and accelerated.
Curious, I was wondering where this was going, so I let it play out. And the girl was getting rather p.o.ed.
Until the designer said, I will not except this chair, not until you vacuumed all the farts out of it.
Needless to say, as mad as she was she still had to laugh, but she still went away mad.
12/09/2011 12:22 PM
You mean between the cushions.
12/09/2011 12:42 AM
Hi Electroman, Where do smells go you ask. I would have to say in a closed room that they go no where, the only difference is that the receptors in your nose tend to ignore a bad odour after a period of time and you don't smell them any more. A bit like when you are on the toilet, generally it doesn't smell as bad as the remnants from the previous person.
I used to work at a pig farm occasionally, the smell always bothered me on each visit for the first 2-3 minutes then the smell probably got into my clothes, then I couldn't smell it any more, but when I got home some times my wife would be dry reaching due to the smell attached to me and my clothes.
Now then if you treat the odour with certain chemicals you can change it molecular state and this way you can get away from the smell.
Best Regards
Joe
12/09/2011 2:02 AM
You're all wrong; smells go into your nose. Doh.
--Homer Simpson
12/09/2011 2:07 AM
If your nose runs, and your feet smell, are you just built upside-down?
Lexicographer Samuel Johnson was once told, "My goodness, you smell."
He replied, "No, madam; you smell, I stink."
--Editor Crankshaft
12/09/2011 3:17 AM
"I say, I say, I say, my dog has no nose!"
"How does he smell?"
"Awful!"
12/09/2011 7:47 AM
Some people think it's funny when before they exit a crowded elevator, to leave a smell (fart) behind.
I think they call that captive audiences.
12/09/2011 7:55 AM
George Carlin's Test Fart. Release about 10% and then gauge the reaction before you let the real one go.
12/09/2011 8:35 AM
Farting in lifts/elevators is just wrong on so many levels.
12/09/2011 11:38 AM
it not wrong on many levels....it wrong on all levels.
12/09/2011 11:55 AM
Some people like their own brand
Good Answers: 19
12/09/2011 1:18 PM
Shagolishious baby!
12/09/2011 1:19 PM
oh behave!
12/09/2011 8:10 AM
Depends on if its a salad or a spicy taco you ate last night. One tends to hang on awile.
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
12/09/2011 8:37 AM
12/09/2011 11:54 AM
'Ring of Fire', I understand that song was written because of a STD.
12/12/2011 3:38 AM
So it has nothing to do with curry? Ooops!
12/09/2011 9:20 AM
"Do you mind stopping that!"
"Certainly Madam, which way did it go?"
12/09/2011 11:36 AM
Some great reasons given: You eventually accept or reject the smell when your smell receptors acknowledge its presence and a level of tolerance is aquired. Try living next to a chicken ranch, or pig farm etc., Ventilate, or inhalate or evacuate are always a solution. Now we sell odorizers. But what about the person who reeks and needs to bathe and your on a long air flight. There should be a code for public nuisance as a health threat.... I for one believe hazards odors should be rated. What do you think?
Good Answers: 130
12/09/2011 5:54 PM
"But what about the person who reeks and needs to bathe and your on a long air flight. There should be a code for public nuisance as a health threat"
There is nothing quite like 26 consecutive hours of flights and transit lounges, denied meaningful ablutions and deodorants.
I blame the terrorists.
Location: Ground Zero of the Pompous and self important....Washington DC
12/09/2011 12:32 PM
They migrate due to some yet undiscovered attraction to the bedrooms and closets of teenagers.
12/09/2011 1:03 PM
Diffusion along with our ability to become acustomed to the smell take us most of the way to the answer. Our dogs are able to detect and track odors that are too faint for humans to smell.
As to the decomposition of VOCs I suggest you talk to the folks at the University of Tennesee, Knoxville campus. Or the Decomposition Chemistry Research Group in Canada.
They have spent many years studying decomposition, odors, and insect collinization of human remains.
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
Good Answers: 19
12/09/2011 3:15 PM
up your nose with a rubber hose
12/10/2011 10:51 AM
Well it was a reasonable question I thought.... and some of your replies are reasonable....
But I do love the funny replies.
Many thanks for trying to answer my question folks!! LOL
John.
Register to Reply 45 comments
34point5 (1); Anonymous Hero (3); Anonymous Poster (2); Electroman (1); energyconversion (1); English Rose (2); Epke (1); Ethanolics Unanimous (1); Fierce Tiger (1); Graycav (1); Joe Sparky (1); JohnDG (1); Kilowatt0 (1); Lapin (1); lyn (2); ozzb (1); phoenix911 (7); pigeoneer (1); PWSlack (3); Randall (2); ronclarke (1); Smoothy (1); SolarEagle (1); Stedou73ish (2); Steve of the North (2); Stinky Pete (1); tcmtech (1); Tornado (2)
