Previous in Forum: Pre-Insulated Pipe for District Heat Distribution System   Next in Forum: Sodium Silicate Adhesive
22 comments
Carbon Graphite
02/15/2012 1:03 AM
Lets talk about carbon graphite impregnating methods which produced by powder metallurgy process;
A famous impregnating is Resin impregnation, more information by you:
Re: Carbon Graphite
02/15/2012 1:20 AM
How about immaculate impregnation?
Accidental impregnation?
Oxymoronic impregnation?
Carbonaceous impregnation?
OK, your turn!
Re: Carbon Graphite
02/15/2012 2:00 AM
Thanks for your comment, but our discussion is about powder metallurgy parts, for example Carbon bearings, Seal faces, Segmental Bush, etc.
Re: Carbon Graphite
02/15/2012 3:22 AM
Please supply something to discuss.
Re: Carbon Graphite
02/15/2012 2:02 AM
This should pretty much cover it: http://www.ingenieurparadies.de/en/ipar/18155
End of discussion (and ridiculous thread)!
Re: Carbon Graphite
02/15/2012 2:20 AM
Your mentioned website has general information, our discussion level is professional.
Re: Carbon Graphite
02/15/2012 6:13 AM
What "discussion"?
Re: Carbon Graphite
02/15/2012 7:04 AM
Procedure of impregnating carbon graphite by Resin
Re: Carbon Graphite
02/15/2012 7:12 AM
What procedure?
Re: Carbon Graphite
02/15/2012 8:00 AM
Vacuum.
Re: Carbon Graphite
02/15/2012 7:46 PM
Are you kidding?
Re: Carbon Graphite
02/15/2012 2:06 AM
Is there some kind of graphite other thn "carbon graphite"?
Re: Carbon Graphite
02/15/2012 2:16 AM
Carbon Graphite:
A mixture would be 80% carbon and 20% graphite. Graphite is a good conductor of heat, a natural lubricant, and has a laminar grain structure similar to a deck of cards, allowing the individual grains to slide over one another. It is this laminar structure that allows the graphite to release from the carbon/ graphite face and deposit on the hard face in the same manner a graphite pencil will write on a sheet of paper.
Re: Carbon Graphite
02/15/2012 4:16 AM
You have yet to state an opinion, with which we can disagree, or agree, as the case maybe, you see?
Re: Carbon Graphite
04/28/2012 1:58 AM
what do you mean by "carbon graphite"?
Re: Carbon Graphite
02/15/2012 7:14 AM
Whatever you're on, Dude, can I have a pint?
Re: Carbon Graphite
02/19/2012 6:37 PM
Come now, get with the program, they use liters
Re: Carbon Graphite
02/15/2012 8:06 AM
From my experience, impregnation is more successful when copious amounts of alcohol are used. Sometimes theobromine (http://en.wikipedia.org/wiki/Theobromine) is useful as a starter to initiate the process.
Sometimes it is preceded by the use of stroboscopic light or exposure to proteins and carbohydrates.
Re: Carbon Graphite
02/15/2012 7:37 PM
Could you supply a question please, because at the moment it appears you are just fishing for general or technical information that you can easily find with a quick internet search or search of one of the major carbon brush supplier websites.
Re: Carbon Graphite
02/18/2012 12:09 AM
If it was easy, you must find a good comments between guys, but there is not.
Re: Carbon Graphite
02/19/2012 1:01 PM
What does this mean (and it still does not answer any of our questions)?
However did you get a "Master in mechanical engineering" as your profile states when you do not have good communication skills?
Forget answering as I really don't care. I happen to know a fair amount about carbon graphite brush technology and the industry but since you cannot be bothered asking and elaborating on even a sensible question I am not going to bother trying anymore.
Re: Carbon Graphite
08/05/2015 10:26 PM
carbon graphite impregnating methods,may be here is what you want,a example like isomolded graphite process. http://www.xrdcarbon.com/materials/iso-molded_graphite/production_flow_chart/
Re: Carbon Graphite
11/14/2025 5:30 AM
Carbon graphite impregnating methods used in powder metallurgy are crucial for improving strength, density, and wear resistance of the final component. Since carbon graphite is naturally porous, impregnation helps fill the open pores and enhances performance in demanding applications like pumps, furnaces, high-temperature bearings, and mechanical seals.
Resin impregnation is indeed one of the most widely used techniques. It provides excellent anti-corrosive properties, good chemical resistance, and improved mechanical stability. It also helps reduce permeability and increases the overall life of the component.
Apart from resin, a few other common impregnation methods include:
1. Metal Impregnation
  • Copper, antimony, and bronze are commonly used.
  • Greatly improves thermal conductivity and load-bearing capacity.
  • Ideal for bushings, bearings, and wear parts.
2. Oil / Lubricant Impregnation
  • Enhances self-lubricating properties.
  • Suitable for applications where continuous lubrication is required.
3. PTFE / Polymer Impregnation
  • Improves frictional characteristics.
  • Used in sealing applications with high chemical exposure.
4. Special Chemical Impregnation
  • Used for specific industrial environments (e.g., acids, alkalis, high vacuum).
  • Helps increase resistance and reduce porosity for critical applications.
Each impregnation type is selected based on the operating environment, temperature, chemical exposure, load, and speed of the application.
If you want to explore more details about carbon graphite components and their applications, here’s a useful resource:
�� https://dmaiccarbon.net/
Register to Reply 22 comments
Anonymous Poster (1); coal1986 (1); DmaicCarbon (1); Hamid.Mahabadi (5); jack of all trades (2); JWthetech (1); lyn (2); Mikerho (1); PWSlack (3); SolarEagle (1); Tornado (2); Usbport (1); xrdcarbon (1)
