Previous in Forum: Unable to Insert Image!   Next in Forum: Heat Source for a Hobby Type of Vacuum Former
33 comments
Flight of the Phoenix
01/05/2013 2:05 PM
I'm sure most remember the Hollywood movie, "Flight of the Phoenix" where the pilot puts together a flying wing with one motor after having crashed and everyone hangs on to the top of the wing as they take off and fly to safety. It seems to me this is not possible. Although it could be put together, I doubt that it would be capable of controlled flight. Any aeronautical engineers out there who would give their opinions. I thought about submitting this to "Myth Busters", but I don't think they would want to build a flying wing.
Mr.Ron from South Ms.
Good Answers: 141
Re: Flight of the Phoenix
01/05/2013 2:26 PM
When there is a wing, it can fly if wind is working the wing. To put an engine on it with a propeller can work also. Putting everything together to make it a controlled flight needs a lot of main provisions: to name few.
-attaching the motor on the wing, connections of fuel, controls, power.
-balancing the weight, all the controls
-rudder when YOU want to decide where to fly.
The end product plane in that movie was probably a modified existing model.
But technically it can be done. The Piaggo Piggy has over dimensioned wings too and it is still used for acrobatics (built between 1940-50)
Plenty of room here
Good Answers: 918
01/05/2013 2:48 PM
The rudder does not steer the aircraft, the wings turn the aircraft. Many people also think a rudder turns a boat, but that is also not true.
The rudder keeps the aircraft yaw axis true with respect to its track.
A rudder (along with the elevator for pitch control) is an essential component of the aircraft to maintain stability.
Modern aircraft without a rudder maintain stability by virtue of computer control of the wing surface. This is simply is not possible by manual human control alone.
I haven't seen the movie, but Hollywood is notorious for not being grounded in reality.
Paul Mantz, one of the test pilots that did a short takeoff and landing of the aircraft died on the second filming attempt when the aircraft's skid hit a dune and cartwheeled.
Good Answers: 141
01/05/2013 6:32 PM
That is correct when in the air, however it turn handy to fly in a horizontal position. When I taxi, my flaps do not help a lot. Thanks.
Plenty of room here
01/05/2013 6:56 PM
"When I taxi, my flaps do not help a lot"
That's what the brakes are for.
01/05/2013 9:40 PM
Repeated you. Should have read more carefully.
Good Answers: 21
01/05/2013 11:16 PM
I have to weigh in here just a bit. Rudder is for yaw, it is also used to turn the aircraft along with the ailerons which are mounted on the wings. Using each of these produces a coordinated turn. One with out the other produces adverse yaw. The wright flier is a good example of this as they used wing warping and the effect was a reverse truing motion before the turn began in the direction intended.
Making an aircraft and making it a safe aircraft is not an easy task. I have built several and have flown several hundred different makes all having something just a bit different in the way they handle. But, if you put enough power on it, any thing can fly, even a rock. Look at some of the things that came out of the 50's and 60's that killed many a good test pilots.
My 2 Cents
Fixitorelse
01/05/2013 6:21 PM
Well you have me curious now.
What does turn the boat when I move the rudder?
Good Answers: 141
01/05/2013 6:45 PM
Hi TCMTECH,
Is this a question for me? A rudder is a steering device I think. Most boats have one or more. A sail boat can be trimmed with the sails only and a motor boat with more engines by the RPM's of each engine. (the latter can even steer pretty good this way)
I think AH brought this up.
Plenty of room here
Good Answers: 918
01/05/2013 8:07 PM
The hull.
01/05/2013 8:15 PM
So what turns the hull? The rudder.
Good Answers: 918
01/06/2013 8:42 AM
Correct. But if you follow your logic, isn't it the person holding the wheel or tiller?
The rudder simply changes the boat's orientation relative to its yaw axis. The hull is responsible for the actual turn.
Good Answers: 141
01/06/2013 8:58 PM
Hi AH, in my #1 post 1 spoke of a rudimentary concept: 1 wing with an engine on it. I wasn't even flying yet. You've got me good, also with the boat with detachable hull and the person. To me the direction of my boat is determined by a destination, mostly planned by my wife. She uses all weapons available to make me agree and then, once on the ocean, my ample brain signals my hands and arms to turn the steering wheel so that the boat goes (sorry) floats there. When I switch on the auto pilot no person is holding the wheel. Just joking. Happy 2013
Plenty of room here
Good Answers: 918
01/07/2013 6:50 AM
"To me the direction of my boat is determined by a destination, mostly planned by my wife."
Now that was a good one! :)
01/07/2013 3:17 PM
I have to vote with A H on this one, as most turns in flying do not actually require much if any rudder input, since strictly aileron turns are done by banking, and using lift. Coordinated turns require some rudder, but the turn wastes a whole lot of the plane's energy (speed) while executing such a turn.
"Most modern aircraft" I can assume only to mean something that at first glance doesn't look like it "should" fly. Examples: wings without fuelage, door stops (F-111A), and on the list goes. Not every "modern" airplane has to be flown by computer, just the ones that rely on new technology.
Good Answers: 918
01/07/2013 3:59 PM
The "coordinated turn" uses the least energy and presents the least drag.
As a sailplane pilot we are taught to watch the "yaw string" on the canopy to guide our rudder input. Drag is something that sailplane pilots take very seriously since increased drag adversely impacts the glide ratio and you also rely heavily on turns when using most thermals to gain altitude.
01/07/2013 4:59 PM
And coordinated, or "two minute" turns don't allow rapid direction changes. They do make your fligh instructor happy though.
Rapid changes are made by pointing the top of the plane in the direction you want to go and hauling back on the stick.
01/07/2013 5:13 PM
At least we agree on something: turns require energy, thus slowing the plane, or causing a reduction in altitude. For your exception, you are using a turn to hold a pattern in a thermal to gain altitude.
Something I have never quite learned is how to not "oversteer" a turn by applying too much rudder.
Good Answers: 918
01/07/2013 5:23 PM
Again, the rudder just puts the pane's yaw axis in line with the air is moving over the aircraft.
The amount of turn is a product of bank angle and how much the stick is pulled back.
01/05/2013 8:13 PM
With an airplane, it's the wings.
01/05/2013 3:53 PM
Well,in the movie, the designer of the phoenix, was an engineer........ Of models. She he did calculations. Wether it can be done, well, I do not know if it could be done with the engineers coming out of college today. Because, if you take away their software ....... And just give them, a handheld calculator in Lu of a slide rule, it would be a stretch. In reality............... No comment. But one can be surprise what ones ability is when your back is against the wall.
01/05/2013 3:56 PM
It's highly improbable that this type of construction could be done in the field, it took a team of experts using various aircraft for parts 5 mos to construct the plane, this working under ideal conditions....Here is a link to some info....
"Type: Tallmantz P-1 Phoenix
msn: 1Civil reg. / Owner: N93082 / Tallmantz Aviation Inc.Film role: First flying Phoenix aircraft (take-off scenes).
Remarks: Of all the aircraft in this film, the actual scratch-built flying Phoenix is the most famous and not always for good reason. It was deigned and built inside
five months for the movie by Otto Timm with construction by Tallmantz Aviation Inc. of Orange County, California. Tallmantz was the main aeronautical company
contracted to the motion picture by 20th Century Fox to not only built the Phoenix but provide logistics for Aerial Unit filming on location. The P-1 Phoenix was
completed on 14 June, 1965 with the first flight recorded on 29 June by legendary Hollywood stunt pilot (and Tallmantz co-owner), Paul Mantz. The engine, engine
cowling, cockpit section, wheels and other parts were from a T-6G Texan. The outer wings came from a C-45 Expeditor and tail wheel from an L-17 Navion. Tallmantz
scratch built the inner wings, fuselage, tail section and skids. The fuselage was a tubular steel framework with wooden bracing and plywood coverings. Some shots
were filmed in Buttercup Valley on 7 July, 1965. Then, the next day on 8 July, while approaching on a fourth run past the cameras, the skids struck the ground breaking
the fuselage off behind the wing, this caused the entire forward fuselage section to nose over into the ground killing Paul Mantz (62), and injuring stuntman Bobby
Rose. Mantz was flown back to California, his funeral was held on 12 July, 1965, attended by many Hollywood celebrities.
Photo (right): James H. Farmer."
Good Answers: 141
01/05/2013 6:50 PM
Thank you. GA. Good research or are you in the picture?
Plenty of room here
01/05/2013 10:21 PM
No, a fan of the movie though, I thought it was a great story....
01/06/2013 11:29 AM
Thanks for the research on the topic. I never saw the latest version of the film and the memory of the original version is a bit foggy, so I don't recall what it really looked like. I'm sure if an aeronautical company built the model, they could make it fly, but I doubt if a model airplane maker could build something that would really work out in the desert and with whatever tools were available. Sounds pretty far fetched to me.
01/05/2013 4:16 PM
There were 2 versions of the story made. I saw the 1965 version with Jimmy Stewart, many years ago. It was very good. It was implausible, but not outrageously so. As I recall the rebuilt plane had a more-or-less conventional planform. This movie was dedicated to the stunt pilot who crashed in the plane during the final stages of filming.
I never saw the 2004 remake.
01/05/2013 9:38 PM
the engineer was really a toy maker! silly story
01/06/2013 12:56 AM
Attach a heavy duty air bag to the bottom of the aircraft.
pnaban
01/06/2013 5:35 AM
Only using Hollywood science. For controlled flight, you need a horizontal stabilizer and elevators to control the wing's angle of attack and the balance of an airplane is critical. The center of gravity must be slightly ahead of the center of lift. It is extremely unlikely that you could build anything flyable from parts left over from a crash, but it makes good escape fiction if you can suspend belief long enough.
01/06/2013 6:41 AM
Of course its possible, they actually filmed it twice using two different aircraft!!!!
01/06/2013 11:15 AM
This movie is FAR MORE BELIEVABLE than the junk you see at the movies today. There's at least some plausibility in the plot.
Could the stranded crew have performed this metamorphosis with the equipment on hand? No way.
01/06/2013 2:08 PM
I will grant that it would be difficult to do in the desert. For example, how would one splice and terminate control cables? Would one have appropriate tools and bolts to make wing attachment fittings? However, it would not need an engineering degree to design and make do. Any member of the EAA, Experimental Aircraft Association, can point to dozens of flyable aircraft (and a few duds) built by people with no formal engineering training. Until the FAA put in the 51% rule (51% must be "home built"), many folks would take the wings from one aircraft and parts from others to assemble a "new" design. Building models is a good way to understand weight and balance, stability, and such. The Phoenix builders didn't need stress analysis, etc., because they were using factory parts and had little choice. Presumably, parts from a transport would be overly robust for a "light" aircraft with little payload. Consider, if you will, the world of ultralights, thousands flying, with almost all designed and built by amateurs, especially in the pioneering years. The Wright brothers were self-taught. Even as late as WW-1, with Focker, Bleriot, Sopwith, et al, there were no formally trained aeronautical engineers, as no such courses existed.
01/06/2013 8:29 PM
I DON"T know aircraft engineeerting, but the one thing that makes the story plausible was that they were carrying a load of steel shapes and fasteners for an oil rig. Not saying it's really doable but----
Robert A. Heinlein (1907-1988) "There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
01/08/2013 10:01 PM
It's a MOVIE (called cinematic license)...and, in my best Bugs Bunny voice, "...th-h-hat's entertainment!"
Register to Reply 33 comments
70AARCuda (1); Andy Germany (1); Anonymous Hero (6); Anonymous Poster (1); bluebelly (1); dvmdsc (5); esbuck (1); fixitorelse (1); Fredski (1); James Stewart (2); lyn (5); phoenix911 (1); pnaban (1); Rixter (1); ronseto (1); SolarEagle (2); tcmtech (1); Usbport (1)
