Previous in Forum: Sodium Silicate for Crystal Garden   Next in Forum: Troubleshooting a Steel Rolling Mill
9 comments
How to Remove PTFE Coating from Inside the Pipe?
08/01/2013 6:45 AM
SS316L Pipe size is DN15 coating with PTFE and its jacketed pipe.
inside 0.8mm coating by black PTFE that i wantto remove.
Can anybody help in this,
Good Answers: 50
Re: How to remove PTFE coating from inside the pipe?
08/01/2013 7:07 AM
If the pipe is short enough, run a 15mm to 17mm drill through it depending on wall thickness of pipe. Best would be to do this on a metal turning lathe.
ignator -
08/01/2013 7:11 AM
Wall is 1.5 mm and basically it is jackted pipe heat exchanger.
And work in starile application. we can not do machine on it.
Is there any other method?
08/01/2013 7:43 AM
Why didn't you include this information in the first place? What have you already tried? What other important information have you left out?
08/01/2013 7:52 AM
Nothing is left now.
Plz help on it if is there any process to remove the coating.
Re: How to Remove PTFE Coating from Inside the Pipe?
08/01/2013 9:51 AM
Buy the correct pipe for the application.
08/01/2013 7:40 PM
Duplicate thread.
Good Answers: 203
08/04/2013 11:07 PM
Ask the manufacture first. They may have had this question already. Also, they probably have more of an idea as to what you want to do than an open forum. How smart do you think us darn idiots are?
Specific questions = Specific answers
Good Luck, Old Salt
08/06/2013 7:52 AM
Duplicate thread.
Reported.
It's amazing that some users won't take the best way out, and will tiddle about on CR4 posting duplicate threads instead of getting on with the job. Whatever is the world coming to <mutter, mutter>?
08/06/2013 7:58 AM
If you have solution then tell...
Register to Reply 9 comments
Anonymous Poster (1); ignator (1); lyn (1); old salt (1); PWSlack (1); Tornado (1); viral30786 (3)
