Previous in Forum: Air for Fuel   Next in Forum: Zinc Phosphate Coating On Wire Rod
14 comments
Diesel Fuel Combustion
08/11/2013 4:32 AM
C7H13 + 10O2 + 39N2 = x1 CO2 + x2 H2O + x3 N2 + x4 O2 + x5 CO + x6 NOx + x7 CxHy please help me to balance this equation
Re: diesel fuel combustion
08/11/2013 4:53 AM
I don't think there's enough information for a unique solution. And you forgot the argon (as well as the CO2 on the left side, and also how to use subscripts.)
08/11/2013 7:32 AM
For instance, the solution I like best is:
x1 = x2 = x4 = x5 = x6 = 0
x3 = 39; x4 = 10; x7 = 1
CxHy = C7H13.
08/11/2013 7:59 AM
I prefer CH3CH2OH, usually with a splash of soda water.
Good Answers: 61
08/11/2013 6:17 AM
There are 3 hydrocarbons (isomers) with the formula C7H13 - none of which could be regarded as being present in diesel fuel, although there may always be the minutest of quantities present. I don't know where you got this formula from. Diesel is normally regarded as a mixture of hydrocarbons from C8 to C21 - possibly you have been given C14H26 as the "average composition" which has been turned into the empirical formula of C7H13, although I see no point in doing that.
As for balancing the equation - that's your homework. You will only learn by doing it yourself!
08/11/2013 7:56 AM
C8H18 + 12.5O2 + 47N2 = x1 CO2 + x2 H2O + x3 N2
another dissociation formula is
2CO + O2 = 2CO2
NOW what do u say
08/11/2013 10:29 AM
It is trivially easy to generalize from a previous example.
08/12/2013 3:14 AM
The stoichiometry class is just down the corridor, third door on the right. Yes, that's it. Have a splendid day.
Re: Diesel Fuel Combustion
08/11/2013 12:48 PM
I believe that's gasoline....
C7H13 +10:25O2 +38:54N2 ! 7CO2 +6:5H2O+38:54N2
Hobbies - CNC - New Member
08/11/2013 10:46 PM
The answer is soooo simple!!! All that gibberish = 3. What was so hard about that???????????
08/12/2013 12:20 AM
equation is wrong check the number of nitrogen mollecules and repost, cheers
08/12/2013 5:40 AM
Nitrogen oxides are a very minor part of what is going on, so they can be ignored with very little effect. Once that is done, assume complete combustion and make the numbers of atoms each side balance-up. It's only simple arithmetic.
How has C7H13 arrived? Hydrocarbons do not usually form with odd numbers of hydrogen atoms. C7H8 would be toluene, for example. C7H14 is a heptene, and C7H16 is a heptane.
08/12/2013 9:06 PM
C14H26 is not equal to 2(c7h26)
08/12/2013 9:29 PM
Complete or stoichiometric combustion for a diesel engine is where I would start the equation.
The theoretical air to diesel fuel mix is, 14.5 kg of air to 1kg of fuel, however this can vary with diesel engines that can provide excess air to 150% or more to ensure complete combustion. The diesel fuel type or quality can also change this ratio.
eg for perfect stoichiometric mix, C3 H8 +o2 = Co2 + H2o
The N2 is not taken in to count as it doesn't change in the heating inside the engine.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
08/12/2013 10:16 PM
If this is homework, read #14 in the FAQs.
Speak softly and carry a big stick.
Register to Reply 14 comments
austyns1 (1); Davesets (1); energyconversion (1); gib (1); happy348 (1); Original_Macgyver (1); PWSlack (2); SolarEagle (1); standarded (1); Tornado (3); Usbport (1)
