Previous in Forum: Analog VS Digital Signal   Next in Forum: Calibration Question
12 comments
Difference of PZT and PT Transmitters
08/20/2013 2:30 AM
i came across the PZT and PT instruments,please explain the difference of these two instruments
Re: Difference of PZT and PT transmitters
08/20/2013 3:03 AM
Please explain the context in which these two different transmitters were found.
08/20/2013 3:34 AM
In a manual from which someone removed the glossary?
08/20/2013 4:10 AM
Very good. Take a Team Point.
08/20/2013 4:21 AM
Normally
PZT stands for Piezoelectric Transducer
whereas
PT stands for Pressure Transmitter
As PWSLACK says we need a little more context.
08/20/2013 5:11 AM
One has a "z" in it, one does not.
Use a search engine. "SE"
08/20/2013 6:42 AM
Are you in charge of Marketing?
Re: Difference of PZT and PT Transmitters
08/21/2013 2:09 AM
For my experiences,PT is used for PCS (process control system) and PZT is used for SDS(Shutdown system) function.am i correct?
Rgs,
khoi
08/21/2013 3:28 AM
With the current level of input from the Original Poster, it is not possible to tell.
08/21/2013 8:21 AM
Hai Khoi
Thanks for your reply
Yes you are Correct ,in my current project PT was wireless type connected to PCS and PZT was hardwired to ESD system.
Please advice me why not PT was hardwired and PZT was wireless,is there any merits or demerits in selecting the instruments type.
Good Answers: 116
08/31/2021 7:10 AM
Whatever the details of type of PT or PZT, a "wireless" radio, optic, or acoustic coupling would be less reliable than a direct wire [maybe pneumatic] connection.
For an ESD system greater reliability would be mandatory.
There is also the desirability of different technology for ESD or back-up equipment/cross-checks.
For example, a 4-20 mA pressure transducer might be used for control with a direct wired steel diaphragm "microswitch" pressure switch for emergency shutdown ESD.
As another, a triplicated, voting shutdown system with radio connection could have all its 3 elements disabled by strong radio interference from an electrical fault.
I believe some airliners have crashed because all three of the airspeed transducers used identical pitot tubes [with inadequate heaters for conditions] which all blocked with ice simultaneously, giving equal, but high readings. Backup "truth" checks, engine speed versus altitude comes to mind, were not automatically alarmed or understood by crew leading to low airspeed and fatal stall.
08/28/2021 9:28 PM
PT - Pressure Transmitter
PZT - Pressure Transmitter(Safety, ESD, PSD)
ESD - Emergency Shut Down
PSD - Process Shut Down
11/15/2021 12:56 AM
PZT is SIL rated transmitter , which shall be connected to plant safety system, whereas PT shall be connected to Process control system, SIL certification is not required
67model (1); Anonymous Poster (1); Fegor (1); javeriaengg (1); khoimngo (1); lyn (1); PWSlack (3); Randall (1); Tornado (1); Usbport (1)
