Previous in Forum: Electrical Wiring Help   Next in Forum: Buck Converters in Series
11 comments
IR Sensor with Buzzer
09/13/2013 11:13 PM
Hello,
I do not have much electronics idea. (but) I want to build an IR sensor with a buzzer. I browsed the net and found these two products which match my needs.
need/requirement: buzzer should sound if distance to object is less than 20cm. 103db level sound should be ok.
products i found:
1. sharp distance sensor: http://www.phidgets.com/products.php?category=2&product_id=3520_0
2. 3-28VDC PIEZO BEEPER: http://www.allelectronics.com/make-a-store/item/ES-10/XL-MINI-PIEZO-SIREN/1.html
I am not sure how to put it together. can anyone advice please? any step by step guide available?
thank you.
Rajeev
Pathfinder Tags: buzzer IR sensor
Re: IR sensor with buzzer
09/14/2013 12:18 AM
You need a micro-controller like an Arduino to program the signal to buzzer....You could just hack a garage parking sensor seems cheaper/easier...
09/14/2013 2:55 AM
Then start with a battery, some switches and a buzzer!
As you learn more you can do more, but to jump in with overcomplicated stuff which you don't understand will be a frustrating waste of time and money.
Trust me, it's just taken me several weeks of extreme frustration and anxiety to get working with a new microcontroller, despite 40 years in the business.Del
09/14/2013 4:21 AM
That's one of those things where 40 days in the business is easier than 40 years.
09/14/2013 11:15 AM
Good Answers: 804
Re: IR Sensor with Buzzer
09/14/2013 3:14 PM
You don't need all that complexity.
Just get a proximity sensor that has a manually adjustable distance and a Normally Closed output, one that runs of 12VDC would be easy to find and will easily match to a 12VDC buzzer. Wire goes from 12VDC battery + terminal, to sensor + terminal, out of sensor switch to buzzer + terminal, out of buzzer - terminal back to battery - terminal. Some sensors may need the battery - wire run as well to power it.
09/15/2013 6:22 AM
What's all this talk of microprocessors?
Keep it simple - as JReaf said (I think) All you need is a ready made sensor with adjustable limits and a buzzer, plus a power supply of course!!
Most of us on here remember the 'old days' when a transistor was new fangled compared to the good old vacuum tubes (valves). Now a days you buy the completed sensor and buzzer and set it up to do what you want.
Simples!
09/15/2013 10:33 AM
Long time no see Electroman, good to see you
09/15/2013 11:35 AM
Oh I've been around, lurking in the background
Most of the posts have comments on by the time I see them though LOL
09/15/2013 10:16 AM
I agree with some of the comments. I can buy a battery operated infrared light for £5 then simply swap the light for a buzzer, job done. If it needs more power replace the light with a reed relay and 470 ohm resistor to switch on something heavier. I hacked one of these to operate a camera. Easy
Peter Jensen
Good Answers: 32
09/21/2013 11:19 PM
The very first thing you need to understand that there is this background light.
AC modulated transmission and demodulated receiver removes this DC or slow varying light background.
There are many TV IR receiver in the range of 40kHz modulated frequency. Transmitters are simply LED driver with gated oscillator.
You need reasonably high focused light output so narrow angle LED and photo-transistor with lens is ideal.
you can transmit logic level 1 / 0 signals so activating alarm is very simple like YES and NO.
Microcontroller is not required for activating alarm but if you use one then perhaps you can use its timer to set alarm for desired time duration and with memory to record information or transmit serially or take multiple sequential actions.
09/22/2013 5:48 AM
On our landing we have an IR lamp that comes on if you get up in the night for a wazz.
It makes a nice click so there is obviously a relay in there.
They are cheap as heck.
But one of those and shield/baffle the detector to give the range and angle of sensitivity you require. Replace the lamp with a mains buzzer/lamp/anything you like.
Cheap simple...
Or just by the sensor Like this one which has an output to drive a mains load.
Register to Reply 11 comments
Electroman (2); JRaef (1); lyn (1); Pj3ns3n (1); Shyam (1); SolarEagle (1); Tornado (1); user-deleted-1105 (3)
