Previous in Forum: Autism & Help.   Next in Forum: GPS Problem
15 comments
Cleaning Grease
10/23/2013 3:01 PM
Is TSP the best product to use for cleaning kitchen grease from polyureathane finished cabinets?
Thanks,
Don
The only people who don't make mistakes are those who don't try.
Re: Cleaning Grease
10/23/2013 3:27 PM
TSP
Greased Lightning
Murphy's Oil Soap
All will work, I like the citrus based degreaser though....
http://www.homedepot.com/p/Maintex-1-gal-Citrus-Based-All-Purpose-Degreaser-162604HD/203086210#.UmgiSvmsiSo
Re: Cleaning Grease
10/23/2013 5:42 PM
I think a wife works better
Re: Cleaning Grease
10/23/2013 6:32 PM
OMG. Somebody hi-jacked your avatar and put up a Halloween mask in its place.
Good Answers: 92
Re: Cleaning Grease
10/23/2013 9:52 PM
I'd say no, but then I make cleaners...
You are better off using a formulated product. TSP (or any other alkaline phosphate) contribute a number of benefits to cleaners but don't possess the inherent wetting power etc. of the surfactant and builder package of a cleaner. It's good, but not the best.
Good Answers: 203
Re: Cleaning Grease
10/23/2013 11:58 PM
Don in LA-
Far better than TSP is Sodium Meta-Silicate. Cleans more, cleans better, less caustic, less damage to materials that have the grease to be removed on them. It also does much less environmental damage. Another benefit to its use is that it requires less scrubbing to get the grease off.
http://www.pqcorp.com/Portals/1/docs/Metso%20Sodium%20Metasilicate,%202009.pdf
It is often used as a non-solvent floor cleaner for truck, bus, large equipment and automotive repair and storage garages.
Good Luck, Old Salt
Good Answers: 92
Re: Cleaning Grease
10/24/2013 12:11 AM
Hate to say it, but Metso is actually more caustic (alkaline) than TSP.
Agreed it's a better choice but probably less available to consumers, and if you are making up a solution yourself be sure not to let it dry on any glass or high gloss ceramics. The silicate can precipitate and bind permanently to these as a micro layer that will cause a rainbow hazing effect.
Re: Cleaning Grease
10/24/2013 12:44 AM
Is this "kitchen grease" a new spill, or grease that has been vaporized and deposited on cool cabinet surfaces?
Makes a difference how you remove it.
TSP is probably not the way to go.
If really hot water and a cloth won't do it, try more hot water.
Then a solvent that won't strip PU coatings is called for. Start with IPA.
Re: Cleaning Grease
10/24/2013 3:14 AM
<...Start with IPA...>
What a waste.
Re: Cleaning Grease
10/24/2013 3:37 AM
A big mistake often made is using solvents etc without any medium to then soak up the disolved grease. If you are not careful you can end up merely spreading it around.
Re: Cleaning Grease
10/24/2013 7:56 AM
Frankly I think the standard multi-surface spray detergent cleaners are the best for this job - cleaners such as 'Fantastic'. That's what I use on my maple wood kitchen cabinet doors that have a urethane finish. I use microfiber cloths and rinse them often in hot water.
Use a good pair of rubber or vinyl gloves 'cause that stuff will make your hands really sore after a while.
Re: Cleaning Grease
10/24/2013 1:55 PM
Wow! A lot of good food for thought. The grease is just vaporized cooking grease that has condensed on the wood cabinets. I do have an exhaust-to-outside exhaust fan but this has built up over a couple of years and my wife usually forgets to turn on the fan. I did clean a couple of doors and cabinet faces with Formula 409 but it required some scrubbing and I think I was getting into the poly finish. Thanks guys.
Don
Re: Cleaning Grease
10/24/2013 2:25 PM
Del told me to tell you that you just need to get a new wife.
Re: Cleaning Grease
10/24/2013 2:33 PM
I might do that if I could trade for a new pickup truck.
Don
Re: Cleaning Grease
10/24/2013 4:31 PM
I don't know. New wives are a lot harder to break in than new pickup trucks.
Re: Cleaning Grease
10/24/2013 6:03 PM
If it's a really sticky build-up of grease, spray it with Goo-Gone first. It will emulsify the build up. It's based on citrus oil and is almost like a furniture polish.
Register to Reply 15 comments
Don in LA (2); Fredski (1); JNB (2); lyn (4); old salt (1); PWSlack (1); SolarEagle (1); Usbport (2); user-deleted-1105 (1)
