Previous in Forum: How Electrical Insulation Fails and Causes Fire in a New House?   Next in Forum: HT and FO Cable Crossing
41 comments
Gold Plated Aluminum Wiring
01/12/2014 7:51 PM
Has anybody ever heard of gold plated aluminum wiring used in a generator..?
Re: Gold Plated Aluminum Wiring
01/12/2014 8:05 PM
does it go out into space? why would you do that?
01/12/2014 9:10 PM
Well it seems the aluminum wire is more malleable than copper and therefore more efficient at producing current flow....what holds it back from being used over copper is the tendency to oxidize on the surface it seems to me, but coated with gold or perhaps copper would yield a more efficient generator....thoughts?....now copper coated aluminum wire is nothing new, but I have never seen, to my knowledge, it used in the windings of a generator....?....or am I completely mistaken?
01/12/2014 9:29 PM
I see no advantage at all.
Maybe at mega or gigahertz.
01/12/2014 9:40 PM
Ask any expeiranced scrap yard owner or worker. Copper clad aluminum in transformers and large electric motors is a real money losing hassle if they don't catch it when it comes in.
I have several Miller and Lincoln Electric welder power supplies that were built in the late 70's to mid 80's that are all copper clad aluminum. They are worthless for scrap.
A friend of mine has a large scrap yard and he has semi loads of welder power supplies transformers and some large electric motors that are copper clad aluminum wound. They are not worth the time or money to scrap them. The ROI is less than what they would get on the material once it was processed.
01/14/2014 6:57 AM
As copper and aluminum have different melting points. You heat to the lowest melting point. Then pour off this metal. Then raise the temperature and pour off product.
Depending on what your doing you may have more product.
01/14/2014 6:52 PM
Unfortunately what that creates is chunky aluminum soup with copper bits in it.
When scrapping out old equipment the whole point is to make a profit on it.
Processing copper clad aluminum by melting the aluminum out is rarely cost effective even if you got the stuff for free. The end products don't separate and clean up well enough to get any decent price for it.
01/16/2014 10:06 PM
Aluminum forms a binary eutectic alloy with copper at 1/3 Cu 2/3 Al. This alloy has a melting temperature far below that of pure aluminum...... point being, melting is not an effective way to separate.
Good Answers: 150
01/14/2014 7:00 AM
Sounds like a theft prevention device to make them not worth stealing....
Who is John Galt?
01/14/2014 7:15 PM
Oh thanks a lot, Rorschach. Now I've got to wipe coffee off my screen.
GA.
Good Answers: 150
01/15/2014 7:39 AM
Oh, I'm sure it has other benefits as well, copper clad Aluminum would be solderable and would also help to prevent galvanic corrosion at connection points with copper. And at high frequency, the additional conductivity of copper through the skin effect would be of benefit while the thermal conductivity of Aluminum would help with heating. I'm not saying it is the ONLY reason they did it, just a nice side benefit.
Who is John Galt?
01/12/2014 10:01 PM
I think Lincoln Electric makes (or made) aluminum-wound motors. Copper is a better conductor, but aluminum is cheaper and lighter, with the problem of oxidation.
01/13/2014 10:06 AM
http://metaldetectingworld.com/conductive_order_metals.shtml I still don't get it. I know AL sucks as wiring, not because it can't carry current or is resistive but its expansion and contraction rates leads to loose connections and contributes to the thread on house fires from poor wiring
Good Answers: 444
01/12/2014 8:25 PM
Seems counterintuitive (and expensive), maybe it's gold anodized surface treated to look like gold.
01/12/2014 8:56 PM
Jewelry making, maybe.
01/12/2014 9:09 PM
Copper clad aluminum wire being passed off as real copper wire has been common for decades so I can see where passing off gold clad aluminum wire could make it to the market.
Good Answers: 146
01/13/2014 10:37 AM
um... gold is sold by weight and is heavy, while aluminum is really light, the difference would be immediately obvious.
incus opella
01/13/2014 12:48 PM
Yes once it's out of the device it's obvious just like comparing copper clad aluminum to real copper wire.
The problem is when to the naked eye the aluminum wire looks just like copper wire. You pay good money for a motor or transformer that looks like it has 300 - 400 pounds of good copper and you pay a guy $1000 for it but when you go to process it all you have is 50 - 70 pounds of useless junk metal worth less than $100 including the iron core and you just spent $200 processing it.
Imagine electronics scrap processors doing a similar thing. They pay some guy $1000 for what the think is circuitry with a few $1000 worth of gold in it only to find out when the process it they have about $50 worth of gold and 1 cents worth of aluminum that just took them $200 in labor and processing costs to find out.
Good Answers: 117
01/13/2014 11:17 PM
no
01/14/2014 12:50 AM
Solar Eagle, did you see this somewhere or did someone mention this in a discussion?
As others here have said, there's copper-clad aluminium wire, and one mentioned that it may be gold-anodised, but, electrically, gold-plated aluminium wire in a generator doesn't make a lot of sense. Gold is worse than both copper and aluminium in terms of electrical conductivity, with silver being best. You'd still have to insulate the windings from each other and anodisation is not a reliable insulator (esp. when nicked or scratched - easily done during the winding process).
I know this sounds flippant (and forgive me, please), but it sounds like a bluddy Government (G) Job! :))
01/14/2014 9:20 AM
No I haven't seen it anyplace, but heard a lot of discussion about the winding's in welders being aluminum, and discussion about the differences.....it certainly would be cheaper and lighter, and I was thinking in the automotive industry, what with all the hybridization and electric drive systems, that any weight saving strategy would be worth considering....Now the plating can be quite thin, and gold doesn't tarnish like other metals,,,,so gold plated aluminum winding's might make sense....It is used in audio....but then also the property of generating current supposedly is enhanced with higher malleability, so I was also wondering if using aluminum winding's vs copper in a generator might be plausible...
http://www.hobartwelders.com/weldtalk/archive/index.php/t-21318.html
01/14/2014 9:26 AM
"It is used in audio", mostly for the bling factor.
Only the most sensitive instruments can tell if there is any difference. That does not include human ears.
01/14/2014 9:42 AM
Well I used the gold plating of audio components as an example that it is not unheard of....and I think the idea is longevity of integrity, a clean connection is a good connection, and a metal that doesn't corrode, makes for a good reliable long-lived connection....If wheel motors could be made lighter, it would reduce the unsprung weight associated with this cool tech....although I think I did suggest a workaround....In any case, weight reduction in tomorrows electric-hybrid vehicles is an ongoing push...2015 the year of the aluminum Ford F-150....booyaaah
http://www.usatoday.com/story/money/cars/2014/01/13/redesigned-2015-ford-f-series-pickup-f-150-aluminum/4421041/
01/14/2014 2:39 PM
That pickup is truly UGLY! Reminds me of the 1958 Edsel.
Forget saving 700# in GVW, that front end must add tons of drag at highway speeds.
01/14/2014 4:38 PM
LOL ...What was he thinkin'..?
01/16/2014 4:22 PM
American Motors' Pacer and Gremlin were truly The Ugliest Cars Known to Man. Their performance matched their dubious aesthetics.
I was loaned a Pacer when my Toyota was in the shop. Driving the Pacer was a truly unique experience: like driving an inverted, windowed bathtub-on-wheels. The suspension felt like rolling on a waterbed. Ten seconds after changing lanes and the car was still swaying. Unbelievable. Like being on a top-heavy ship with no keel.
Good Answers: 32
03/08/2015 12:28 AM
Ears may have Tintin noise.
Good Answers: 32
11/11/2015 11:27 PM
Perhaps Gold capacitors may be using Gold over Aluminum / Mylar.
Good Answers: 40
01/14/2014 1:16 PM
Hmmm... (a bit 'taken-aback', by such a post...)
"...thinking in the automotive industry...that any weight saving strategy would be worth considering....plating can be quite thin, and gold doesn't tarnish like other metals...so gold plated aluminum winding's might make sense....(thus) wondering if using aluminum winding's vs copper in a generator might be plausible"
Once-upon-a-life-ago, I had opportunity to work on literally thousands of different electrical apparatus (primarily motors and generators). Never back then, nor with current occasional exposures, have I seen what you're inquiring about.
I believe the "full / appropriate" answer must cover several points.
1st - How large (or small) of a unit might this be considered for use in? Would the weight-saving ACTUALLY offset the (other) "disadvantages"...? Every such material substitution has its trade-offs.
2nd - "True", gold does not tarnish and (bare) aluminum does. However, the aluminum wire used in wound rotors, stators, etc is coated with awfully tough, high-temp resistant insulation that prevents it from oxidizing on its surface. And ("duh", lest SOME readers need to be reminded), even the gold plated wire would require such a coating.
3rd+ ... Those 'trade-offs' mentioned above go NOT ONLY for the choice of wire, in the specific case of your OP... but for the iron and insulations as well. Just as grain-oriented silicon steels (laminated thinly), afford best performance from the standpoint of minimizing losses while affording maximum ß (flux density), lesser quality iron can get the job done for less cost ... with its corresponding trade-offs.
And so, as with SO MANY other such questions, you know as well as any of us that "sure, it CAN be done". But, at what *extraordinary* cost, and to what gain?
Hasn't gold about peaked, lately, on the markets? Personally, I am convinced that any monies invested towards such applications as you might have in-mind would be BETTER FOCUSED on the other areas of design. Just my 2-cents-worth.
Hobbies - CNC - New Member
01/14/2014 2:28 AM
Gold and aluminum form a diffusion alloy which is quite resistive. Semiconductor manufacturers chasing failures in integrated circuits found ball bonds onto aluminum developed a "purple plague" around the bond, creating failure. A jeweler friend told me that the stuff is very brittle.
Not the best generator windings.
01/14/2014 2:36 AM
No, but there is insulation used on aluminium which is gold in colour.
01/14/2014 5:56 AM
It is not common to gold plate directly onto aluminum. Usually it requires a layer of copper or nickel before the gold. This makes little sense from an conductivity stand point in a generator but perhaps in a very corrosive environment this might be feasible. However there are many other metallic components in a generator that would need corrosion protection and if the device in question does not address these concerns then the corrosion protection idea is out. But to actually answer your question, no I have not seen gold plated aluminum wire used in a generator or any where else for that matter.
My shoes are too tight, but it doesn't matter because I have forgotten how to dance.
01/14/2014 11:29 AM
Yes I would think a primary coat of copper before gold....or possibly silver then gold...
http://www.aeroelectric.com/articles/AlumWire/AlumWire.html
Good Answers: 150
01/14/2014 7:04 AM
Given the thermal expansion coefficient difference between Aluminum and gold and the fact that they form a brittle high resistance alloy at the diffusion bond, I really can't see any benefit of doing this. I suspect it is Lacquered Aluminum
Who is John Galt?
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
01/14/2014 7:07 AM
Would the military use it in mobile/battlefield electronics for the weight savings over copper-clad aluminum or straight copper wiring?
Dirt is for vegetables. Pavement is for racing.
01/14/2014 7:44 AM
Most likely 'anodizing' which puts a ceramic like finish on aluminum. For better conduction properties at high frequency, silver plated copper is used. At higher frequencies electron flow tends to move to the surface, and silver is a better conductor. The only non-military use of gold plating I'm aware of was by Hewlett Packard back in the '70's, they used to use heavy gold plating on the entire boards rather than just on the 'fingers' Most older HP devices are scrapped as a result.
01/14/2014 9:06 AM
Dear Mr. SolarEagle.
Not Heard. It appears to be an Imagination.
If at all CONDUCTIVITY is considered as the CRITERION, the SILVER is the Best Choice for coating, as it has the HIGHEST CONDUCTIVITY. Cost wise, certanily GOLD is highly expensive, than Silver.
DHAYANANDHAN.S
01/14/2014 9:22 AM
Dear Mr.SolarEagle.
Pl. refer my posting No.22 above. I forgot to mention, that as for as CONDUCTIVITY is concerned, GOLD is ranking 3rd, next to Copper, which is No.2 in CONDUCTIVITY. First and highest conductivity is possessed by SILVER.
This is also indicated by Mr.Fredski, in his Posting No.9 above.
DHAYANANDHAN.S
Good Answers: 804
01/15/2014 9:52 PM
Here's a reason why aluminum is not too popular in motors and generators...
01/15/2014 10:03 PM
That looks like a pretty darn good reason not to use it as a motor/generator, but look on the Bright Side: it *could* double as a self-stirring aluminium crucible.
10/28/2015 1:55 PM
I think I understand the purpose of your question. And I've considered the very same concept. It seems that 100 volts at a resistance of 2 ohms is 5000 watts to remove the resistance by using gold in the windings would be to double the output wattage. Is that the hypothesis?
10/28/2015 7:12 PM
Back in the day, a combination of gold and aluminium on ICs caused purple plague, migration of gold under the effect of the high electric field, which ruined the ICs. Can't imagine why you would use it in this application.
Register to Reply 41 comments
artsmith (1); dhayanandhan (2); drbobwoolery (1); Fredski (2); geraldpaxton (1); JRaef (1); lyn (4); melloncolliephysicon (1); ndt-tom (1); OldTooly (1); Phaddy (2); RAMConsult (1); rhandwor (1); Rorschach (3); Shyam (2); SolarEagle (5); tcmtech (4); Theophilus Stark (4); Tornado (1); truth is not a compromise (1); unclefastguy (1); Yusef1 (1)
