Some
people say it is impossible to synchronize the clocks to measure one way speed
of light. That would be true if one would use Einstein synchronization of the
clocks.
What if we use back synchronization as follow:
Let's start with point A and B separated by known distance d. At
time tx as indicated on clock A we will send a signal (photon) from A to
B.Let's assume the signal will arrive at B at time t0. Now we can correct the
clock at A by substituting t0 for tx (so when the clock at A was ticking and
indicated tx+nt, it now will indicate t0+nt).
Now if we send a signal from A to B at time t1, the clock at B
will indicate t1+time the light travel from A to B.
Can anyone point an error in my reasoning?
