Previous in Forum: Weld Failed NDE Twice!   Next in Forum: Brass Over Nickel Plating
10 comments
Manufacturing
10/06/2014 8:56 PM
Hello,
I am looking at a print from the 1930's. It gives a description as follows.
2x8 S. PL. #2001
This is a description for material of a bracket. I know it is steel but looking for specific type. I need to have a crack welded. I am thinking cold rolled steel. Any suggestions greatly appreciated.
Re: Manufacturing
10/06/2014 9:10 PM
To me this says, (PN) #2001 bracket in 8 places. The S. is puzzling, but I wasn't born until 1947.
#2001 may be a reference to a bill of materials.
If a magnet sticks to it and it isn't rusted, just use a MIG welder with mild/carbon steel welding wire.
It'll be fine.
A picture might help.
Re: Manufacturing
10/06/2014 9:22 PM
One contractor did some MIG welding on the pieces. Did ok. Should have pre heated the base first, because one could tell not very good weld penetration on some welds. Next contractor coming in is going to stick weld. I figure the standard 6010 root, with some 7018 cover pass to fill out.
I can make sense of the other abbreviations in the prints. C. RS. should be cold rolled steel, and so forth.
Thanks.
Re: Manufacturing
10/06/2014 9:59 PM
steel plate...?
Re: Manufacturing
10/06/2014 10:38 PM
Its steel plate. Just trying to find out what kind. 1930'S generator from hydro unit
Re: Manufacturing
10/06/2014 10:44 PM
20 questions?
Re: Manufacturing
10/07/2014 12:49 AM
Are we down to 17 now, or up to 23?
Re: Manufacturing
10/07/2014 3:08 AM
AAnd would it matter which? (16/24)
Good moaning!
Re: Manufacturing
10/07/2014 7:06 AM
if there are any other similar notes maybe one can the decipher the drafting standard.
Otherwise with the information here, any response is a guess.
Re: Manufacturing
10/08/2014 11:24 AM
Depending on how critical these brackets are to plant safety (hydroelectric), you should hire someone with a good PMI gun (or atomic emission tester), find out the precise alloy involved (and if carbon steel, you need to know precisely the carbon content which most PMI guns will not give you). Another option is to have a sample cut off and sent for complete identification analysis, as this cost is far less than catastrophic failure.
On the other hand, how sure are you this "bracket" is not cast iron, or cast ductile iron? Did the fracture show anything about grain size - typical of cast iron failure. In the 1930's there were a lot of cast steel parts around, as I am told. If your welding protocol does not match up with the alloy type, the built up stresses from welding will result in a quick failure of the part.
Good Answers: 21
Re: Manufacturing
10/11/2014 1:29 AM
Do you have a back smith close. Or someone who can ID steel from the shape and colors, from grinding a small section? Sure fire way to get pretty close to metal type. Good Luck
Fixit
Register to Reply 10 comments
AllenK47 (2); Crabtree (1); fixitorelse (1); James Stewart (1); lyn (2); phoenix911 (1); SolarEagle (1); Tornado (1)
