Previous in Forum: Guide For My Estimation   Next in Forum: Burying Pre-Insulated Tubing
12 comments
Recommended Materials for Vessels with High Chlordies
11/03/2014 3:01 AM
Currently I am working on the designing of GOSP High Pressure Production Traps Vessels having 14.0 ft inside Diameter and 150 ft tangent length. Design = 200psig@220F. Material is SA-516-70N(HIC). Vessel has internals ( 2-Coalescers packing, 1-foam breaker, 5- surge baffles, weir plate, vane type inlet device) having material 316L SS. Vessel also has internal protective coating.
My question is that we have high chloride concentration in the vessel 60000 mg/L or 60,000 ppm. I want to know that this Vessel with internal coating (painting) and 316L SS internals is accceptable for this high chloride contents.?
Pathfinder Tags: Vessels
Re: Recommended Materials for Vessels with High Chlordies
11/03/2014 3:16 AM
It might be worthwhile for you to procure a membership in NACE (National Association of Corrosion Engineers).
Good Answers: 92
11/03/2014 8:16 AM
What is your pH, what are the associated cations and is the given concentration chloride ion or total chlorides, and are there any oxidisers or reductants in the composition? These details make a huge difference.
316L is a chloride resistant material, not chloride proof. It has been found to show pitting and crevice corrosion in seawater (design, finish and flow rates can have a big impact on this). My personal recommendation would be against using it at this elevated temperature.
As far as the carbon steel/ paint combination, no comment as this is a pressure vessel. Speak to your material supplier, provide more info on the protective coating or follow Tornado's advice.
Re: Recommended Materials for Vessels with High Chlorides
11/03/2014 8:20 AM
Follow Tornadoes (:-) advice. And while your are at it have a complete list of process parameter and fluids involved at hand.
Also make sure you know how long it needs to be acceptable and by whom.
What coating?
316L SS is not holding up for long in certain environment to 60000 ppm Chlorides!
Good Answers: 38
11/03/2014 9:05 AM
It is fortunate that you are asking this question before your expensive vessel design is complete !
It is not complete....is it ?
All of the people above offer good advice. Your 316L is not a good choice for your high chloride/high temperature environment.... it will form pits.
Your carbon steel shell may fare worse than the 316L..... It will all depend on the quality and type of the internal coating.
I suggest that you procure the services of a corrosion professional.
The Hendrix Group is very knowledgeable and experienced in chloride corrosion issues
http://hghouston.com/home.aspx
Please let us know of your final decisions.....
Good Answers: 97
11/03/2014 9:10 AM
Tantalum has good resistance to chlorides. Get out your wallet.
CRTL-Z
11/03/2014 11:23 AM
  • Plastics
  • Rubber lining
  • Glass lining
  • etc.
Make the vessel smaller. "What you don't have, cannot leak." - the late Dr. Treevor Kletz, globally-recognised process safety guru.
11/04/2014 7:01 AM
There is one recommendation to use Glass Flake Reinforced Vinyl Ester Coating for Immersion Service at Temperature up to 90°C. but this internal coating is not recommended when steam out cleaning will be utilized. and in this case what about the internals, SS 316L internals will also be provided with coating?
11/04/2014 1:37 PM
PTFE.
Good moaning!
11/03/2014 7:08 PM
At our company we use very aggressive chemicals (Acrylic acid, among others) in 304 SS reactors. So far, the best linings we have found to protect the vessels are: glass, Teflon and Plasma coating. From the latter, the only process that may be suitable for your vessel (due to it´s internal configuration) seems to be a Plasma Coating, as it it directly sprayed to the surface, requiring no subsequent melting as Teflon (250ºC) or glass (about 600ºc) do. Before hiring a company for doing these processes we sent them some sheets of metal, got them coated and eventually left these samples submersed in the chemicals to simulate an ageing process. Samples were later on analysed to determine the degree of the chemical attach (if any). Good luck in your project!
11/04/2014 12:07 AM
What is the major kations? NaCl solotion (brine) is stored at concentrations of about 180g/L as Cl or 300g/L as NaCl. HCl you need a ...... I do not know. Talk to some one at a Cl2 plant.
11/04/2014 1:05 AM
Good Day
You going to have a problem with cracking (Chloride Stress Corrosion Cracking) in the 316 ss, especially if your PH is more than 2. Low Alloy steels will be functional in such a vessel, but I think you have a corrosive environment, you will have to use materials with a high nickel content in the region of 35% nickel they are highly resistant but not totally immune, but material with 45% nickel are virtually immune, but these materials are expensive, but will last much longer, I am speaking of experience.
11/04/2014 12:45 PM
Did you really mean if pH is more than 2, or did you mean to say less than 2?
I agree that chloride, acid solutions, along with any heat stress will crack 316 within possibly even minutes, not hours.
Crabtree (1); gvz12 (1); IdeaSmith (1); James Stewart (1); JNB (1); Metallica (1); MJCronin (1); nhabib (1); PWSlack (1); r&ddoc (1); Tornado (1); Unredundant (1)
